Fill up at a 1/2 tank! or pay $159.12
Discussion in 'Gen 2 Prius Main Forum' started by mdescher, Aug 1, 2006.
  1. mdescher
    mdescher New Member
    This is under the don't let this happen to you catagory. I have a 2006 and recently I was driving when the gas gauge light went from the 2nd bar to just one bar left, I went a bout 2 blocks and pulled into a gas station...car and ari conditioning were running fine as it was over 110 degrees that day. Filled up the tank putting only 9.2 gals in to fill...then the not fun part happened...my Prius would not start. Called for a tow to my usual Toyota dealer (Northridge Toyota) who ran a computer check the "cannot be wrong" and said I had 2 errors. aP3190 Poor engine power code, and a P3193 Fuel ran out code.
    To make a long story short, the dealer said the computer would need to be re-booted, and charged me $159.12 for the pleasure. I was informed that thisis NOT UNDER WARRANTY, and was told this happens to all new Prius drivrs, and I must have been mistaken as the computer said I ran out of gas and this is what caused this!!! Funny how you can run out with 2.7 gallons of gas in the car....a car I might mention that states 50 miles to the gallon...evn my worst mileage uphill with air on is 37mpg...that said I should have been able to drive another 75+ miles easy before running out of gas.
    Then it gets better...I pay so I can get to work...still disgruntled, and then call the dealership to complain 2 days later...I am told that the sales person should have said you have to keep at least 1/2 a tank of gas in the car at all times as the gauge does not display properly due to a bladder type fuel tank that contracts and expands with the outside temperature....and there is nothing I can do about it but call regional
    Toyota. I did this yesterday, they confirmed this is not in the manual or on the warranty. I will now wait to see how this gets handled...in the meantime I am warning everyone I know of this...I hope you do too!!
    Love my Prius...but if this is true...they need to recall them and fix it or make sure anyone who owns one is aware with a big sticker ovr the gas door ;-)
  2. FBear
    FBear Senior Member
    355
    23
    Maplewood, NJ
    2015 Prius v wagon
    That is a total crock of c**p. Yes, it's true you shouldn't run the tank down to the last flashing pip. But half-full no way. You should speak to the regional Tech and press them on getting the money refunded. 2.7 gallons does not constitute an empty tank. Keep badgering them until they fork over the refund.
  3. Renocat
    Renocat Member
    363
    Rochester, NY
    <div class='quotetop'>QUOTE(mdescher @ Aug 1 2006, 01:27 PM) [snapback]295729[/snapback]</div>
    I say that is not acceptable. Pay the kind of money we do for a Prius and then be told you have to keep it 1/2 full even though the manual says nothing about that :blink:
  4. paco-shalom
    paco-shalom Veteran Prius Owner
    62
    Phoenix
    2 points:
    1. You probably did not have 2.7 gallons left in the tank if you put in 9.2. I have never been able to fill with more than 9.8 from the flashing pip, even the one time I ran out of gas. When calculating the max range for a tank of gas, use the number of gallons from your last fillup, not the maximum capacity. This is because of the bladder-tank.
    2. I have never heard about rebooting the car computer after running out of gas. So many Prius drivers do run out, especially when trying to push to see how far they can get on a single tank. In my case, the car started up just fine after I added fuel.
  5. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    I often don't fill till the flashing pip on my 2005. I have actually gotten 10 gallons in once and never had a lick of trouble. Go after Regional, your dealer is feeding you a big load of......
  6. darelldd
    6,057
    389
    Northern CA
    Yeah, this is BS. No need to guess at how much gas was in the tank - the gage clearly showed that you had gas in the tank... and the car was still running! As far as I can tell, you did NOT run out of gas... and even if you did, there's a charge for this? Wth?
    If we can only use half a tank, then the day has now dawned when a modern EV has substantially more range than a modern gasoline car.
  7. daronspicher
    daronspicher Active Member
    1,208
    <div class='quotetop'>QUOTE(mdescher @ Aug 1 2006, 12:27 PM) [snapback]295729[/snapback]</div>
    When they tell you stuff like this, ask for this information to be sent to you on letterhead, signed by whoever wants to back this statement up.
    Then post a scan of the page on here for all of us..
    Then start talking to Toyota corporate about what the heck is going on here.
    I've filled up 38 times (since 2/15/06). 2 times, 11+ gallons. 10 times with 10.x gallons, and 16 times with 9.x gallons. Most of the 9.x gallon ones are in the high nines.
    I think I've only had the blinking pip once or twice. 28 of 38 fillups are 9.0 and up, I'm not sure why all the trouble with people running out of gas, or having trouble gassing up their prius. Did I get the reject car that is freaky normal in this way?
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Dash should have lit up like a christmas tree if you were out of gas. If that didn't happen then it shouldn't have logged an error code. Often you can find the mileage at which the error code was logged, you should ask for that information, if they have it now, maybe it was something in the past and was stored.
    Can't explain why you didn't start up, something else was off. Do you have SKS? Did you leave the fob in the car while you fueled? There's a situation where you can hang-on-start up if you hit the Power button twice very quickly and that can be tricky to get out of (there's something in the FAQs about how to resolve that).
    In any case, I think it highly improbable that you ran out of gas if the dash never lit up and told you there was a problem. Likewise there is no 'reboot' necessary if all that occured is that you ran out of gas, many many people do this semi-on purpose all the time with no consequences other than a CEL for 3 start-up cycles.
