Finally, I've got a height adjustable driver's seat
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Solar_Powered, Aug 2, 2006.
  1. Solar_Powered
    Solar_Powered New Member
    38
    Cypress, Southern California
    Yes, I'm one of those tall drivers who has desired a lower driver's seat so you can see better (there has been many topics discussing this subject).
    Also, in the past, I posted the instructions "Move up the Rear-View Mirror for better forward vision"
    ( http://priuschat.com/index.php?showtopic=20285&hl=mirror )
    so you can see the "tall driver's syndome" runs strong in me!
    Finally, after a lot of research, thought, planning, a trip to Japan, and bit of sweat; you'll find the results of my quest as the attached .PDF.
    I hope this will be useful to others on PriusChat!
    12/16/2009: Yahoo is discontinuing its "briefcase" service, which is where I've kept my published Prius files, thus the files have been moved to:
    http://www.box.net/shared/9dc62z6acc
    raffpoz likes this.
  2. dmzach
    dmzach New Member
    <div class='quotetop'>QUOTE(Solar_Powered @ Aug 2 2006, 05:32 PM) [snapback]296623[/snapback]</div>
    Nice to know there's someone else out here who's even more obsessive about height comfort than me. :) Just to let the rest of you know, I sent a note to Speedware Motorsports regarding putting Recaro Trends into a 2006 Prius. He said he'd find out about seat measurements and available space and get back to me next week - I'll share with Priuschat what I find out. He was not aware of anyone putting the Trends into a Prius, though I think that I read on one of these boards about someone having done it.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Please post this in the article section for posterity. Good job, but holy cow!
  4. DavidTO
    DavidTO New Member
    102
    Great job. What a crying shame you had to do that at all, though, really.
    I've got my Prius on order, and at 6'1", I'm a bit concerned about this...
  5. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(dmzach @ Aug 2 2006, 04:54 PM) [snapback]296632[/snapback]</div>
    I can tell you already that they fit. I came REALLY close to putting them in... but decided on just adding lumbar and heat to the factory seats.
    Now... about lowering the things... WOW! You're my new hero. Man, there has just GOT to be an easier way though. Without knowing a thing about which I speak... it would seem that modifying the Japan factory seat left-to-right would be an easier task??? Who knows. I just know that I want mine lower! Thanks tons for sharing.
  6. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(Solar_Powered @ Aug 2 2006, 06:32 PM) [snapback]296623[/snapback]</div>
    Man, that is useful to all of us here. It is like gold. Only now that there is a solution, I am going to have to way how bad I want it. Seems to me like a few weekends to do the project. Thank you though, I will copy the instructions to me hard drive.
    You did great!
    Toyota are you listening?
  7. NuShrike
    NuShrike Active Member
    1,378
    Is Japan the only country with this kind of seat? What about Europe.. You would figure if this seat was there, just grab the German one stock, for instance...
  8. naterprius
    naterprius Senior Member
    1,843
    Solar, does the seat sit any further back now that you are done?
    Nate
  9. Tideland Prius
    16,126
    <div class='quotetop'>QUOTE(NuShrike @ Aug 2 2006, 09:57 PM) [snapback]296794[/snapback]</div>
    Australia has it although I believe it's RHD too.
  10. KMO
    KMO Senior Member
    1,511
    385
    Finland
    2023 Prius Prime
    These seats are standard in all of Europe, so it would have been a lot easier just to ship a replacement from a German dealer. Possibly more expensive though.
  11. nyprius
    nyprius Member
    385
    24
    Saratoga Springs, NY
    <div class='quotetop'>QUOTE(Solar_Powered @ Aug 2 2006, 07:32 PM) [snapback]296623[/snapback]</div>
    Thank you for this excellent post! I'm not sure I'd have the patience or ability to do all the work you've done. Having studied the seat extensively, do you think it would be possible to drill lower holes in the four pieces of metal extending up from the seat rails that hold the seat in place? It appears I could do this then bolt the seat at a lower position. If I sold the car, I could return it to normal. What do you think?
    Also, it would be great to know if it's possible to get a height adjustable LHD seat from Europe and what it wold cost? Toyota ought to start making these available for US Prius's. Providing these seats for free or at a nominal cost would partly make up for the mistake of not providing height adjustable seats in the US, as they are provided in Japan and Europe.
  12. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    WOW! ...... I am completely speechless and in total awe. :eek:
  13. Solar_Powered
    38
    darelldd asked, "it would seem that modifying the Japan factory seat left-to-right would be an easier task?"
    The "pump handle" height adjustable mechanism (and many of the other seat related assemblies) are fabricated using large flat rivets. These rivets are also very low profile, often so the heads can clear other parts of the assembly. As rivets of this size are typically assembled in a multi-ton press, it would be difficult to find a fastener of equivalent size and strength to replace them. I'd estimate a left-to-right swap of the mechanism would be actually more difficult than the seat retrofit I did.
    naterprius asked, "does the seat sit any further back now that you are done?"
    No, the retrofitted height-adjustable seat mounts exactly to the floor as the original Prius seat, so there is no additional leg room as a side benefit.
    nyprius asked, "Having studied the seat extensively, do you think it would be possible to drill lower holes in the four pieces of metal extending up from the seat rails that hold the seat in place?"
