First car wash, what a "beep"-ing car!!!
Discussion in 'Gen 3 Prius Main Forum' started by Beachnut, May 9, 2014.
  1. Beachnut
    Beachnut Member
    185
    43
    Hello all!
    I just washed our new Prius opt. pack 3 car for the first time ever, with my remote key in my pocket. Every time I hosed off the car anywhere near the door handles, the car would beep at me!:whistle: Pretty weird. Beep, beep! Like it liked the water,, or,, maybe its like a cat, and it does NOT like getting wet!:eek: I thought maybe I should take the "key" out of my pocket, and set it far enough away from the car so it wouldn't be a beeping at me, but I was rushing around trying to keep the sun from spotting it, so i just kept letting it beep away when ever it got tickled with the water!
    Any one else experience this? Is this normal? Weird beeping car! Tomorrow it gets is first clay bar & wax job. I wonder if it will purr like a kitten for that?:ROFLMAO:
    Love the car so far though!
    Beachnut
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    It's "bleepin" normal !
  3. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    It shouldn't beep if the car is powered off. Also try leaving the fob inside the car while you wash it.
    In cold weather I leave it inside with the power on while I remove snow. It prevents the annoying triple beep every time you open and close a door.
  4. Warp4
    Warp4 New Member
    Richmond, Va USA
    I had crazy thoughts of the water short circuiting the doors when I did the wash. Somewhere in the manual it says it will behave as you described. No worse for the experience.
  5. fuzzy1
    10,335
    The water on the door handle finger sensor tricks the car into thinking you are touching the sensor, trying to lock the door.
    spiderman likes this.
  6. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    And/or trying to UNlock it.
    My C does that too.
    Keep the FOB far away from the car........or don't get the door handles too wet.
    Heavy rain can "confuse" some of the fancy sensors on modern cars too.
  7. bisco
    51,154
    leave the fob behind next time and you won't have any beeping problems.;)
  8. bisco
    51,154
    leave the fob behind next time and you won't have any beeping problems.;) ;) as for double posts, well, that's another story!
