Filters...questions...
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Jorlan, Jul 4, 2016.
  1. Jorlan
    Jorlan Junior Member
    35
    27
    OK...Since owning my 2016 Prius back mid february I already put 15,000+ miles on it sincei pretty much drive 180 miles a day for work...
    QUESTION:
    1. When are the air filter and cabin filter supposed to be replaced again?
    2. Can i use K&N Air filters? It doesnt say in the manual if i can use wet type air filters...
    3. Will this void warranty?
    52,405
    cabin filter, check, clean or replace very 15k.
    engine filter, same at 30k.
    you can use k&n, but there's no benefit. you can't beat the oem filters.
    kithmo and WilDavis like this.
  3. Mendel Leisk
    41,928
    Look in your Warranty Booklet for the filter intervals. Keep in mind though: you inspect it; there's no point in replacing filters that are still in good shape. Lifetime can vary greatly depending on your air conditions.
    Considering the infrequency of filter changes, the risks inherent in oiling a K&N filter improperly, the lack of any "performance" advantage, I would stick with the OEM Toyota filter.
    #3 Mendel Leisk, Jul 4, 2016
    Coast Cruiser likes this.
  4. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    I'm running k&n in 2011, agree, no benefit, going to replace it with paper filter next time. Its not worth the extra cost, seen no improvement in gas mileage.
    Coast Cruiser and bisco like this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    No advantage with the Prius to using a free flow filter, the MAF will compensate by enriching the mixture then the 02 sensors will detect a rich mix and lean out it out. Depending where the 02 sensors are on the catalytic converter, after or before, you could be damaging the cat with the rich mix if they are after it..
  6. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    I don't know if the cabin is in the same location as my gen 2. But it's behind the glove box. It was in the owners manual. Drop the arms on the box and slide out the filter. Like a air conditioner filter. They get clogged with leaves, etc quickly. The engine air filter could get bad if you drive on dusty roads. A few minutes to change. Filters and oil changes were my only maintenance for 200K.
  7. krmcg
    2,592
    2,392
    Whittier, CA
    Yes. It is.
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  9. Mendel Leisk
    41,928
    Cabin air filter I would knock the debris off, hit with air in the reverse direction, carry on until hopeless, then change.
    Engine air intake filter I would replace when it's significantly dirty. The car's computer will adjust fuel to match air flow, so you don't have to be obsessive about it. On the other hand, I wouldn't try to clean it, like the cabin filter.
  10. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    High flow rate filters won't make it a race car and they let too much dirt go by destroying the top piston ring. Why would you want to do this? How much time do you really spend with your foot glued to the floor anyway? Do you need the extra half horsepower that badly?
  11. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    Also a good idea to check cabin filter for rodent damage. I have had mine for a year and just checked it for the first time and found a mouse nest. I think it had been in there a while maybe even before I got it. It was certified and the dealer was supposed to check it but who knows if they did. I have been rechecking it since I replaced it and there is no sign of it coming back. I just used the Walmart fram filter.
  12. ETC(SS)
    7,367
    You're putting 50,000 a year on a 2016 for work?
    Wow.
    You're a little early for filters, but I would recommend against the K$N filter.
    There's no benefit.
    Sometimes people say that there's a small ecological benefit, but I would submit that paper filters in a landfill might not be a net benefit compared with the impact from the cleaning and re-oiling procedure. YMMV.
    There's no horsepower gains that are real-world measurable in a Prius and there are no MPG gains either.
    I've never peeked inside a G4 but I'm thinking that you have a throttle body and a Mass Air Flow Sensor in there somewhere.
    K$N have a bad habit of oil fouling some of these components if you use too much oil in the gauze, and if you don't use enough the K$N has the same filtration ability as a gym sock - because that's pretty much what it is.
    At your depreciation trajectory your car isn't going to be worth much in 5 years, so yeah...the K$N filter might theoretically save you some money in filters but perhaps not so much if it costs you an extra service visit or two along the way, and after you factor in the costs of the oil cleanings.
    Good Luck!
  13. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I would agree to not using a KN air filter because they have commonly messed up mass air flow sensors in other cars
    Nexus 6 ?
