Finally replaced my 8.5 year old 12V battery! Non AGM???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by uart, Jun 15, 2013.
  1. uart
    uart Senior Member
    4,215
    1,201
    Australia
    I've been watching my 12V battery fairly closely over the past few months, trying to go for a record for how long the little oem battery could last. But alas it couldn't make it through (southern hemi) winter and started going down-hill really quickly over the last few days. It's was hitting as low as 10.5 volts in the ig-on test, and I actually saw it transiently dip as low as 9.6 volts during boot up. Yikes!
    So yesterday I had to change it out pretty quickly as my wife needs it to be reliable for a trip next week. Didn't have time to order anything online so it was either the Toyota OEM (about $350 here) or take a punt with whatever the local battery place had that would fit. It turned out they had one for a third the price of the Toyota one, except it wasn't AGM! It is however fully sealed and maintenance free, it is a low self discharge calcium type, and it does have the attachment for vent tube. The guy there assured me that it meets all required standards for mounting inside the cabin space, so I decided to give it a try.
    Here's a pic of my new el cheapo. The picture doesn't show any reference to see it, but it's tiny! Literally about half the weight if the OEM battery I removed. The rating is still 35AH and 330CCA, so it should do the job.
    DogDaze, m.wynn and JMD like this.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    So long as you are never in an accident, you are fine.
    An AGM battery has much less sulfuric acid to throw around the passenger cabin in an accident.
    (many batteries would work electrically in a Prius, wanting an AGM battery that is externally vented is all about protecting humans from the battery if things go wrong, as Toyota placed it in the passenger compartment with you and your passengers)
    DogDaze likes this.
  3. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Hi Jimbo. This battery is well sealed and is supposedly designed for this application. It has the facility for the vent tube (which I have attached). It's a very lightweight battery and very firmly secured, so I think it will be ok.
    DogDaze likes this.
  4. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    It will probably be fine but I think I would have gone for a mobility AGM battery, even if it doesn't have the vent tube. But going alternative to the overpriced OEM is a direction I would like to see more as competition is good for the end user.
    DogDaze likes this.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Both the Prius I have owned had the battery within 2 inches of the back bumper. Try not to be hit from behind. That would break open the case and give the contents forward momentum.
    DogDaze likes this.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I found a 2011 Australian AC Delco Catalog
    ACDelco Batteries Catalogue-1
    On page 39, it lists two batteries as being for the Toyota Prius
    Low Maintenance Accessible NS40ZLWC or Sealed Maintenance Free S40B20L
    DogDaze likes this.
  7. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Yeah that's the one Jimbo, the S40B20L. It's a tiny battery. Feels like it's only about 10kg, and it's got a built in hydrometer (sited though a little window in the top).
    Yeah if it gets hit hard enough in the rear to split the battery case then the OEM battery would also split. But the acid in the OEM would leak more slowly.
    DogDaze likes this.
  8. Mike500
    Mike500 Senior Member
    2,593
    764
    I would say you're just fine. What makes the OEM battery more shatter resistance or less frangible than the one you got. Acid is not the major problem with a battery. If the car is hit hard enough for it to leak acid, who cares if the steel in the right rear behind the wheel well starts to rust. Corrosion of that area to eat through the metal might take a couple of years.
    The battery is vented and the battery compartment is vented for only one reason. That's to release hydrogen that might be built up in that area. Heard about D-LZ 129, also known as the German Airship Hindenburg?
    DogDaze and uart like this.
  9. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Thanks Mike. :) Yeah the battery is very sturdy. Jimbo's point however is that if the AGM battery ruptures then the acid will leak relatively slowly compared with a traditional battery. In any case though, I think that any acid would be contained there in the wheel well.
    I wasn't going to compromise on the vent though. I did have to very slightly modify the vent tube to accommodate this battery, which was easy enough, though I wasn't really expecting to have to do this given that the Acdelco catalogue listed it as a suitable replacement for the Prius.
    For those interested in measured voltages, this battery measured 12.5 volts out of the proverbial box. I assumed that it might have been sitting for a while so I gave it a light charge and it settled to about 12.7 to 12.8 volts a few hours after charging.
    Once installed in the car I got the following readings on the MFD using the "acc/ig-on/ready test" (each measurement taken after giving it about 10 seconds to stabilize) .
    Access: 12.5 Volts
    Ig-On: 12.2 Volts
    Ready: 14.0 Volts
    BTW. I repeated the test two consecutive days with identical results.
    DogDaze, dorunron and Mike500 like this.
  10. Mike500
    2,593
    764
    Thanks for the info. A few years down the road, when I have to replace mine, I'm going you route. The vent isn't really necessary, anyway. The OEM battery vents into the compartment. The vents in this compartment draw the air (including hydrogen) out of them as the car travels down the road. If you're a worry wart, just route the vent tube out the vents in the compartment.
    Great find!