  9. taoofbean
    taoofbean New Member
    Portland, OR
    I ran out of gas completely and the computer did not need a reboot.This is bullshit. Particularly this 1/2 tank comment is pure bull. Don't stop till you get your money back.
  10. mdescher
    mdescher New Member
    <div class='quotetop'>QUOTE(daronspicher @ Aug 1 2006, 10:18 AM) [snapback]295777[/snapback]</div>
    Lesson is in the leaning and experience gained. I called Toyota regional yesterday, they said they would have the regional customer service person contact me within 3 days. I will continue to post on this until resolved. Did not make any sense that if a car runs out (even though it did not) you cannot just fill it up an go.
  11. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    When I test drove my new-to-me 04, it had the flashing pip. I took delivery this way, and my sales guy "convoyed" with me to their contract gas station for my "free" fill-up. He did the card, and I pumped. We got every bit of 11.5 gallons into the car ( :blink: ). Close call, I guess, but the car has shown no signs whatsoever of acting up as a result.
    Beyond the question of getting your money back, which you very well should, I'd also want to know why the car acted up in this fashion. You might demand that they produce for you the exact codes thrown by the ECU, which you could then research yourself. www.techinfo.toyota.com is a good starting point, though you do have to pay for access to the service documents. You can buy daily, monthly, or annual access (I usually do the $50 monthly access when I've built up a couple issues I need to look up (we're now back to being a two Toyota family -- I do this maybe 3-4 times a year and look up lotsa stuff during the 30 days).
  12. mdescher
    mdescher New Member
    <div class='quotetop'>QUOTE(ekpolk @ Aug 1 2006, 10:29 AM) [snapback]295789[/snapback]</div>
    They were nice enough to put the codes on the invoice. For everyone's refference they are: P3190(poor engine power) and P3193 Fuel Run Out, then HV ECU code POAOF (engine fail start) - then in comments wrote - refer to owners manual about low fuel and fuel run out. I spent 2 hours page by page thru the owners manual and copuld not find one thing abou this other tan a small statement that it is not good to allow vehicle to run out of fuel (DUH!)
  13. CrazyRussian
    CrazyRussian Junior Member
    42
    Keep at least 1/2 fuel in tank!!!! How about filling up at every gasstation that comes your way!!!! Damit, how the hell dealerships come up with that crap???
  14. mdescher
    mdescher New Member
    <div class='quotetop'>QUOTE(CrazyRussian @ Aug 1 2006, 11:05 AM) [snapback]295811[/snapback]</div>
    Perhaps not all dealerships...I have had good experience with this dealer for serice...until now. Northridge Toyota in Northridge, CA.
  15. ekpolk
    548
    176
    2018 Prius
    Two Eco
    md:
    You won't find the good stuff in the owner's manual. It's a "dumbed down" lowest common denominator thing. The service bulletins, manuals, and so forth are all accessible, for a small fee, at the link I added in my last post. I think the daily rate is $10. You can view and download a lot of stuff, all models of Toyota and Lexi, in 24 hours. Though I'm new to the Prius, we've owned Toyotas of one stripe or another, for almost 10 years. This site is the place to find anything you want to know about your Toyota.
  16. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(ekpolk @ Aug 1 2006, 12:47 PM) [snapback]295834[/snapback]</div>
    And nowwhere do those documents say to never go lower than 1/2 tank... nor that there will be some major service charge if you do.
  17. Tideland Prius
    16,122
    <div class='quotetop'>QUOTE(Renocat @ Aug 1 2006, 10:36 AM) [snapback]295739[/snapback]</div>
    Actually, the manual does say that but it's not ½ tank, it says to keep at least ¼ tank of fuel.
    "It is a good idea to keep the tank over
    1/4 full.
    When you refuel on a slope, the indicator
    may not show the correct level.
    When you refuel less than about 11.4 L
    (3.0 gal., 2.5 lmp. gal.), the fuel indicator
    may not change."
    pg 114 in 2004 US Owner's Manual
  18. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Out of all of this i'm curious... exactly what does the tech mean by "rebooting" the ECU? I can see having to clear the error codes, but turning the car off shuts down the ECU and turning it on boots it up... i'm not seeing where he really has to do anything!
  19. mdescher
    mdescher New Member
    <div class='quotetop'>QUOTE(eagle33199 @ Aug 1 2006, 01:15 PM) [snapback]295883[/snapback]</div>
    I am not sure, but the sevice manager said it takes 2 to 2 1/2 hours to do! They also set the "inclination meter and reset ECU and tested the fuel delivery system with OBDIISCAN tool" and verified low fuel light working. I am not sure even if there is an "inclination meter" and what it would do...tell you if you were on a slanted road? LOL!
    I think it is a dealer training issue. When we bought the Prius the service manager reccommended buying the extended warranty on a 3 year 36,000 mile lease, he quoted a service schedule exactly like me Solara...I had done some research and said I did not think it needed any major service until 100k miles except oil etc. and they said no. So we bought it and drove off...when I got home I again read the service schedule in th manual, and demanded a refund as I was right...they hemmed and hawed then when I went to the dealership and should the service manager the schedule...he apologized and said he actually had never even seen the schedule in the manual as cars were selling so fast. They refunded the contract...different dealer..Frontier Toyota in Valencia, Ca. Toyoto really needs to improve their training! IMO.
  20. ServoScanMan
    ServoScanMan Member
    262
    Lorena, TX
    I just filled up today with 2 pips on the gauge. The Wal-mart pump said it put in 11.418 gallons. How big is the tank on the 2006 model?
