Filthy door gutter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ukulelegeek, Nov 3, 2022.
  1. ukulelegeek
    ukulelegeek Active Member
    152
    104
    We have to park our Gen 3 Prius under a very trashy oak tree. The rear door hatch gutter keeps getting full of leaves and sticks. I have a mess to clean up once a month, and if that drips down on the carpet, well...
    Does anyone have a solution, short of chopping down our neighbor's tree?
    mikey_t likes this.
  2. ASRDogman
    ASRDogman Senior Member
    6,063
    3,256
    You can chop down the part that is over your property.
    The property line goes up also. (y):whistle:
    xliderider likes this.
  3. mikey_t
    mikey_t Active Member
    370
    391
    Los Angeles
    I park under some trees in my spot behind my apartment and have the same issue. I also get a lot of debris in the upper right of the engine bay, it's just an empty space practically designed to be a nest, and the gutters next to the rear lights. Currently they're both literally full of leaves and tree stuff. Really annoying.
    ukulelegeek likes this.
  4. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    In my experience, rainwater will pool in the compartment around the 12-volt battery when that drainage path clogs with "tree stuff" where it runs between the taillight and the body. The solution is to take the taillight off to remove the debris.
    Grit likes this.
  5. PriusCamper
    PriusCamper Senior Member
    11,065
    4,504
    Pacific Northwest, USA
    Lol, I live in the PNW where you can grow a hundred foot tall tree in only 50 years... So if you think tree debris is a challenge in the SE, you oughta see what our trees do year round, especially during pollen season!
    Point being a mature tree can provide enough oxygen for two humans to survive for an entire year. If you can't value that and you don't wash your car more often than once a month, that's on you, not on the tree!
  6. mikey_t
    370
    391
    Los Angeles
    I was gonna take care of it next week. Is it difficult to remove the tail light?
  7. ASRDogman
    6,063
    3,256
    Buy a cheap car cover.
  8. ukulelegeek
    152
    104
    I've owned a car cover. It wasn't the answer. There aren't many things more inconvenient than removing a wet car cover full of soaking wet leaves. One day, I walked out the door to find that the car cover had blown off overnight, and was lying in someone else's yard, nicely wrapped around a birdbath. We don't have the funds right now for a carport. This side of the tree will be trimmed soon. We use a Certified Arborist.
    mikey_t and CR94 like this.
  9. ukulelegeek
    152
    104
    I've never removed a taillight.
    Gen 2
    Gen 3
    Mendel Leisk and mikey_t like this.
  10. bisco
    49,397
    a magnetic strip over the gutter?
  11. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    You shouldn't need to do it unless the drainage path behind the taillight is clogged to the extent of causing water to run inside the car. On the right side, that water shows up as a puddle around the 12-volt battery. I'm not sure how corresponding leakage would show up on the left side, because water drains mostly to the right where I normally park.
  12. mikey_t
    370
    391
    Los Angeles
    Lol, the bumper needs to be removed? I'll just try my best with a pipe cleaner to get as much out as I can. Thanks for posting the video link though, much appreciated.
    ukulelegeek and Mendel Leisk like this.
  13. Mendel Leisk
    38,653
    Hey, at least he didn't need to remove the dash.
    mikey_t and ukulelegeek like this.
