filthy cooling fan
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nancytheprius, Aug 6, 2021.
  1. nancytheprius
    nancytheprius Active Member
    357
    153
    iowa
    Hi Everyone i decided to clean my cooling fan for the hv battery as preventative maintenance and I was shocked as to how filthy it is. My 2006 prius only has 77k miles, but i’ll attach a picture. it is covered in filth. Any ideas on how to get it all off? I’ve used a new toothbrush and a plastic fork to gently scrape a lot off. I am also vacuuming periodically, but there is still so much stuck on. Thanks!
    The next picture is the “clean” version, but is still really dirty.
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,589
    5,888
    Texas Hill Country
    Try some window cleaner and q tips
  3. nancytheprius
    357
    153
    iowa
    thanks, i’ve been using q tips and have had a ton of luck! i’ll send an after pic update. i’m really glad i decided to check out my fan
    iPhone ?
    Mendel Leisk and SFO like this.
  4. nancytheprius
    357
    153
    iowa
    Here’s a before and after picture from q tips and a vacuum.
    before
    after
    iPhone ?
    bisco and Mendel Leisk like this.
  5. Mendel Leisk
    40,574
    Run a duster boa through all the ductwork too. If you’ve got a vacuum that can be set to blow, that’s good too, for chasing dust outa the corners.
  6. rjparker
    9,589
    5,888
    Texas Hill Country
    Nice
    nancytheprius likes this.
  7. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
  8. nancytheprius
    357
    153
    iowa
    It was my first time working near the hv battery. Total like an hour and a half, but now that you know the q tip trick it should be less than an hour. I’ve also watched videos and read articles and never saw one as dirty as mine was
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    What’s the cabin filter look like?
    What’s the engine air filter look like?
    How low is the oil on the engine dipstick?
    #9 edthefox5, Aug 12, 2021
  10. nancytheprius
    357
    153
    iowa
    Here was my engine air filter a couple weeks ago! I changed my oil myself last month and filled it to abt 3 quarters up the dipstick and 2500 miles later it’s still at that spot
    dolj likes this.
  11. nancytheprius
    357
    153
    iowa
    I replaced the cabin air filter too and it was not pretty
    iPhone ?
  12. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Why is your car so filthy?
    Why 3/4 on the dipstick there’s a full line that’s where it needs to be.
    How many miles on the car.
  13. Mendel Leisk
    40,574
    I don’t know Ed: if it’s 3/4 of the way and stable, I wouldn’t stress about it.
  14. nancytheprius
    357
    153
    iowa
    it has 78k miles. I bought it from an elderly man and it used to be his wife’s car. It sat for awhile while she was sick before she passed so my guess is dust? no pets tho so it still seems weird. I filled it 3/4 between low and full because it was overfilled twice before i just started doing my own oil changes.
    edthefox5 likes this.
  15. Mendel Leisk
    40,574
  16. rjparker
    9,589
    5,888
    Texas Hill Country
    Ignore the static...
  17. edthefox5
    10,096
    4,831
    Clearwater, Florida
    the problem with that is if you don’t keep the oil at some certain demark
    You will never know if it’s eating oil or starts eating oil and how many engines have we seen on this site fail from lack of oil. Oil light comes on too late.
    And it’s always the just bought it. But whatever don’t stress about it.
  18. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    You'll be fine at that level and it is better than being overfilled. There are bigger things in life to worry about.
  19. Mendel Leisk
    40,574
    Too: when doing oil changes, I put in the spec’d amount, no more, and AVOID looking at the dipstick. Drive a week, then check (first thing in the morning), and it’s invariably just a tad below top mark.
    If I check right after filling (with a minute or two run time to fill the filter), it tends to read somewhat low. If I yield to the temptation to “top up”, I end up overfilled.
    #16 Mendel Leisk, Aug 14, 2021
  20. dolj
    dolj Senior Member
    8,209
    4,180
    Agreed. I have observed the same.
