Finding Shops OTHER than Toyota for Service
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by qdllc, Mar 7, 2017.
  1. qdllc
    qdllc Senior Member
    1,370
    399
    Coming up on 50K. I know I probably should drain and fill the transaxle, inverter and coolant, but DIY might be more than I have time for. Anyone know how to find a shop that does good work on the Prius OTHER than a Toyota "stealership" or at least what's a reasonable cost for these services being done?
  2. qdllc
    qdllc Senior Member
    1,370
    399
    The local Toyota dealer has quoted the following prices....
    Coolant - Inverter drain and refill - $149.99
    Coolant - Engine drain and refill - $102.00 +/-
    Transaxle drain and refill - $149.99
    Brake system flush - $86.00 +/-
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    You do not list nor mention a location you are in.
    #3 JimboPalmer, Mar 7, 2017
  4. qdllc
    qdllc Senior Member
    1,370
    399
    It'd have to be fairly local. I'm in Bristol, VA, and the three closest Toyota shops are essentially under the same parent company.
    If the prices they quoted are reasonable, it might be easier to pay to have it done.
    Raytheeagle likes this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    What's you limit on distance? There is a good shop in Ashland, but that's a fair distance away.
    Also the prices quoted seem high, other than the brake fluid flush. With those prices, there must be a large monthly payment someone there has. I would look elsewhere or DIY.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    My local dealer, Kirk Toyota in Grenada MS, has done 3 transaxle drain and fills for me, 2 at $90, and one at $110. Obviously there is less overhead in MS than in VA.
  7. Mendel Leisk
    38,733
    The transaxle drain and fill is oddly high, makes me wonder if they know what's involved?? It is a simple drain and fill. Looking up my parts dept invoice from last time I DIY'd it, the supplies, including two ridiculously overpriced washers, was around $44 (Canadian). Labour is about the same as an oil change, say 1/2 hour, for pros with a lift. Anything up to $100 would be reasonable I guess.
  8. Currahee
    Currahee Member
    103
    33
    CT
    Those are all cheaper than my local dealers but similarly arbitrary. Like the inverter coolant being more expensive and than the engine and the trans fluid the most expensive despite being the simplest procedure. I think they just pick what the labor would be in the worst case scenario and use that as a flat fee for those services.
  9. NeilPeart
    NeilPeart Hybrid & PiP Convert
    75
    69
    Bay Area, CA (USA)
    I'm in the Bay Area and the dealers in San Jose and Sunnyvale charge a lot for service items. I found a local shop called TLS Autio that does great work. They performed the transaxle fluid change for $100 and while they had the car lifted they replaced all of the missing clips for free. I take my 2010 Prius there and will take my 2015 PiP once my free dealer service expires.
  10. bisco
    49,504
    those prices look decent, just take it there.
  11. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    You can do all of those for 100$ in parts...
    If you're going to spend that much on those services, you should just invest in Jacks and jack stands to do it yourself. It doesn't even take that long to do, take a day out of the weekend and you can do all of it in one session. There's even videos to show you how to do those jobs. I have 133k miles on my vehicle and all of the videos I posted on YouTube is what I've been doing only, and I've never had any major issues with the Prius.
    Going hours away for these services is pretty mind boggling:confused:
    Plus, dealerships will charge you 100$+ per hour, and if you're planning to take it to an independent shop, hopefully they are Prius certified or know what they're doing.
    Mendel Leisk and Raytheeagle like this.
  12. Currahee
    Currahee Member
    103
    33
    CT
    FWIW, I did both Gen 3 coolant loops without lifting the car although it would have been easier lifted. Just take down the front half of the splash shield and you can hold a pan under the inverter drain. The trans fluid you will definitely need a jack and four jack stands.
  13. Mendel Leisk
    38,733
    Or ramps in the front, and jackstands just 'round the back. But yeah, four jackstands is my MO. Ditto for tire rotations: just raise the whole car.
    Still, some people live in apartments, or just have street parking. It can get more difficult. If you're motivated there's always a way though. Just knowing someone with a concrete slab you're ok. With a roof over it and a power outlet: heaven.
  14. NutzAboutBolts
    1,476
    1,552
    Bay Area
    Or you can go to an empty parking lot and do it there :ROFLMAO::ROFLMAO::ROFLMAO:
    Raytheeagle and Mendel Leisk like this.
  15. Mendel Leisk
    38,733
    As long they have lax security, but yeah. It is nice have a garage.
    Raytheeagle and NutzAboutBolts like this.
  16. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Or a friend with a garage like when I had to replace a thermostat in 15°F weather and only had an outdoor gravel driveway.
  17. Lightning Racer
    Lightning Racer Active Member
    239
    320
    Anchorage, Alaska
    I can't believe no one else has pointed out that the first and third items are the same. They are on the same coolant loop! I pointed out the same thing in another thread a month or two ago, so I wonder how many dealerships are double charging for that. As Currahee mentioned without emphasis, there are two coolant loops.
  18. Mendel Leisk
    38,733
    No: one's coolant, the other's transaxle fluid. Brain bubble?
  19. qdllc
    qdllc Senior Member
    1,370
    399
    Well, after watching the videos, I'll do the fluids myself EXCEPT for the brake flush. Since you really need the software to have an easy time at it, it's worth the cost to let Toyota do it. Last thing I need is an error code I can't clear.
    bisco and Raytheeagle like this.
  20. Mendel Leisk
    38,733
    The brake fluid change without techstream is not that hard. Did you watch @NutzAboutBolts video on that. I did that recently, with my wife pushing the brake pedal. We watched the video multiple times, and I also read through the Repair Manual. Raise the whole car and take off all wheels makes it easier. Two pint bottles of Toyota DOT3 brake fluid were $8.50 per.
    Here's my high tech equipment:
    The sequence in Repair Manual, a little different than @NutzAboutBolts video, is FR, FL, RL, RR.
    #20 Mendel Leisk, Mar 8, 2017
