First Dealer Tank sucked...
Discussion in 'Gen 2 Prius Fuel Economy' started by setheriah, Mar 16, 2007.
  1. setheriah
    setheriah New Member
    40
    Ok Well its about 50 degrees in Tulsa... Filled up for the first time...
    Display said 315 miles driven at 35.2 mpg
    I manage to get about 10.7 gallons in which I rounded up to a round dollar figure and got 10.883 gallons in with one pip left.. Didn't even get to the flashing pip yet....
    so take the hand calculation 315/10.883 = 28.94422494
    which sucks...
    I realize though that I have to take into consideration that I made a lot of trips when I was in Portland that were less than two miles per segment..
    So which is more accurate the gage or my hand calc.. I dont know how much the dealer really filled it as well..
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    tank to tank always believe the MFD calculation. For lifetime you're going to be more accurate with the calculated.
    2 mile trips will kill you and you've got a long way to go to get the most out of the car.
    Be sure to read my article:
    http://priuschat.com/index.php?autocom=art...rticle&id=3
  3. chuck kershner
    chuck kershner New Member
    25
    <div class='quotetop'>QUOTE(setheriah @ Mar 16 2007, 12:45 PM) [snapback]406866[/snapback]</div>
    Welcome to the real world. When I bought my Prius I, too, agonized over mileage considerably less than the EPA sticker 61/55. The best I've ever obtained was in the first 600 miles when I hit 49 mpg. Then mileage continued to slip back to the mid- to hi-30s, touching 40 occasionally, depending on the weather. I also make many mile or less trips during the day and mileage can drop into the hi-20s, like you just described. Today I did a 160 mile round-trip (not a lot of miles) and it was up and down and over some of the hilliest countryside in central New York State. The average for 300 miles so far on this tank is 38.9 mpg. I still have two ticks to go on the gauge before the blinking light. Speaking as an ex-gas mileage junkie, I might suggest you simply drive the Prius, have fun in it, and be mindful that your 35.2 or 28.92827624 mpg is better than what you previously owned (I assume) and that the emission is considerably more friendly to the environment than virtually all other vehicles. (And since I also have an incurable disease, I find that life is simply too short to calculate my Prius' gas mileage to eight decimal places.) Enjoy the car, enjoy the ride, enjoy life.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I never come in under 40 mpg, even in the coldest, snowiest time of year. In the summer we average around 55 mpg. Your mileage will improve as the car breaks in and your driving technique improves.
    As Evan says, don't try to calculate mileage based on tank fills. The bladder in the tank causes too much variation from one fill to the next.
    Tom
  5. DFWPrius
    DFWPrius New Member
    Hurst, TX
    Gas brand in the tank is a major factor also.
    If you buy gas at discount stations like Racetrack, Circle K, Seven-11, and others. They buy alot on
    the open market, so the gas blending changes from tank to tank, in ground at the station and in the
    car.
    I get 1 to 2 mpg more per gallon if I buy at shell, or BP.
    Localy in the dfw area I have found Shell to be one of the best for my car.
  6. setheriah
    40
    <div class='quotetop'>QUOTE(chuck kershner @ Mar 16 2007, 04:59 PM) [snapback]406968[/snapback]</div>
    Well i did the calculation in the excel spreadsheet anyway
    <div class='quotetop'>QUOTE(efusco @ Mar 16 2007, 12:48 PM) [snapback]406870[/snapback]</div>
    so believe the Display on a tank of gas.. but the calculated for lifetime average?
  7. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(setheriah @ Mar 16 2007, 06:04 PM) [snapback]407017[/snapback]</div>
    Well, I wouldn't go quite that far. Welcome to The Guess Gauge. There is 1 thing to absolutely believe: When the last pip flashes BUY GAS.
    Generally my MFD is close (1-2mpg high) to my calculation. Sometimes in the cold it is 20% high. I always believe my calculation before the MFD. However, the MFD is the only reading you have on the current tank.
    I switched to Shell exclusively for the 5% rebate on their MasterCard. The changes of brand, insulation, tire pressure, and driving style have not reduced my mpg during the winter.