    DogDaze likes this.
  11. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    A great find if you live in Australia. I couldn't find this battery in the U.S.
    uart: was the AC Delco battery equipped with JIS terminals or did you need to buy them separately?
    DogDaze likes this.
  12. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    This battery along with many others of it's type is available in the UK. The possibility of acid splash in an accident is there but only remotely and would not put me off using one but this is a decision only an owner can make.
    When I was working and had company cars "usually estates or hatchbacks". It was against company rules to carry ladders,steps, or any long solid object inside of the vehicles because one driver was injured by the item he was carrying in a rear end accident. Something no doubt we have all done at some time. It was also required that all loads however small were fastened down with a safety net. There are risks in everything we do.
    John (Britprius)
    DogDaze, JMD and uart like this.
  13. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Yes jadziaman, it came with the small JIS terminals and was a perfect fit. I didn't measure it exactly, but it's about the same height and width as the OEM battery but is a lot shorter (in the terminal to terminal direction). The positive post lined up perfectly with the positive clamp assembly, and so the negative post had a bit of extra clearance from the rear of the hatch compared to the OEM part. However the pigtail (-ive strap wire) still reached easily. Also, the metal hold-down piece that goes over the top fitted nicely across, about at the centre of the battery, so physically it fits in very neatly.
    The only thing that was a bit awkward was the vent hole. I didn't realize until I got it home, but it was ambidextrous, with a vent hole at each end of the battery. It's similar to the oem battery in that there's a rectangular cavity above the cell vents, fully sealed off in this one, except for a small vent hole at each end. The holes are baffled between the exterior and this internal cavity, presumably to prevent acid escaping through the vents. So I had to place a small plug in the vent hole at the negative end, which isn't used. (I just used a small bolt I had lying around, wrapped in plumbers tape to make it snug fit when threaded in).
    DogDaze likes this.
  14. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Yeah there's a risk in everything. Actually there's a small safety advantage in this battery (and other light weight replacements), to offset that risk. Given the very light weight, for any given accident g-force it's much less likely to break free and become a projectile. It's almost half the weight of the OEM battery, lighter even than the optima yellow top.
    DogDaze likes this.
  15. wintechsw
    wintechsw Junior Member
    36
    Vic Australia
    Looks like I'm in need of a new 12v battery also, how is this replacement going, any problems, experiences etc?
    TIA
    DogDaze likes this.
  16. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Hi wintechsw. Not much to report at this stage except that everything is working perfectly. :)
    I was going to update this thread with the voltage measurements after it's been in the car (in regular operation) for about two weeks. Since it had been on an external charger prior to the previous measurements the voltages may be a little bit different now that it's just in regular service.
    So I'll update here with more info in a few days time, and if I get a chance I'll try to post a picture or two of how I had to modify the vent tube.
    DogDaze and JMD like this.
  17. uart
    uart Senior Member
    4,215
    1,201
    Australia
    I thought I'd update this thread now that the new battery has been in a couple of months.
    I redid the voltage measurements now that it's just been driven normally for about 8 weeks (with no external charging). Measurements taken after the Prius has been left overnight without driving.
    1. Voltmeter measurement directly at the fuse box jump point: 12.50 volts.
    2. Diagnostic mode MFD measurement, accessory mode: 12.3 volts.
    3. Diagnostic mode MFD measurement, ignition-on mode: 12.1 volts.
    4. Diagnostic mode MFD measurement, ready mode: 14.0 volts.
    I know that some people will say that these voltages (particularly the mfd measured) are a bit low, but in my experience they are 100% normal. For the many years that my previous battery work perfectly (before it started to weaken) it always returned *exactly* the same voltage measurements as this.
    DogDaze and m.wynn like this.
  18. uart
    uart Senior Member
    4,215
    1,201
    Australia
    I had to access the spare wheel on the weekend, so while I was there I decided to take a few photos of how then new battery fits.
    1. The first photo shows the general fit. The height and width and terminal sizes are the same as the OEM, so you can see that it fits nicely. The new battery is a fair bit shorter than the OEM but that doesn't seem to hurt anything.
    BTW. All that brown crap isn't corrosion. It's corrosion inhibitor that I sprayed in there a couple of years ago when I thought some acid might have gotten in there (trying to add water to the old battery).
    2. Here I've annotated the minor modifications that were needed to connect the vent tube with this non-oem part.
    DogDaze likes this.
  19. Stormz
    Stormz Member
    105
    Perth, Australia
    Went to Auto-1 today and bought a sealed maintenance free battery for $135. It doesn't have the vent hole though but the guy assured me no gases are created unless you put a battery charger on it.
    DogDaze likes this.
  20. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    ...the ACDelco option sounds like a very good option for down under. I wonder though if Toyota designed Prius for this type of battery what design mods (if any) would be included (pan under battery? secondary containment?).
    DogDaze likes this.
