Final results on MPG vs Tire Pressure on G3
Discussion in 'Gen 3 Prius Fuel Economy' started by Glider, Aug 25, 2009.
  1. Glider
    Glider New Member
    135
    30
    Memphis
    I wanted to tie some loose ends together on the controlled measurements I did of MPG vs tire pressure on the G3. Based on the number of time various files were opened, it seems that people have checked the earlier (incomplete) results much more than the final results in my other thread on this. Because of the confusion from the multiple files attached at different places, I am re-posting the final results here and adding a few comments.
    First, you will absolutely get better mileage at higher pressure, but not as much as many people are reporting (at least, not on the OEM Avid S33 15" tires).
    Second thing, there are three graphs listed at different speeds. I have no reason to believe there is a significant difference in MPG increase with PSI for the speeds I used, so use the TOTAL (last) graph which has all the data combined. That graph has a straight line fit and a curve fit. I recommend the curve, althought there is not much difference.
    Finally, here's an example (use your own numbers) of how to use it. Suppose I have 30 PSI (average of front and back) in my car (set by the dealership for a comfy ride - like I got) and I am willing to go to 46 PSI. At 30 PSI, you read 61.2 MPG and at 46 you get 62.7 MPG. That's a difference of 1 1/2 MPG - and that is what you should get on average. If you were getting 58.5 MPG, you should go very close to 60 MPG on average.
    Suppose your number is less, say 1 MPG improvement. Is it worth it? That's up to you. When you combine that with every other known technique (for example, slow down 2 mph and pick up another 2 MPG or whatever), raise the A/C a few degrees or turn it off when you don't really need it, etc. It all adds up to a major improvement in fuel efficiency beyond the great performance the car already has!!!
    Happy motoring!!
    5 people like this.
  2. MikeDS
    MikeDS Member
    298
    Los Angeles
    Cool! So what PSI are you running now?
  3. Glider
    Glider New Member
    135
    30
    Memphis
    I'm at 46/44. I think I'll sit tight (no pun intended) for a month or so - make sure everything feels good. Then I'm looking to head to 56/54. That worked fine during all the test runs, but they were only for a few hours each.
    Anybody who runs over sidewall max (sounds like a car accident in NYC) want to give us the benefit of your experience: handling, comfort and MPG?
  4. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    I think your going to find there is a point of diminishing returns. I think it's going to be similar to this, 30 to 40 psi = 1.5 MPG, 40 to 50 psi = additional .5 MPG, 50 to 60 = no appreciable difference.
    Don't quote those numbers, I just made them up, but I think the curve will be something similar.
    In other words, I think you have achieved almost all of the additional mileage your going to get by tire pressure. I think really light weight wheels and light weight, low rolling resistance, narrow tires would be the next step. Probably take 1000 years to recoup the investment though. I appreciate your work, I knew there was an increase in mileage, I thank you for quantifying it.
  5. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Great well thought out post!
    Does anyone know the highest pressure allowed?
    On the big plus side is tire wear - I bet at 50 you'll increase the life by 50%.....
  6. Glider
    Glider New Member
    135
    30
    Memphis
    Yes and thanks. Your idea about diminishing returns is right on, and so folks have the #s (the gains actually don't fall off quite so fast):
    Original PSI.....New PSI...MPG Gain...Cum. MPG Gain
    ...30.................40...........1.00..........1.00
    ...40.................50...........0.75..........1.75
    ...50.................60...........0.45..........2.20
    There is huge confusion about the "highest pressure allowed". The max sidewall pressure does not mean that exceeding it - within reason !! - places an uncompromised tire in danger of bursting. It means that you cannot safely carry a load higher than the max load by simply increasing the tire pressure beyond the max pressure. This is so misunderstood that Edmunds calls it one the TOP 10 AUTOMOTIVE MECHANICAL MYTHS (Why do they list 12??)
    "10 Automotive Myths and Misconceptions " Edmunds Daily
    (click where is says..... "click here" <-- yes, I overlooked that myself first time - ha ha )
    Other people same the same thing. HOW MUCH OVER MAX?? You can't get anyone to quote this officially (liability issues), but unofficially I have heard that 25-50% over Pmax is fine (burst is around 300% over Pmax) for an uncompromised car tire. For a 44 PSI Pmax, that would be 55-66 PSI. But it is your call to make for your car. Don't do anything you are not comfortable with, right?
    The word from longtime high-pressure folks is that tire life goes way up and there is no extra wear in the middle for SBR tires (unlike older bias tires)
    Good luck!
