Fender trim part number
Discussion in 'Gen 5 Prius Main Forum' started by bostonbruins8703, Feb 5, 2024.
  1. bostonbruins8703
    bostonbruins8703 Active Member
    178
    101
    Brewster, Ma
    2024 Prius Prime
    XSE
    #1 bostonbruins8703, Feb 5, 2024
  2. Hammersmith
    Hammersmith Senior Member
    1,305
    1,331
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Need more info. Front fender or rear fender? Which exact piece are you looking for?
  3. bostonbruins8703
    178
    101
    Brewster, Ma
    2024 Prius Prime
    XSE
    The black glossy fender trim that’s on the fender. Rear back passenger side
  4. bostonbruins8703
    178
    101
    Brewster, Ma
    2024 Prius Prime
    XSE
  5. Hammersmith
    1,305
    1,331
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'd double-check this if I were you, but I believe they are:
    Front-right: 75601-47020
    Moulding Sub-Assy, FR Fender, RH
    Front-left: 75602-47020
    Moulding Sub-Assy, FR Fender, LH
    Rear-right: 75605-47020
    Moulding Sub-Assy, Quarter Outside, RH
    Rear-left: 75606-47020
    Moulding Sub-Assy, Quarter Outside, LH
    You can also get a body-color-matched set from HybridPit(for an insane price):
    Grazio&Co. Colored Fender Arch Molding for Toyota Prius 2023-2026
    If anyone wants the matte black version from the LE/SE, replace the 47020 with 47010 in all the part numbers.
  6. Gwyd
    Gwyd Member
    102
    75
    NE Florida
    2023 Prius
    @bostonbruins8703 - did you order this part and determine it was the correct one?
    I don't understand why the entire front fender sub-assy panel is $225 and the flimsy piece of molding is $140....
  7. bostonbruins8703
    178
    101
    Brewster, Ma
    2024 Prius Prime
    XSE
