Fender Replacement DYI (help ?)
Discussion in 'Gen 2 Prius Technical Discussion' started by P-car, Dec 6, 2008.
  1. P-car
    P-car Junior Member
    44
    Bucks County, PA
    Our 2005 Prius needs to have the driver-side fender replaced -the good Lady had a small mishap exiting our narrow garage. I found an aftermarket supplier (on eBay) that sells them primed (~ $90) or painted (for extra $150). Any advice on whether this is a DIY friendly (lots of mechanical but no body repair know-how) undertaking...?
    Any and all pointers are most welcome…
    Thanks
    Jascha
  2. Patrick Wong
    18,200
    6,472
    Hi Jascha,
    I suggest you invest $10 for a one-day subscription to techinfo.toyota.com and download the body manual pages relating to the front LH fender replacement so you can judge whether you can do this or not. Depending upon your car's exterior color and your ability to discern various shades of colors, you may or may not like the color match between your car and the newly painted fender especially in bright sunlight.
    Regarding an aftermarket fender, it may or may not precisely match the Toyota-branded part, so be aware you may be accepting some risk there. Good luck with your repair.
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
    I looked at the body repair manual. It doesn't give full instructions, but it looks relatively straightforward. It looks like there is a retaining clip up near the top of the fender which you will need to release to take the old fender off. Since you need to access the clip inside the fender, you will need to remove the fender liner first. I'm attaching the two pages that show the bolt locations and the clip location.
  4. P-car
    P-car Junior Member
    44
    Bucks County, PA
    Many thanks for the cogent pointers and the telling diagrams -it would be nice if I can reach the anterior fastener without removing the bumper cover…
    Fred, you have great loyal friends!
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    I think you will have to release the bumper cover clips on that side to access that bolt, but I don't think you would have to remove the whole cover.
  6. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    Here is how to remove the fender:
    1. Remove the wheel.
    2. Remove the wheel well liner. There are several fasteners that hold the liner in.
    3. Remove the front bumper cover. You may be able to get away with just unhooking the fender and headlight on the side you are working on.
    4. Remove the headlight.
    5. Remove the inner A pillar liner. This part is located in the wheel well were the door meets the fender. Just stick you head in the wheel well and look toward the rear of the car, it's the tall black plastic thing.
    6. Starting with the bolt that you access by opening the door and looking toward the fender streight removing all the fender bolts. There is one in the door jam (it's up high), one under the A pillar liner, one on the rocker panel (under the car), one under the bumper cover on the side up front, and 2 on the top ledge under the hood. One of the top ones is under the seal that comes down from the windshield so you will have to pop that out of the way.
    Take the top bolts out last so the fender won't fall off and scratch up the rest of the car. You may have to tug on the old fender to get it off as it's glued on to the car just under the little window.
    Another thing: You can get a primed aftermarket fender from someplace like CertiFit Auto Body Parts - Home for $35
    emendia likes this.
  7. P-car
    P-car Junior Member
    44
    Bucks County, PA
    Here is my picture story of the fender replacement...
    For the most part, I followed the succinct instructions generously offered by jelloslug and dogfriend. I chose to unbolt only one side of the bumper cover and was able to set-aside the headlight assembly -which facilitated greatly removing / re-installing the fender. The one tricky part is to recognize (now you will) that one of the fasteners located at the edge of the side window (clip type) can only be approached from the liner side (see below). After some mock experimentation / assembly it became apparent (confirmed with a friendly Toyota bodyshop Tech) that the best way to do it is to locate the clip in its designated hooked slot (on the frame) and thereafter press the finder to it. Do not try to do it with clip on the fender (most are supplied that way)!
    It was not all that difficult but requires diligence and patience (still working on this virtue )
    Again, I would like to thank all of you who offered words of encouragement and advice!
    emendia and valsor like this.
  8. Rickame
    Rickame Junior Member
    Eliot, Maine
    I'm replacing my fender and have two questions if anyone sees this comment on this older but great thread.
    1. I would like to know what holds the clip that you have to get to up under the wheel well. Like P-Car notes, its attached to my replacement fender and it needs to first attach to to the hooked slot. It looks like there is a bolt of some sort in the slot, does it just push on or am I missing something.
    2. Kinda off topic but can someone tell me what the black round plastic plastic item is near the lower headlight attachment on the car body, looks like there may be wires coming from it. I do not seem to have that item, but do have on two wire plug that goes nowhere. I don't know if I had it before I dented my fender or if it may have broken off...wonder if its essential:) You can see the item in two of P-Cars photos, img_0724 and img_0719. I may aske in another tech topic too.
    Thanks for any help.
    maverick1970 likes this.