    4 people like this.
  7. dogllama
    dogllama New Member
    118
    Los Angeles
    I finally looked into my tire pressure after getting consistent 48 mpg tanks while employing various hyper-miling techniques to maximize MPG.
    My pressure coming from the dealer was around 33 psi for each wheel. I bumped it up to 46/44 and wow what a difference.
    I am now getting a consistent 52 mpg and I actually like the stiffer feel.
    I drive in LA with a lot of stop and go which makes me wonder if a higher PSI helps more in a stop and go scenario vrs long runs. I'm no expert, but maybe the force it takes to turn the wheel off the line is what was dragging my mpg down so much?
  8. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    Very good, thank you, but the hit on MPG was much less than I suspected. I'm amazed that the difference between 30 and 50 PSI is less than 2 MPG on average.
  9. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Based on what i"ve read, there is roughly 1mpg difference for every 10 extra lbs of air in the tire.
    Realizing that tires are the very first level of suspension, I prefer about 40 - 44 psi.... any more than that the ride becomes stiff and less luxury feel as if I have a cheap suspension and can feel every rock and bump on the road... plus there is always the risk of rupture if you hit something of significance.
    I hit the edge of the blacktop once where it had broken off pieces an it caused a blowout... that was running 60psi. At that point I realized how dangerous that was and stopped it for my families sake.
    A cheaper and-or softer tire seems to tolerate higher pressures better, but the more expensive higher mileage tires that have harder rubber dont fare so well without ruining the ride.
    Some tires just wont run the higher pressures without wandering all over the road... especially if they are new.. it feels like your running on tread instead of tires.
    I agree with the curve of diminishing returns...... the risks, are not worth the benefit.
    But the biggest thing that needs to be accounted for in a thread like this is whether they are running the 17" vs. 15" wheels or not.
    Unless all the contestants are running the same size wheels within a few mm, its tough to rule out benefits of air pressure differences as its fairly common knowledge the 17" wheels deliver a near 3mpg hit vs the 15".
    2 people like this.
  10. Glider
    Glider New Member
    135
    30
    Memphis
    It's great that you picked up 4 MPG. Probably some of that is coming from something other than tire pressure - maybe car break-in, better driving, etc.
    Yeh, I expected more too, but we have to take what we get. Stated more positively, "every little bit helps"
    Yep, 0.1 MPG/PSI is just about what I got, especially at the lower end of the curve. I've at 56/54 for 3 weeks and, to be honest, I'm not crazy about the transmission of bumps into the car. My FE has picked up by maybe 2 MPG.
    Regarding the blowout, are you sure you wouldn't have gotten one at max sidewall pressure (which is supposed to carry no risks)?
    Since you mentioned risks, and this is being hit pretty hard in another thread also, I have to say something about that. When I went (10 PSI) over max sidewall, I realized that my additional risks were minmal - maybe even negative - because I took another measure as well. I slowed down 5 MPH (from Speed Limit + 5, where I have driven for decades, to Speed Limit).
    I now think that all the risks: decreased stopping distance, skidding in turns, blowouts from impacts, etc. are probably better than they were under my old driving habits at MFGR suggested tire pressure.
    I will see how well I adjust to the harsher ride over the next few weeks. If not, I may come back down to 45 PSI or so (at the expense of 1/2 MPG)
  11. windstrings
    6,280
    378
    Central Texas
    I prob ran 30K miles before that happened. I expect I would have never had an issue if I hadn't hit something that caused an unusually high air pressure all at once.
    The other thing that scares me is the hot temps... I believe you gain about 1psi for every 10 degrees..... on a very hot day over 100 degrees, can you imagine how hot the tires must get on that pavement?
    Blowouts freak me out because if they happen, it could be anytime any place, and when you least expect it..... Lord help you if it happens on the front.... I just don't think its worth it.
    I was fearless until something happened totally out of my control without warning.
  12. bwilson4web
    16,012
    We sold our 2001 Echo with 30k miles in the spring. It had the original tires with deep treads in part because I kept the pressure up to max sidewall ... and no higher. This made the handling more precise but bumpier. But the new owner, a co-worker, is very happy with the car and sure enough, the Firestone folks said, 'Those tires sure are old ...' and he said, 'Yes, we like them ... they've been in the family for a long time. I'm going to pass them on to my son when he is old enough to drive.'
