Fill up on 2010 how much do you do
Discussion in 'Gen 3 Prius Main Forum' started by ilovemymac, Jun 1, 2013.
  1. ilovemymac
    ilovemymac Member
    170
    22
    Gardner, KS
    I finally got to my 2nd fill up. I noticed it clicked off and i am use to with my old car usually being able to go a little more to get to an even dollar amount. I wasnt even thinking and when the pump clicked off i started it again and was able to put almost another gallon of gas in and then i was still able to go a little more to get to an even dollar amount.
    Do you guys do that or first time it clicks you leave it?
    If i go by what i put in 7.9 gal with 3 bars left on the gage i got 44.5. BUt if i go by where it clicked off the first time then my millage was over 50.
    49,373
    if you fill at the same pump every time, either technique is fine as long as you're consistant. one tank isn't that accurate. the more you have, the closer the average will be. i like to round, but the higher the price, the more difficult it is. you don't want gas coming back at you, i stop at the first click.
  3. TwoUnderPar
    TwoUnderPar Member
    78
    72
    I fill up until the gas level is at/in the filler neck. I don't stop until I can see it... that way I know I have gotten every single drop of gas in the car that is physically possible. It is also a very consistent method of fill-up since the "one click" or "three click" or "whatever click" is not consistent from pump to pump.
    WE0H likes this.
  4. peterjmc
    917
    188
    Clarksburg, MD
    I stop at the first click.
  5. El Dobro
    El Dobro A Member
    6,978
    3,213
    If I can get to the handle (NJ) I stop at the first click and then round up to the next dollar or fifty cents.
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
    When it clicks off I fill to nearest gallon, just makes paper work easier, always even gallons! :)
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Your 2006 Prius has a fuel bladder in the tank. It's hard to get the same amount of fuel in every time so checking mileage the old way will not yield accurate results unless you record the gallons and miles for several thousand miles then do the arithmetic. When I had my gen2 (2005 Prius) I just used the consumption read out which on that version of the Prius was pretty accurate.
    This is the Gen3 forum and our cars (2010 and newer) do not have a bladder in the fuel tank and the pump usually clicks off at about the same fill level each time, providing the pump works as it should. I still use the consumption read out but on Gen3 cars we need to subtract about 4% from the indicated mpg because of a built in error in the reading.
  8. ilovemymac
    ilovemymac Member
    170
    22
    Gardner, KS
    I don't have a 2006 I have a 2010
    But if I stopped at first click then my mpg is higher then what is on the readout.
  9. Rupert B Puppenstein
    Rupert B Puppenstein Active Member
    261
    126
    North Carolina
    I fill up to the first click. I don't see how it would be consistent if you went over that. I have found that most pumps are very close when it comes to when that happens. The tricky part seems to be the surface of the gas station. Some are level, and many are not. So, that is when I get a bit of a discrepancy.
  10. tumbleweed
    4,067
    687
    Eastern Oregon
    The info panel below your avatar says you have a 2006, that's all we have to go by. :)
    With a 2010 I suggest using the consumption read out and subtracting 4% from the reading and it will be pretty accurate.
  11. ilovemymac
    ilovemymac Member
    170
    22
    Gardner, KS
    If I go by that my mpg sucks. But I don't think it's accurate. If I go by filling up 1 click off then I got about 4% better.
    Sorry will change the info. I have a 2010 v with the 17in wheels
  12. SFR-DSR-44
    SFR-DSR-44 Junior Member
    59
    Milpitas, CA
    I don't know about Toyotas, but, filling up until you can see it on Fords results in fuel getting sucked into the EVAP canister and over time this ruins it causing an emissions error code to be thrown. I only go to the first click.
  13. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    I stop at first click for thisd reason also. Toyota doesn't recomend topping it off so you can see it.
  14. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    That indicates to me the likelihood that your first fillup was closer to the top than you second fillup at the first click.
    I usually go to the second or third click, but I don't believe that I am consistent in how far I fill the tank. Therefore the MPG for any given tank may be off, but it all averages out over the long term.
  15. GBC_Texas_Prius
    218
    38
    gbc texas
    Pointing out the obvious, if you track every mile, it all averages out and worrying about how many clicks doesn't matter.
    I try not to push it past a couple of clicks. On my CRV, fuel apparently got sucked in to the canister by me trying to top it off too much. The check engine light has been on for 3 years with no decrease in performance or mileage. Luckily I don't live in a county that requires emissions tests.
    I have the same mentality. If I squeeze in an extra half gallon, that's another 25 miles or so on the tank, but I think you have to overcome that temptation. The risk reward isn't there.
  16. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Like stated above, you cannot compare calculations between tanks if you don't use the same filling procedure. Choose one method and stick with it.
    I stop at two clicks on my PIP because the pump sometimes shuts off early if I am not holding the handle just right. My 2012 Three never had this problem so I stopped at one click.
    As mentioned above, most manufacturers recommend NOT topping off. It could harm the car. Some people claim to have never had a problem but why take the chance? You have the ability to drive 400+ miles on a tank. That should be good enough.
    FWIW, your displayed mpg is between 4.5% and 6% optimistic compared to hand calculations. Some very early model 2010s were closer to 9% optimistic! This is based on observations from hundreds of GenIII owners.
    peterjmc likes this.
  17. Mendel Leisk
    38,646
    That seems to be my case: over two years of tracking the error I'm seeing is around 8%.
    Just to chime in: there is NO reason to try to squeeze more in, trying to second guess the pump shut-off mechanism. I've found each tank calc pretty accurate, using the stop when it shuts off method, and ANY error is cancelled out at the next fill up.
  18. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
  19. WE0H
    WE0H Senior Member
    3,247
    527
    First click if you don't want to take a chance of spilling gas on your car. Otherwise fill 'em to the threads for the most miles per tank ;) I have never had a evap can issue on any vehicle since 1984 when I started driving, but others will say different. Fill it as you desire :)
    Mike
  20. socalcoast
    socalcoast New Member
    California Coast
    I don't know if this makes sense, but I am going to put in only six gallons, which covers my weekly commute of approx 300 miles..
    This should help to keep the car lighter...
