Finally found the ideal "pinch weld" jacking block
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Georgina Rudkus, Dec 5, 2018.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,173
    2,213
    Taylors, SC
    My husband's friend has the Quick Jack and these blocks.
    QuickJack Pinch-Weld Rubber Block Set
    I liked them so much when I saw them used, that I ordered a pair for my husband as a birthday gift. They also work perfectly with our Harbor Freight aluminum racing jack.
    They are close to those impossible to find mysterious ones mentioned in the Toyota factory manuals.
    #1 Georgina Rudkus, Dec 5, 2018
    Mendel Leisk and mjoo like this.
  2. Mendel Leisk
    38,730
    I used the supplied scissor jack once, at the (lighter) rear proscribed jacking point. I observed the slot on the scissor jack is deep enough that the weld-seam doesn't "bottom out" in it, only gets lateral support. It bears on the sheet metal behind,d and a single use dimpled it in a bit. :(
    I prefer to raise either the full front (or rear) with the central jacking points. Then put safety stands (with conventional cradles) at the flagged points. both the front and rear zones are heavier gauge, reinforced.
    I can see using something like the linked pads if I wanted to raise one corner with the floor jack, but I never seem to be doing that.
    #2 Mendel Leisk, Dec 5, 2018
    Raytheeagle likes this.
  3. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
  4. VFerdman
    VFerdman Senior Member
    1,152
    1,177
    Western Massachusetts
    Looks like something one can make out of scrap wood in about 5 minutes using a table saw or 15 minutes using a hand saw. I never use blocks. I just lift at the jacking points and support the corner I lifted with a jack stand where the subframe attaches to the body. Been doing that for the past 35 years or so. This Prius is no different.
  5. Georgina Rudkus
    3,173
    2,213
    Taylors, SC
    The above photo is from a Toyota jacking manual.
    I tried both of these. They are too hard and bottoms out so only the small "knife edge" of the pinch weld and any side motion would likely bend the metal of the pinch weld.
    To remedy the situation, I milled the slot a quarter inch deeper. Still the hard edge of the slot's top corners land on the rocker panel's sheet metal not reinforced. Still, two lines was better than one.
    Quick Jack is a subsidy of Bend Pak and has many years of experience with making car lifts. The rubber-urethane compound used to make their blocks is of a Shore durometer hardness that is stiff enough to support the car rails, yet is soft enough to deform to conform to the "knife edge" and cushion the sheet metal line on each side of the pinch weld. Each block then, supports rails on three lines or strips of contact.
    Bay Stater and Mendel Leisk like this.
  6. Georgina Rudkus
    3,173
    2,213
    Taylors, SC
  7. Georgina Rudkus
    3,173
    2,213
    Taylors, SC
  8. Georgina Rudkus
    3,173
    2,213
    Taylors, SC
  9. Mendel Leisk
    38,730
    If you (for example) just raise the front,, the pinchwelds are all the more precarious. I did that once, the first oil change (of about 16 now), didn't like how it was behaving. Here's a shot of my preferred front bearing points and the jack stands, location per the previous image. These are the main underbody rails, heavy gauge, and they go through a bit of a downward radius near the front end, so it's very easy to find a "flat spot" for the jack stand cradle, whether the front end is tilted up, or the car is raised and levelled:
    Another shot of the front points:
    I'll see if I can dig up a similar pic of where I put jack stands at the rear. Again, it's per the mark-up in the pic I posted above. It is very close to the rear pinch weld jacking point, just inboard, on a very heavy gauge hump of steel.
    #9 Mendel Leisk, Dec 6, 2018
  10. Leadfoot J. McCoalroller
    7,176
    6,724
    Pennsylvania
    2018 Prius c
    The block seems nice, my only complaint is that it is priced about the same as a 600 year supply of hockey pucks at my current burn rate.
  11. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    I too like pinch weld jacking pucks/ blocks.
    I made 4 out of 8 rubber hockey pucks.
    Bay Stater likes this.
  12. Mendel Leisk
    38,730
    I use a hockey puck (without a groove), to reduce my floor jack's travel on the rear/central jacking point.
    Sorry for being the troll of this thread, but I don't like jacking up flimsy cleaver edges.
  13. Georgina Rudkus
    3,173
    2,213
    Taylors, SC
    Here's a new photo I just got. My husband and our friend loves them. They find them useful on all pinch weld cars. pinch weld blocks.jpg
  14. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    looks good /
    but not $85.- good.... /
    RRxing and Raytheeagle like this.
  15. VFerdman
    1,152
    1,177
    It looks good enough to try and replicate from some wood scraps. Could you publish the dimensions? Those slots look about 3/4" wide or so. As I said, I never really worried about that and most cars I owned had pinch welds, but this looks like it could be useful.
  16. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    When I bought the ones I did from Amazon, I made sure the larger one fits into the place where the original jack pad was. The smaller one fits into the place where the original pad is in my smaller jack, but is smaller in diameter than the original pad on that one. I personally use the central lifting points like Mendel does and I originally placed jack stands where the pinch weld lifting spots are, but tried to avoid from having them carry a load. Then I purchased some sort of polyurethane jack stand slotted pads for the stands and pinch welds, but haven’t used them yet.
  17. Georgina Rudkus
    3,173
    2,213
    Taylors, SC
    Less than $25 each delivered isn't bad at all. They are larger than any of those off of Amazon. It's a quality molded made in USA product. I'm sold on them and glad we got them.
  18. Georgina Rudkus
    3,173
    2,213
    Taylors, SC
    Blocks are approximately 3x4x2-3/8 high. Slots are 3/8 wide x 5/8 deep. All dimensions are in inches. OJ pinch weld block dimensions.JPG
    VFerdman likes this.
  19. VFerdman
    1,152
    1,177
    Thank you, that's very helpful. I may create one and try it. As I said, I never felt the need for one, but maybe there is something I don't knot I didn't know...
  20. Mendel Leisk
    38,730
    More coffee, more coffee... :coffee::coffee::coffee:
    These blocks are intended to be used only in a floor jack cradle, not atop a safety stand? This is another deal-breaker for me: I'm never inclined to lift one corner with a floor jack; I'll do either a full front or rear lift.
