Firefox help?
Discussion in 'Fred's House of Pancakes' started by efusco, Dec 30, 2008.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I've been using FF for a long time. Had the latest version installed on a Vista laptop.
    A few months ago I started, occasionally, getting hang-ups when the browser tried to install some add-on updates. I'd first get a message saying it was unable to install due to another incidence of FF running, then it would go back to the install progress bar, seem to go to the end, then I'd get the 'another incidence' error and the cycle would begin again. This went on indefinately. If I shut down and rebooted and tried to open FF it would do the same.
    I found I could reinstall FF and it would work fine...so I assumed the software was getting corrupted somehow.
    So, tonight, I had the same issue. But this time when I tried to reinstall I got an error message box titled "7-Zip" that reads "Can not create temp folder archive". I uninstalled firefox thinking that would be the problem, but to no avail, same problem.
    I'm waiting for a Chat session at Mozilla, but no one is responding there. I've searched the "Knowledge Base" and found nothing. I googled and found a spanish or Italian site that seems to discuss a similar problem, but can't get it to translate enough to be of any help. So I seem to be stuck with IE on this laptop.
    Anyone have any good ideas how to get my FF to work again?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Were you logged in as an administrator when you did the re-install? It sounds like it could be a privilege issue.
    Tom
  3. Mjolinor
    Mjolinor New Member
    229
    Greece
    2002 Prius
    If you are using Windo$e then Google Chrome is worth looking at. I know it doesn't fix your Firefox and browsers are pretty personal but maybe it will fill you in till you find a fix at least and you never know, you may like it.
  4. qbee42
    18,058
    3,074
    Northern Michigan
    Evan, do you have any aggressive security software running? Sometimes this will lead to installation problems. You might want to turn it off for the duration of the installation.
    Tom
  5. efusco
    19,891
    1,192
    Nixa, MO
    1)Yes, as admin
    2)Tried Chrome, don't like it as well and I like the features of FF.
    3)Nothing too aggressive and it's been on my PC forever without previous issues. I can shut it off, but I think it has something to do with the 7-Zip software.
  6. qbee42
    18,058
    3,074
    Northern Michigan
    That makes sense. Rereading your OP, I wonder if the 7-Zip is trying to do some sort of automatic archive during the new installation? If it is 7-Zip, I would expect the problem to be in one of two areas:
    1) 7-Zip has done something funny to your registry and/or shared files and as a consequence your computer is borked up (technical term).
    2) 7-Zip is installed correctly but is running rouge.
    Have you considered uninstalling 7-Zip just to see what happens?
    Tom
  7. efusco
    19,891
    1,192
    Nixa, MO
    I got a reply from someone at the FF help forum (he has nearly 24k posts) who suggested a clean install and deleting my FF file folders...so I'll give that a try.
  8. efusco
    19,891
    1,192
    Nixa, MO
    Oh, and I looked for that 7-Zip thing and couldn't find a program or anything...but I didn't search as thoroughly as I'm capable.
  9. qbee42
    18,058
    3,074
    Northern Michigan
    7-Zip is an open source archiving program. It works like pkzip on steroids. Here is some information:
    7-Zip
    Hope the clean install works. What a pain.
    Tom
  10. efusco
    19,891
    1,192
    Nixa, MO
    Nothing's working so far. Here's the thread at the Firefox Support forum.
    Hang on update and can't reinstall due to 7-Zip error
    So far I've deleted all mozilla folders, uninstalled FF, deleted all my temp folders, and attempted clean installs multiple times. But it immediately hangs as soon as I hit the 'open' button with that same message.
  11. qbee42
    18,058
    3,074
    Northern Michigan
    Okay, Evan, this is starting to make a little more sense. One of the last posts replying to your question states that the Firefox installation program is a self-extracting 7-Zip archive. This means that the Firefox download has been compressed using 7-Zip, and it should expand automatically during the installation. Your error message suggests one of two things:
    1) The Firefox download is corrupted. If this is the case you need to re-download the Firefox installation file.
    or
    2) The Firefox download is okay, but you are running it in such a way that it can't create the temp directory necessary for expansion. When you start the Firefox installation, the self extracting file needs to create a temporary folder with an uncompressed copy of all of the files needed for the installation. The error message says that it can't create this folder. That can happen if the file and folder properties are set wrong, or if you run the installation as an unprivileged user. Look at the folder where you are running the Firefox installation and see if anything is funny.
    Tom
  12. efusco
    19,891
    1,192
    Nixa, MO
    Highly doubtful as I've downloaded it multiple times directly from the Mozilla site.
    or
    Thanks Tom, that makes sense...but I don't know exactly how to do what you're suggesting in that last sentence. I'm using IE to download the file and run it from there.
  13. qbee42
    18,058
    3,074
    Northern Michigan
    Try making a folder on your C: drive. Name it Install or something else that you can remember. Once you create the folder, right click on it and click on security or whatever name is used in Vista. You are looking for the file and folder privileges. Set all of the privileges to full control for everyone. Download the Firefox file to this folder, then double click it and see what happens.
    Tom
  14. efusco
    19,891
    1,192
    Nixa, MO
    I think I've got it...it has something to do with IE (big shock right!)
    I installed Google Chrome, downloaded FF, and it's installing right now!!!
    I'll report back when I've finished installation and confirmed all is well.
  15. Motobob
    Motobob Seaside Pearl...
    22
    Colorado
    I have very similar issues crop up in the last 3 weeks. I did a clean install, etc, but still have the issue it stops working, hangs up, and you cannot close it in the processes; says it is still running. I actually transferred my bookmarks and using IE right now with no issue. All speed is back. I "almost" thought it had something to do with "this" site as it seemed to happen after reading the forum.
    Bob
    Vista and firefox- no issues until a few weeks ago.
  16. efusco
    19,891
    1,192
    Nixa, MO
    I'm alive!!! Still hunting for my favorite add-ons to get back in place, but I'm alive. It's the damn IE loader that was the install issue. Hopefully with this nice clean install I'm good to go for a while!
  17. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    As far as Vista, I have a Vista Ultimate machine in my home office, I built it myself. I have had to reinstall Ultimate numerous times, until I updated the BIOS for the MSI motherboard
    There was a security update a couple of weeks ago that may have caused your grief. Some of the computers at the office had random glitches that went away once the updated update (Say that quickly three times, I dare you) came out
    Remember that even though you delete a file or folder, you don't change the Registry values. I don't recommend starting the Registry Editor, as any mistake on your part can really fubar things. A wipe and clean install is safer
    IE can cause issues for downloading. I only log into my Adobe account with Firefox, as I tried for three days to download the Acrobat Pro 9 update without success. First thing tech support told me: install Firefox and login using Firefox.
    Best of luck. Try heavy drinking, that always works for me
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    So, how did that heavy drinking go? I'm about to start the rounds myself, so had better sign off
  19. efusco
    19,891
    1,192
    Nixa, MO
    Guess you missed the posts above where I found my fix....but that didn't preclude the drinking. It is/was New Year's Eve!
  20. qbee42
    18,058
    3,074
    Northern Michigan
    Good news. I will censor my usual comments about IE and just say "happy new year!"
    Tom
