First a Prius
Discussion in 'Gen 3 Prius Main Forum' started by John Albertson, Oct 11, 2020.
  1. John Albertson
    John Albertson Junior Member
    Tennessee
    Just purchased a 2015 gen 3 from an elderly lady with 25k miles. Joined this forum and amazed at the collective info and knowledge here. Going to install a OCC ASAP. First fill up with non ethanol gas computer shows average 54.5 mpg. Will check actual mpg next fill up. Original EP20 tires have plenty of tread but approaching 6 years old by date code so will be replacing tires soon. They are noisy tires.
    Burna J, SilverSmoker, iplug and 2 others like this.
  2. orenji
    orenji Senior Member
    5,887
    3,488
    Welcome to Priuschat! Hope you enjoy your new Prius! There is no going back to a non-hybrid once you get a Prius.
    John Albertson likes this.
    51,966
    first a prius, then a tesla?
    congrats, all the best!(y)
  4. orenji
    5,887
    3,488
    Nah you got that wrong. See going to a Tesla is going backwards in quality. Going to a Prime or Mirai would be the direction a Toyota fan would go in.
  5. Mendel Leisk
    41,479
    Yeah the EP20 get noisy as they age/wear. Become a menace in any amount of snow too. That said, they're pretty cheap, and very good for mpg.
    An elderly lady with 25k miles? ;)
  6. John Albertson
    Tennessee
    New tires today. Bridgestone Turanza Quiettrack’s. Very quiet but time will tell once they break in.
    Also received Veepeak obd2 scanner and ran life expectancy test with Dr Prius app. Was pleased it passed with 78.11% out of 90. It’s a 2015 manufactured Dec 2014 so almost 6 years old.
    Oil catch can also came, so time to get acquainted with some diy on the engine.
    Plan to change transmission fluid at next oil change too!
    First fill up with 352 miles was 6.6 gallons, 53.3 mpg.
    Found a Valero station close by that has non ethanol gas for $1.99.
  7. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    The HV battery likes to be used and that one hasn't been. If this is a long term purchase, I suggest looking into the merits of grid charging vs wait & see if it fails under warranty. Plenty of threads here so have a look around.
    Also, with the VIN you can check and see what's been done by Toyota dealers here: Welcome to Toyota Owners
    GOOD LUCK!
    Jason Beauchamp likes this.
  8. Mendel Leisk
    41,479
    Does it say 90% is max, say in the dr Prius info? A little odd.
  9. John Albertson
    Tennessee
    So the Dr Prius app results are not good? I would think if the battery was not well my gas mileage would suffer but I am new to the Prius and obviously still learning.
  10. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    That is the youth fountain of gasoline
    (y)
  11. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    First of all, that is just an estimate. Second, the battery is healthy. Just drive it regularly and you should be fine for a long time. Once you do, the results may actually improve. And you are still under warranty for another 2 years.
    How many miles per year do you expect to do?
  12. John Albertson
    Tennessee
    I usually drive 15-20k a year.
  13. royrose
    1,389
    953
    Foot of Pikes Peak
    Your hybrid battery will like that.
  14. spudnut
    spudnut Active Member
    145
    159
    Idaho Falls/Pocatello, ID
    So what's E-10 selling for in your area, if E-0 is selling for $1.99? Myself, I burn lots of E-10 because I refuse to pay extra for E-0, and still average mid 50's per tank.
  15. John Albertson
    Tennessee
    It’s around 1.89. The place I was getting E-0 is $2.45. I found a couple places with puregas and one had it for $1.99. Hope it stays that way.
  16. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    Might want to checked for a clogged battery fan especially if the previous owner had pets.
