First 70 mpg tank, 2 1/2 years later!!
Discussion in 'Gen 2 Prius Fuel Economy' started by donee, Sep 2, 2008.
  1. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Made my first 70 mpg tank. 70.1 mpg acording to the MFD, and 70.4 mpg by pump volume. Pumped at the same station, at the same time of day, at about the same temperature. So, the bladder effect should be minimul. The mileage was 663.1 miles , 9.413 gallons pumped.
    I fill up on the day that the third pip drops. It dropped about a third the way into work this morning, and I filled up on the way home tonite. This was 14 days of commuting, plus weekend trips, just short of three calendar weeks.
    The mileage from the gas station to home was 88.1 mpg (4 miles). Which included the restart warmup engine operation.
    The Mycanscan is what I am using to evaluate the Prius operating condition. This is a computer program that runs on a Asus EEEPC, amoungst other comptuers, and is fed by a CAN-USB. This is an expensive solution compared to a Scangauge. But, hell if Bush is going to give me money, I am going to spend it overseas, I guess. Both these items are imported.
    Using the Mycanscan, I was able to not mess around with false attempts to get into glides as much during warm-ups. SHM (Super Highway Mode) was also able to be driven, even though it does not have a load or throttle position indicator. Just by waiting for SOC over 60 % and dropping down in speed to 53 mph, and 1280 RPM. This was good for about 7 mpg. I think aero mods help make this a practical commuting technique, because one can avoid speeding up and down with the mods to stay in this mode. I have aluminum flashing covers on my trim rings. I have other mods, by its 50 / 50 if they are advatagous or making drag.
    Additionally, I found a evening non-highway route that matches the warmup cycle better. I found that the direct route to the highway was very poor matching the Prius warmup - about 40 mpg as I got on the highway. Versus another route which results in 50 mpg in the same distance thanks to allot of pulse and glide during the various warm-up stages, and uphills just when I need to get the car through to the next stage. This was good for about 4 mpg.
    Finally, weather has been advantagous. Just cool/dry enough to avoid using the AC. Probably good for a few mpg.
    Last year my typical tanks were no worse than 58 mpg.
  2. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    Congrats, Donee!!
    That is quite an accomplishment. I don't know that I'll ever get THAT kind of mileage!
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Congrats!
    If you were running on Diesel (15% more energy), you would've achieved PNGV Supercar 80 MPG target. It makes me realized what an arduous task the Supercar project back in the 90's.
  4. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    :tea::car::nod::first::lock1::whoo::hippie::peace::rockon::cheer2::thumb::mullet:
    That pretty much sums it up.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Yay, it's a good feeling...I've broken 70 only 3 or 4 times in the nearly 5 years I've had my Prius...my last tank my best ever at 73.3 MPG. It takes so little to 'break' a great tank. I know there are those who can do this routinely, but I think those of us who must work in a lot of short trips and occasionally highway/distance trips find it difficult to get perfect numbers over the course of a 600+ mile tank.
  6. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Congratulations!
  7. Flying White Dutchman
    4,376
    313
    did you make any pictures from all those mods?
    love to see them!
  8. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    Congratulations, the closest I ever came was I was holding onto 71 MPG with about 185 miles on the tank, but rainy weather killed it and I ended up with a 62 MPG tank after everything was said and done.
  9. jimsoh
    jimsoh New Member
    30
    west central Ohio
    Congrats, I've owned mine for only a few months & accomplished a 62.3 tank. But I have a good commute to use your formula for better hwy mileage.
  10. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    Donee, forget the techno-babble.
    What diet are you own, down from how many pounds :)
  11. Brianb913
    Brianb913 Member
    91
    50
  12. hill
    8,640
    Excellent ~ and way to go ! !
    One of my 1st congratulaters after my 1st 70mpg tank asked me, "Are you going to try for 80?" NO WAY :p
    Anyhow, where's the pic's ?? You DID have your camera phone ready for the momentous occasion, didn't you?
  13. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Thanks for the replies. Nope. I did not take a picture. I guess I should have. Nope, did not loose any weight. Still my hefty self. If anything, and past experience, the walking I have gotten in this summer has put weight on. Doubt I will repeat this , again, this summer.
