Finally - full system upgrade
Discussion in 'Gen 2 Prius Audio and Electronics' started by Justdidit, Apr 3, 2014.
  1. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    2007 non JBL, no Navi, with backup camera ..base system being removed. This is happening... now.
    Dino33ca likes this.
  2. tf4624
    tf4624 Active Member
    526
    51
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    After doing some research I went with the JBL GTO804
    Sonic Electronix - Compare Products
    For the location and sensitivity rating, it seemed to be the better choice. Plus it got raving reviews online for comparable priced 8" subs.
  4. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
  5. tf4624
    526
    51
    The JL w3 will fit. And it's a "W" series which you know is top notch. Suggest getting that instead
  6. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    I agree the W3 gets a lot of hype but for the specs, the JBL beats out the JL...then again i only spent 1/3 the price of the JL also but if i'm unhappy, i can always upgrade.
    JBL GTO804 vs JL Audio 8W3V3-4
    Cone Material Polypropylene vs Mineral-filled poly
    Surround Material Rubber vs Rubber
    Ideal Sealed Box Volume (cubic feet) 0.3 vs 0.3
    Ideal Ported Box Volume (cubic feet) 0.6 vs 0.35
    Port diameter (inches) 2.5 vs 2
    Port length (inches) 8.8125 18
    Free-Air No vs No
    Dual Voice Coil No vs No
    Sensitivity 91 dB at 2.83 watts vs 83.24 dB at 1 watt
    Frequency Response 30 - 400 Hz vs 28 - 250 Hz
    RMS Power Range (Watts) 50-200 vs 50-250
    Peak Power Handling (Watts) 800 vs 500
    Top Mount Depth (inches) 4 3/8 vs 4 9/16
  7. tf4624
    526
    51
    When it comes to subs. JBl vs JL. Sorry JL w3 will win
    One can read all the specs you want, until you hear it and experience it, specs aren't enough to know
  8. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    where's the pix?
    jl's are fantastic, but in this small car 2 8" subs of any decent brand will be more than enough.
    you gonna shoe-horn those 8's into the rear doors?
  9. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    I was only able to install the Pioneer deck, MirrorLink, E-Brake bypass, 1 Polk amp and both sets of Infinity components installed last night. Gonna tackle the other amp and subs hopefully soon.
    I've decided to make an enclosure in the tray behind the battery. Got the amp mounted under the seats so they are completely out of the way. Looks really clean, other than the deck, You can't tell anything has been upgraded...fairly stealthy other than the 7" DVD screen.
    The upgrade in sound quality and power is ridiculous... Def worth the $$$$
  10. tf4624
    526
    51
    Final pictures yes ?
  11. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    (2) JBL GTO804 8" Installed into my custom sealed box. Still have access to my spare tire and jack. Used 12" speaker grills painted to match the trim. Used the oversized grills incase I want to upgrade the sub size later.
    Joebiscuit likes this.
  12. JC91006
    16,474
    8,393
    Can you put any weight on the grills? That's right in the center of the hatch space
  13. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    yep, made several runs to the airport this weekend with lots of luggage with no damage to the grills or any loss of sound quality.
    JC91006 likes this.
  14. JC91006
    16,474
    8,393
    I wanted to add a sub but didn't want to lose any space. This turned out really good....wanna do another? :LOL:
  15. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    I actually have another box already made.....just haven't carpeted it yet...made for 8s or 10s
  16. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    wow, i never thought of that idea, about placing the subs that way. i really like that! i might do that now. thanks!
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    Anyone interested?
  18. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
  19. kingnba6
    1,018
    242
    NY
    if i was local and had the same car, i would scoop it up! How come you are selling it?
  20. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    I'm moving and dont want to haul this one with me.
    I made two, the one I'm selling is the 1st one. This one was just never carpeted or had grills mounted. The difference between the two is the location of the subs. The below pictures shows my current setup, the subs are more center of the floor. The one I'm selling, the location of the subs is more toward the back of the car.
    Thats all the one I'm selling needs...carpet and some mesh grills...
    #20 Justdidit, Jan 26, 2015
