finding an ignition wire under the hood
Discussion in 'Gen 2 Prius Accessories & Modifications' started by peakfinder, Mar 16, 2007.
  1. peakfinder
    peakfinder New Member
    Hey folks,
    I looked carefully with search but could find no thread that would help me...
    I'm installing daytime running lights from Web Electrics in my 2007 Prius. To complete the installation I need to tap into an "ingnition on" (switched) wire under the hood. Can someone tell me how to find an accessible wire under the hood? by the way, they want a wire on at least a 15 amp circuit.
    Thanks in advance!
    Joe
  2. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    <div class='quotetop'>QUOTE(PeakFinder @ Mar 15 2007, 10:27 PM) [snapback]406615[/snapback]</div>
    Someone may have a better answer, but I would start by reviewing the Fuse Box information in the owners manual. Look for items that are located out in the front of the car that come on when the ignition is on, like maybe the radiator fan or something. May also check to see if there is a Relay Box under the hood, and what type of items are controlled by the relays. Each relay should have a corresponding fuse in the fuse box that might be 15 Amps or more.
  3. peakfinder
    Thanks so much for the suggestion. I have looked at the fuse box but I'm unsure how to gain access to underneath it where I can tap a wire.
    I really have given up on this thread--lot's of people reading but no responses. I'm surprised that there is little or no information on tapping an ignition wire under the hood.
    Joe
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    Why don't you just turn on your headlights and leave them on all the time?
  5. peakfinder
    <div class='quotetop'>QUOTE(Bill Merchant @ Mar 18 2007, 12:53 AM) [snapback]407764[/snapback]</div>
    Bill,
    I prefer the way the DTLs look, they are less annoying to other drivers, and besides, I have already purchased the DTL kit. It is quite simple to install--I just have to find where to tap into that ignition hot wire. :unsure:
    Joe
  6. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Peakfinder,
    You may not know, but the Canadian Prius' have a control that runs the headlights as daytime running lights, probably at reduced intensity, like Saturns do. Its probable this same control is in all the Prius', and just needs to be enabled in our US Prius, for non-HID cars. You might ask your dealership to ask Toyota about this.
  7. Syclone
    Syclone Member
    540
    Good news - S11 (smart key ECU connector) has all the voltages that you need. Bad news - I couldn't find the diagram in the service manual CD that shows where, exactly, S11 is located. I've attached a pin-out for S11. It's a PDF file.
    [attachmentid=6928]
  8. peakfinder
    <div class='quotetop'>QUOTE(syclone @ Mar 18 2007, 10:33 AM) [snapback]407874[/snapback]</div>
    Thanks for looking Syclone! I Will see if that plug matches up to anything I can find under the hood
    Joe
  9. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    I'm surprised no one has found a way to make the fog lights into DRLs by now. Any ideas?
  10. vinnysca
    vinnysca New Member
    200
    Here's my foglight as DRLs mod that I found in this site. Just do a search and type in fog light mod.
    Vince.
  11. NoMoShocks
    1,292
    82
    Camas, WA
    <div class='quotetop'>QUOTE(vinny @ Mar 18 2007, 03:46 PM) [snapback]408057[/snapback]</div>
    I like this idea, because I am not sure if it is real good to have my HID headlights on all day long. I bet they are expensive to replace at end of life.
  12. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    <_< PeakFinder couldn't have used the "Canadian" method, which runs the Halogen headlights at lower voltage for DRL. PeakFinder has the '07 Package 6 which includes HID headlights not adaptable to running at lower voltage. Seems if you really insist on DRL, the fog light modification is a workable solution.
    I shudder to anticipate replacement of HID headlight bulbs. I read they run around $250 for each bulb alone. The good news is that they should last a long time. I do like the broader light pattern on the HID's - better illumination on the peripheries - they show both the curbs and edges of the highways somewhat better than the Halogens I had on my 2004 Prius.
  13. irfanally
    irfanally New Member
    Pennsylvania
    Yes, I figured it out. There are TWO relay boxes. The easiest way to get to the ignition wire is to access the RELAY box located in the center of the firewall panel just below the wipers. It’s a small rectangular box which almost goes unnoticed. Remove the two bolts from the sides, pop open the cover and you will see 4 relay switches. The PURPLE wire connecting to the largest relay on the left hand side is the ignition wire. You can access it by flipping the relay box after popping out the base cover. I used a QUICK-SPLICE to connect the Yellow Modwire to this Purple wire which will supply the power to the bulbs. I also have added a switch that can engage or diengage DRL feature. You can email me if you need to do that too. I did this as I dont want my DRL on all the time. Just want the inspection to approve it when I import the vehicle into Canada and then turn it off. It drains your battery unless you decide to have a mod to replace the lights with LEDs. I can show you how!
    Regards
    Irfan
  14. pviebey
    pviebey New Member
    78
    Um. Isn't the cigarette lighter switched? Couldn't he just tap that?
  15. dapastaguy
    dapastaguy Junior Member
    45
    Sumter, SC
    My thought would be to find the fuse that comes on with the ignition, pull it, and place your driving light wire in the socket. Reinsert the fuse and you are good to go. No need to find a wire to tap.
  16. Qlara
    Qlara New Member
    488
    No, can't do that.
    The main fuse box under the hood is always 'hot' for all plugs.
    The center relay (from Irfan's post above) will be a better option to tap the ignition-controlled wire for juice.