    Seriously, folks now have information they can use to do price-performance tradeoffs. I too have seen a defective tire with a 'bulge' from an impact or internal delamination. Stuff happens and I don't fault folks for being cautious ... as long as we're all working from similar sets of facts and data. <grins>
    Excellent study and great comments! I've really enjoyed this thread.
  13. a64pilot
    771
    62
    Albany Ga.
    Blowouts on the front are easier to deal with than the ones on the back. The reason is you can correct for the pull on the front because the front axle steers. Have one on the back and all you can do is counter steer to keep it under control. But I agree with you, I can do without the excitement. I've only had a couple of blowouts in my life and they were really non events. maybe I was just lucky.
    I have never seen a blowout from an overinflated tire, all of them I have knowledge of come from under inflation and the excess heat that comes from that. Ever been around mobile homes when they are being moved? That's one blowout after another.
  14. windstrings
    6,280
    378
    Central Texas
    I"ve never had a front blowout, but I would think the ability to "steer" out of it is negated by the blowout itself, I would rather be in a position of correcting.... especially in a front wheel drive car.
  15. dogllama
    dogllama New Member
    118
    Los Angeles
    The change in MPG was immediate. I had been really pushing at 33 psi to get 48, but the 52 came easily right after I bumped them up. The 48mpg was derived off 2 450 mile tanks, and the 52 has stayed consistant so far in my current fill up at 100 miles in. I drive the same stop and go traffic everyday so nothing besides PSI and 1 tank fill, nothing has changed.
    The large (~4mpg) increase seems to be well above average which is why I was thinking that a higher PSI would do more for MPG in a stop and go scenario.
  16. Glider
    Glider New Member
    135
    30
    Memphis
    Thanks - and care to divulge current PSI in your Prius??
    Yes, blow outs are bad, but what about that question of "Which is more dangerous, front or rear?" Well, you can find many proponents of both theories, but it's nice to have quantitative data, so I found this publication:
    Tire Blow-outs and Motorway Accidents. Martin JL, Laumon B, French National Institute for Transport and Safety Research (INRETS), Bron, France. During the period from 1996 to 2002, 60,397 vehicles were involved in crashes with property damage and/or injury on a French motorway network of 2000 km. It was observed that 6.7% of these accidents involved tire blow-outs…. However, two main facts require examination: (1) On inter-urban motorways, crashes involving blow-outs of rear tires occur four times more frequently than for blow-outs of front tires. (2) The frequency of tire blow-outs is especially high for vans, and almost always involves rear tires. This higher frequency for rear tires is the result of two phenomena, which are indistinguishable given the data available: firstly, a four-wheel vehicle is more difficult to control if a blow-out occurs on a rear tire (confirmed experimentally); secondly, rear tires may be in poor condition more often than front tires, and so more prone to blow-outs. Consequently, users are strongly recommended to install the best tires on rear wheels…
    SURPRISED??? For years they have been telling us to install (two) new tires on the front wheels!
    I didn't read your last sentence, sorry. Maybe there is a difference and a bigger effect for stop and go traffic. Certainly possible. Anyone know anything about that?
  17. bwilson4web
    16,012
    No problem:
    • Sumitomo T4s - 52 psi, maximum sidewall 52 psi
    • OEM tires on 2010 - 44 psi, maximum sidewall 44 psi
    I'm using 50 psi pressure indicator caps on the Sumitomo tires to detect any loss of pressure. The 2010 Prius, tire pressure system has been reset to reflect the new pressure.
    I don't see any problem with keeping the tire pressure at the maximum sidewall. This preserves the tire warranty and avoids going into operational regions where I don't have instrumentation to see what is going on. But once the tires begin to reach end-of-life, I have no problem with trying higher pressures.
  18. windstrings
    6,280
    378
    Central Texas
    That report is surprising.. especially since most of the weight is up front on most vehicles with the engine.
    Well One things for sure.. I hope I never have another blowout.... they are not real fun... .fortunately, I was only going about 40 when I had mine.
    You basically have an instantaneous flat tire.
  19. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    It's not as bad as it seems. The higher your pressure at the start, the less the pressure increases from driving.
    Also, feel your tires after along freeway drive on a hot day, they will be warm but not shockingly so.
    Back in the bad old days of bias ply tires, a long highway run on a hot day would get a tire too hot to hold your hand on it. Properly inflated radials don't heat up anythng like that and they will be much cooler than the road surface on a hot sunny day because of the air blowing over them.
  20. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Rolling resistance is a higher percentage of total drag at low speeds than it is at high speeds, so the percentage effect on MPG will be higher at low speeds.