    Actually, that was my original plan. But on close examination of the complexity of the rear mounting structures, I abandoned that plan. Additionally, as my wife is about 1 foot in height shorter than I am, I was highly motivated to focus my attention on the height-adjustable solution so we both could drive the Prius comfortably.
    Many have also mentioned that purchasing a Prius seat from Germany might also be a good solution; I agree. Hopefully a German based "Prius Chatter" can answer the question, "Does a Prius in Germany come equipped with a factory height-adjustable seat? And, "How much does such a seat cost as an aftermarket item?
  14. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(Solar_Powered @ Aug 3 2006, 02:13 PM) [snapback]297088[/snapback]</div>
    Thanks! Clearly the fix I was suggesting wouldn't work if there were two drivers of different heights. I'm the only driver of my car. If someone short needed to drive it, I'd give them a pillow.
    Can you say more about the rear mounting structure? As far as I could tell, there seemed to be four triangular pieces of metal coming up from runners in the seat rails. The points of the triangles were at the top. There was a hole through each triangle near the top, to which the seat was bolted. The metal was partly bent for stength, but that didn't seem to preclude drilling a lower hole to which the seat could be mounted, possibly with longer bolts if necessary. What was it about the rear supporting plates that made this seem not viable?
  15. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    In the end, how much lower would you say the seat can go? (Front/rear)
  16. Solar_Powered
    38
    nyprius asked, "Can you say more about the rear mounting structure? As far as I could tell, there seemed to be four triangular pieces of metal coming up from runners in the seat rails. The points of the triangles were at the top. There was a hole through each triangle near the top, to which the seat was bolted. The metal was partly bent for strength, but that didn't seem to preclude drilling a lower hole to which the seat could be mounted, possibly with longer bolts if necessary. What was it about the rear supporting plates that made this seem not viable?"
    Nyprius, you need to spend a lot more time taking your Prius apart! :)
    If you look at the attached .JPG of the rear mounting structure, I've added red lines where the support bracket is hidden by the other structure.
    Let's say we want to pull out the lower two bolts, and drill two new holes higher up in the support bracket; the lower bracket will interfere with the seat sliding rail. OK, let's say we want to drill out the upper rivet and remove the about 18" long "rivet pin" that passes through the tubular brace, and drill two new holes higher up in the side structure of the seat; the resultant lowering can only be about 1/2" before the support bracket interferes with the beige plastic trim piece.
    My conclusion (and you can draw any conclusion you want to) is that the only way to make a permamently lowered seat is to remove a "strip" of steel from the support bracket, effectivelty shortening it, and re-welding the bracket back together.
  17. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(Solar_Powered @ Aug 3 2006, 08:51 PM) [snapback]297400[/snapback]</div>
    Thanks again Solar_Powered! This is excellent info! I was looking under the seat while it was in the car. So I couldn't see exactly what was going on. Your picture helps a lot. Even lowering the seat a 1/2" would make a noticable improvement I think. If I wanted to lower the seat an inch, the ideal amount for me, it seems I could trim or file off some of support bracket. I'm pretty sure the supports are meant to shear off in a severe accident. I'm concerned that welding might limit the ability to shear. Of course, what I'm suggesting might affect shearing as well, but probably not as much.
    Your pictures shows the bracket bolted on the bottom but riveted on the top. I can't see the other side of the rivet. Do you know if it's bolted or riveted on the other side? It looks like it might be difficult to drill out the rivet. So I was hoping the rivet is a fixed post with a bolt on the other side.
  18. Sho-Bud
    Sho-Bud Member
    190
    Amsterdam, Netherlands
    In The Netherlands, all Priusses have the height adjustable driver seat.
    I called the parts department of the dealer.
    The chair consists of loose components which can be bought seperately.
  19. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(Sho-Bud @ Aug 4 2006, 03:23 AM) [snapback]297543[/snapback]</div>
    Thanks Sho-Bud! Do you know what the whole seat would cost in tan fabric? Alternatively, could you provide a website or phone number where I could get this info?
    I had the seat rails extended on my Prius so it slides back three inches further, providing a lot more leg room. I assume I could take the rails off the old seat and put it on the new one. Though, I'd have to check if the height adjustable and non-height adjustable seats have the same rails.
    Toyota should make this seat available in the US. US Prius owners shouldn't have to deal with the cost of shipping it in from Europe. Also, I wonder if the seat would make it through customs. Or does it need USDOT approval before being used in the US.
    This is as much a safety as a comfort issue. My visibility is significantly restricted out of the front and rear windshields because I sit too high in the car. This means not providing seat height adjustment, as it is provided in Japan and Europe, increases the chance of having an accident, as well as substantially decreases driver comfort. For the safety and comfort of their loyal customers, Toyota ought to make it easy for US Prius owners to replace their driver's seats with ones that have height adjustment.
  20. Solar_Powered
    38
    <div class='quotetop'>QUOTE(grasshopper @ Aug 3 2006, 04:18 PM) [snapback]297225[/snapback]</div>
    The rear of the seat (i.e. headroom) moves down about 2 inches lower than the original Prius seat, and the front of the seat (i.e. thighs) moves down about 1-1/4 inches.
