Filter wrench for oil change. Help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lenalik2000, Nov 19, 2009.
  1. lenalik2000
    lenalik2000 New Member
    26
    Sharon Mass.
    I'm having trouble finding the filter wrench at local Auto zone store. The article in this forum calls for 65mm wrench. In the store they don't have the size on the wrench, only part numbers. Is any one got the wrench from Auto zone? I need the part number.
  2. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    I got mine from Pep Boys and they did not have sizes on the package, but they do on the wrench itself. So you might try looking at the wrench instead of the package.
  3. lenalik2000
    26
    Sharon Mass.
    Update: Auto zone part number 25404 "F"
  4. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    Last week I was at Walmart. They sell the wrench. I was going to post the part # but I can not find it on their site.
  5. Ongs-Hat
    Ongs-Hat New Member
    16
    Raleigh
    I've read other threads here that state 64mm wrench. Which one is it?
  6. SureValla
    SureValla Member
    590
    Shelton, CT
    why do you need a filter wrench? In my Gen II I just use a giant pliers with rubber grips.
  7. lenalik2000
    26
    Sharon Mass.
    Just changed my oil and posted video on youtube if you want to wach. [ame=http://www.youtube.com/watch?v=iSI--fzSVfs]YouTube - 2010 Toyota Prius oil change. How to change oil[/ame]
    10 people like this.
  8. Judgeless
    1,821
    255
    Cleveland, OH
    I stopped by the Walmart less then 1 mile from my house and picked one up today. It was $3.26.
    Name: Imperial Universal Oil Filter Wrench 65/67mm
    Part: IF-6567C
    Walmart SKU: 073035918185
    UPC Code: 7 30359 18185 2
    Price: $3.26
  9. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    I thought the 65/67mm would not work on the Prius???
  10. Judgeless
    1,821
    255
    Cleveland, OH
    This device supports both 65 and 67 mm. The enter ring is 65mm
  11. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    I thought I read that the 65/67mm did not have enough clearance to take off the filter.
  12. Stellarnaut
    Stellarnaut Stellarnaut
    Fort Worth, TX
    2018 Prius
    I've got the 2010 Prius. I tried the 25404 from Autozone and it slipped too much so I took it back. Being a two step I noticed the outer step was preventing the inner step from seating properly to get a tight fit.
  13. Mendel Leisk
    38,240
    Just measure my Honda filter socket, which is a perfect fit on the Prius filter cap: inside face-to-face is about 64.3mm (corner-to-corner is almost 66mm). It has 14 faces.
  14. taxachusetts
    taxachusetts Junior Member
    39
    Boston
    "I thought the 65/67mm would not work on the Prius???"
    It won't work on the Gen III. I had a 65/67 and modified it with a file to work on my 2010.
  15. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    I found the 65mm wrenches were to big. I bought this one and it works fine.
    http://www.amazon.com/Assenmacher-Specialty-Tools-TOY-640/dp/tags-on-product/B0015PK3AG
  16. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    FWIW, I also bought the Assenmacher oil filter tool. Fits perfectly. You might be able to get a similar tool thru a dealer parts Dept faster but probably at higher cost.
    The only other hard-to-find "special service tool" I've found necessary on my Prius is a 23mm socket for the wheel lugnuts. It took several hardware & tool store visits to find one locally.
  17. gliderman
    gliderman Active Member
    751
    223
    I always wondered why Toyota, and others, dont just put a nut on the end of the oil filter cap?
    Seens like an easy and smart thing to do.
    +1 Assenmacher oil filter tool
  18. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    The SST works on many Toyota and Lexus automobiles.
  19. Shalomobile
    Shalomobile Shalomobile
    Fayetteville, TN
    The 65-67 wrench would NOT work on my 2010 Prius...Bought one today at Advance Auto Parts and returned it for a refund...
  20. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
    One millimeter? Hopefully your cartridge wasn't over-tightened. Be very careful when you get the 64mm variant.
