Finicky Bluetooth
Discussion in 'Prius v Technical Discussion' started by jonjacobmoon, Nov 10, 2011.
  1. jonjacobmoon
    jonjacobmoon New Member
    portland
    So far the bluetooth works okay, but at times, it is a little finicky and I am wondering if I am the only one having the issue.
    When I first connected via the bluetooth, it worked just as I thought it should. It found my contacts, downloaded them to the car system, and all was well.
    Now, it now only doesn't seem to find my contacts (although it will occasionally and randomly find one or two) it will not make a smooth switch from the audio after using the phone. If I turn off the bluetooth on the phone and back on, it usually reconnects and plays the audio.
    My phone runs Android 2.2.3.
    Is this just an isolated case or a known problem?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Might be good to indicate the phone model and carrier. I doubt that all Android phones have identical Bluetooth hardware and drivers, even when running on the same Android OS version.
    Even Apple changed the Bluetooth chip from the iPhone 3GS to 4, even though both can run iOS 5.0.1. See step 11 of http://www.ifixit.com/Teardown/iPhone-3GS-Teardown/817/2 vs. step 18 of http://www.ifixit.com/Teardown/iPhone-4-Teardown/3130/3. On the Verizon iPhone 4 (CDMA version), they went to a Murata chip (but they believe a Broadcam BCM4329 is inside), see http://www.ifixit.com/Teardown/iPhone-4-Verizon-Teardown/4693/2.
  3. eldiee
    eldiee Member
    118
    17
    Iowa on Mississippi River Bluffs
    I went through 3 cell phones(all the same model) to get one that worked with my Prius Bluetooth. It may just be your phone.
  4. MBRGuru
    MBRGuru Member
    255
    26
    If switching Bluetooth on or off, or power cycling the phone fixes it, then it's probably the phone getting into a bad state.
  5. jonjacobmoon
    portland
    Good point. Its a t-mobile galaxy S. The real weirdness is the indeterminacy of it all. Sometimes it works as expected, sometimes not.
  6. registered
    registered New Member
    Vancouver, Canada
    I have the same sort of problems with my wife's Nexus S and my BlackBerry Torch. Phone almost always works; music, less so.
  7. Robbert
    Robbert Junior Member
    Deerfield, NH
    Same issues here too. Blackberry Torch 9810 (still no Entune available for this one.. Grr).
    I have had bluetooth say it's connected and then I dial a phone # and it routes the audio to the phone.
    I've had the contacts not sync randomly. Reading my email out loud (identifying when messages arrive) is flaky too. Sometimes it works and sometimes it doesn't. I haven't tried audio much, but the few times I have, it also seemed to randomly work and not work...
    In 99% of the cases, resetting the blackberry brings everything back to normal. There's only been one time when turning the car off and on was the only way to get the phone to communicate again.
    With all that said, my old '06 Prius didn't have bluetooth, so I used a bluetooth adapter from Blackberry (figured it's the same brand, so it must be more compatible...). Same issues. Sometimes it worked, sometimes it didn't. And the only way to get it to work was to pull the power on the adapter or on the phone...
    Not impressed with bluetooth in general. Seems to be flaky overall...
  8. BlizzardPearlV
    BlizzardPearlV Junior Member
    35
    So far the phone has worked exactly as described for me (iphone 3gs on rogers network) except for being able to check mesages. I don't know if this is even turned on in the Canadian models but its not there for me unless I am missing something when it comes to turning it on. Also while I can get it to play music I can not however get the song names up or have a button to access albums / playlists ect, honestly that is a little frustrating. Had so much potential to not having to deal with plugging in my iphonej to have full control.
  9. ldbman
    ldbman Junior Member
    MA
    Greetings:
    I use an iPhone 4. At first I had the same problems, even went back to the dealer. Two things I have determined. First, the display changes as soon as the car speed exceeds 5 MPH. Contacts and number dialing screen are blanked. Only speed dial & call history remain accessible. The service people say these are programmed into the phone as a safety issue. Second, if the phone is connected through the accessory/USB socket, the screen defaults to this connection. However, if the phone is connected via bluetooth, there is no sound. Workaround is to choose audio source, then select bluetooth (tow screens are displayed, both seemingly playing the same song.
    Hope this helps.
  10. littlemaster
    littlemaster New Member
    Really, it is very interesting information.
    Thanks
  11. DragonflyDM
    DragonflyDM Junior Member
    53
    Pittsburgh
    If you want to use your USB to charge your phone and use your phone's screen to navigate music, video, or whatever, then get an external battery (the kind you use to charge your phone in an emergency or add extra battery life). This will allow you to keep all your functionality of the phone while still charging-- then use the bluetooth to run all your audio through.
    This is how I can get my daughter to still watch shows on a long drive but not still have the speakers get the audio.
  12. wilbur1
    wilbur1 New Member
    Madison, WI
    I have problems also holding the pairing/connection. i do not have a smart phone. i have an LG rumor2.
  13. rjparker
    rjparker Tu Humilde Sirviente
    7,601
    4,458
    Texas Hill Country
    Same problems as I reported earlier. Standard Nokia phone worked fine everytime in my 08 Prius became super-flakey and then failed totally on the V's bluetooth. Changed it to a standard Motorola phone, works better but has problems with contact sync (writes some in backward) and dialing (stereo mutes, phone dials, stereo unmutes, call completes, sometimes stereo mutes during call, occasionally does not). Motorola phone also works flawlessly in 08 Prius.
  14. Barb 135
    Barb 135 New Member
    I tried 2 phones different models now on my 3rd a I phone 5 will see how that one works
  15. Barb 135
    Barb 135 New Member
    The I phone 5 has worked fine so far. Just have to keep up with Technology.
