Firewall location?
Discussion in 'Gen 5 Prius Technical Discussion' started by priusdriver223, Mar 5, 2025.
  1. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey everyone, does anyone know where the firewall is located? Specifically the one that runs through the driver footwell to the engine bay? I took a look underneath the footwell area and found dead ends, am I slow? Cheers!
  2. ChapmanF
    18,516
    KInda hard to miss the firewall. Try to get into the engine bay from inside the cabin, you'll find it.
    Are you asking about the firewall grommets where wiring passes through the firewall?
    The Electrical Wiring Diagram shows their rough locations.
    Toyota Service Information and Where To Find It | PriusChat
    Or look underneath for some fat bundles of wire and follow them,
  3. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    The firewall is located behind the engine on the engine compartment side, and in front of the accelerator and brake pedals on the occupant cabin side. It is also in front of/under the glove box on the passenger side of the occupant cabin.
  4. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    What's the reference to the firewall from? Your cars owners manual, or some article you found on the internet?
    Because there are two main types of firewalls in modercars. The old school firewall is between the gas engine and the cabin to slow a possible engine fire from entering the cabin. The other type is a computer firewall that are now beginning to show up in modern cars with wifi / bluetooth and telmetrics connections.
    PrimeDan likes this.
