Filling the tank...
Discussion in 'Gen 2 Prius Main Forum' started by McGiffin, Nov 30, 2005.
  1. McGiffin
    McGiffin New Member
    I've had my 2005 for a couple weeks now, and tried to fill up the other day. It kept tripping the nozzle shut off, when I knew the tank wasn't full (it added about 7 gallons when the guage was on the last bar). I tried to "top it off", but I'd only get a couple cents worth of gas each time before the nozzle shut off. Kind of irritating.
    After driving about 25 miles(post-fillup), the gas guage dropped to 1 bar from full, so I know it didn't fill.
    What's the trick to "filling" the tank?
    TIA.
    Bill
  2. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    <_< Bill
    Try searching on "bladder" or "tank" in PriusChat. This subject has been extensively discussed for month after month. Some of the comments will no doubt be informative for you.
    This is a well known peculiarity of the Prius caused by the fuel tank bladder.
  3. McGiffin
    McGiffin New Member
    Thanks Charles! I tried searching on GAS and Tank, but no luck. I figured it must have been discussed already.
  4. CedricMordrin
    CedricMordrin New Member
    42
    What are the temps in your area like?
    I've only had mine two weeks now, and I have filled it up once, was down 6bars and was able to put in 7.64gal. It was about 80 degrees F here when I did that. From my understanding the bladder is somewhat sensitive to temp, not wanting to expand as much in cooler weather.
  5. jeromep
    jeromep Member
    827
    Eastern Washington State
    The bladder is pretty sensitive to temperatures. In warm weather it is fairly pliable and will expand to its full capacity pretty easily. In the winter it tends to not want to expand and as such makes filling the car up a bit difficult.
    Try filling the vehicle more slowly to allow time for the bladder to expand with the additional volume of fuel you are pouring in.
  6. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Yup, it's getting cold out. Don't worry about it.
  7. NuShrike
    NuShrike Active Member
    1,378
    Our FAQ on this.
  8. Cocoatreat
    Cocoatreat New Member
    65
    Miami
    i have had my new pri since mid october.......i have never had any problem with the gas bladder.. but then i do live in so fla......& the temp here is warmer
    i usually fill my tank up once a week.......(at about $7.50!) at the cooler part of the day..
    my gas tank never goes b4 3/4 tank
    the most i have filled up my tank was the 1st one.......driving from north palm beach to miami from the dealership.......i think then i added about $14 ....at about 1/2 tank
    i'm pretty impressed still.......& the love relationship continues~ :rolleyes:
  9. Stevep
    Stevep Junior Member
    77
    Orlando, Fl
    I have filled up about 4 times. and find that if you fill up slowly, there will be no problem. I have averaged about 54 MPG, and the computer agrees with figuring the mileage manualy
  10. MNPrius
    MNPrius New Member
    177
    Minneapolis
    Despite all the information on here - I'm still struggling with this. It's cold here in MN and I rarely can get the tank full. Lots of time, the last bar disappears within a couple of miles. So I share your pain!
  11. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Dude join the club, you are likely to be way colder that I am, even if we do have snow right now (run and hide run and hide). OK we get just a little phrenic when there is one inch of snow around here. Yeah, Yeah, Yeah I know that is not much, but remember we use the God method of snow removal. That is God put it there and God will take it away. More the half the people around here can't drive in any snow at all.