    At 68 something mpg after the first day. Head winds in the morning, cool weather mistimed my warmups so I missed some long glides engine off. Will have to add 1/4 th grill block in the morning. The drive home I got caught by every light due to getting mistimed early due to an accident. Also blew all my down hill momentum while a cop did a youie in front of me to go after a speeding SUV over the center line about 5 cars up. Also had heavier traffic (although not stop and go). Trip home took 1 hour 15 minutes, versus the more normal 55 minutes. I have had trips where most lights were hit, all the warmup points made, and coasted that the trip MPG was up around 88 mpg in 55 minutes travel time - which is right on the same travel time down the highway. Time to work this morning took 35 minutes (SHM was difficult into the head wind, kept droping down to 51 mph and was only at 65 mpg versus the usual 71 mpg), versus the usual 45 ( with 10 minutes of slow and go). Then again, this was just one bad day. During the the 70.1 mpg tank, I was up to 71.3 mpg half way through. Then the cool weather started. It was lucky it was so warm yesterday, as things were timed poorly due to two abulances 20 minutes apart on that trip home.
    Here is a link the thread about the hub-caps. There is a picture of one in there. http://priuschat.com/forums/prius-modifications/41338-aero-anticorrosion-mod-trim-rings.html . These look the same from standing distance as when I put them on. But there are small stone impacts from the inside out (not outside in suprisingly) one can see if one gets close to them. I did a coast down test with these, and saw a difference, besides the apparent audible difference. From about 45 mph (coasting, engine off, neutral), the car would hold speed within 1/10 th of a mph for 5 or 6 seconds, versus more than 1/10 th mph drop without them, in less than a second.
    The other aero mods are thin turbulators on the upper third of the A pilar and just before the max height of the rear view mirrors (no additonal cross section area). Also, there is a 20 mm front to back, by 5 mm thick by 2 foot long bump made out of rigid PVC foam (Divynylcell 3lb/cu ft) at the rear of the rear spoiler. I may have the turbulators too thick right now. This was an idea from edbso on Ecomodder web site. Mine are made from 2mm inch thick self-adhesive foam (Foamies trademark). I think they need to be down around .7 mm thick. But I will stick it out for a while with these. I did some wool tuft testing with these, and the effect is small on the Prius (its apparently large on the Matrix). Its amazing what sidewinds do to the air on the side of the car. The full effect of the turbulators can be overcome with just a small side wind blowing over the top of the car. The rear PVC foam bump caused an apparent reduction in rear wind noise. Not as much as the aero hubcaps, but noticable. This idea was mentioned in the Chevy Volt aero video that was linked too from the Ecomodder web site. That mod was only on for the last week of the three weeks. I probably will fill in the foam with epoxy once I can get some blue painter tape to protect the car.
  14. a priori
    3,083
    408
    23
    Chicagoland (West)
    Do you have pictures of these mods on another thread, too? I'd like to see what you have done, Donee.
  15. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi a-priori,
    As they are a work in process, and of somewhat new, or dubious effect, I do not have pictures. Edbso has pictures of his Dymo label tape turbulators on Ecomodder.org.
    Belly pan or vortex generators? - Page 2 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com . These were made with simple pinking shears, common to most sewing kits, and available at stores such as Joann Frabrics, Hobby Lobby, etc.
    I think this is a great idea, but because of the low angle of the front of the Prius the jury is out whether these help or hurt on the Prius. On a car with a steep windshield, and definate vorticity, they should break up the vortex and allow the flow to cascade down the side of the car and give a smaller effective cross section at speed. Edbso's report of quieter zone of air near the upper front side window appears to support this hypothesis on the Toyota Matrix he drives.
    Here is a link to the Volt video:
  16. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Oops, I did it again. 70.1 mpg, 570 miles....
  17. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Congrats! :)
  18. a priori
    3,083
    408
    23
    Chicagoland (West)
    I guess it is just that time of the year!
    The temps have been perfect around these parts. Today completes the first July on record for Chicago where the temperature never reached 90 degrees!
  19. VABeachPrius
    VABeachPrius Member
    155
    Virginia Beach, VA
    Congrats, donee. I understand the patience it takes to acheive great numbers.
  20. patsparks
    10,664
    567
    Adelaide South Australia
    Good on ya!