  8. Bill Merchant
    Bill Merchant absit invidia
    4,096
    82
    The MFD shows calculated MPG (in the US) based on the time fuel injectors are open (volume) and wheel revolutions (distance), both very small increments. Hand calculation is based on pump volume (uncompensated for temperature in the US, but volumetrically accurate to about 1/8 ounce) and odometer reading (accurate to ±0.1 mile or around 500 feet, based on standard 855 revolutions/mile tires). What neither can't account for is the energy content of the fuel. Both measures should converge over the long term.
    Also, the first tank can be weird. My MFD showed more miles than my odometer.
    The Prius gets better MPG than any other car currently in production. Your personal MPG will get better as the car and tires break in, as you learn to drive for fuel efficiency, and as the weather warms.
  9. setheriah
    40
    well im doing a little better now.. Now I am at 49.9 mpg and driven about 250 miles on the second tank.. did not lose the first pip until 157 miles of driving... I set the cruise control at 60 mpg... and coasted down hills so far only lost two pips on the tank..
    keep you posted...
  10. Godiva
    Godiva AmeriKan Citizen
    10,339
    The Prius has a flexible bladder. You can't do hand calculations accurately. You'll have to use the screen.
    A lot of short (less than 10 mile) trips aren't great.
    You can improve your mileage by increasing your tire pressure.
    There is also a breaking in period. Your mileage will increase with each tank. The first few are always the worst. There is also a learning curve where you learn to drive more efficiently.
  11. daveleeprius
    daveleeprius Heh heh heh you think so?
    429
    Seattle
    <div class='quotetop'>QUOTE(Godiva @ Mar 17 2007, 10:10 PM) [snapback]407690[/snapback]</div>
    Breaking in period? Nobody told me about that before. My 2007 hasn't ever gone below 42mpg, and I have about 3k on the car now, and the MFD says 43mpg.
    Dave
  12. Godiva
    10,339
    <div class='quotetop'>QUOTE(DaveLeePrius @ Mar 17 2007, 10:32 PM) [snapback]407696[/snapback]</div>
    All new cars have a breaking in period. I noticed my mileage improved after the first 2,000.
    When I got mine the first tank was about 44.5 and they went up every tank after that. I get between 48 and 52 now with my tires at 42/40.
  13. steviet
    steviet New Member
    64
    Massachusetts
    <div class='quotetop'>QUOTE(Godiva @ Mar 17 2007, 10:59 PM) [snapback]407709[/snapback]</div>
    I think nowadays the breakin period is almost non existent, with the materials and finely tuned machinery used to create the engines these days I doubt there is much in a way of a traditional break in that we used to have years ago. It's more likely that we get used to driving the car hence the better fuel efficiency as time and mileage go up.
    I completely agree with you about the hand calculations and I never understood why people put so much stock in the hand calculations when the size of the gas tank changes with temperature from fillup to fillup. Seems to me the computer would do a much better job tracking that.
    Steve
  14. brick
    brick Active Member
    1,083
    78
    Upstate NY
    I must be the only one whose dealer didn't short change him on fuel. In fact, they somehow put more fuel in the tank than I have since. The first pip ran out around 110 miles or so IIRC, and for my fills it usually runs out around 30 or 40mi. As a result my first tank looked really good on paper. I guess it goes both ways.
  15. JamieS
    JamieS New Member
    70
    My dad insists on filling it up when the tank's at halfway.
    How do I calculate the mileage when we're filling it up so screwy?
  16. JimN
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(rainydysandmondys @ Mar 18 2007, 08:14 PM) [snapback]408093[/snapback]</div>
    For lifetime mpg keep a record of the amount of gas pumped each time. Divide the odomoter (total miles) by total gallons.
    For the mpg on the tank subtract last time's odo reading from this time's odo reading and divide by the gas pumped this time. IN THEORY, this calculation should match the MFD if you reset on each fill up.
    Although I have some large deviations, the MFD's calculations are close to mine. I might actually believe the computer if it measured fuel consumption instead of sampling it.
  17. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    <div class='quotetop'>QUOTE(steviet @ Mar 18 2007, 03:51 PM) [snapback]408040[/snapback]</div>
    While it's not the same as years past, it still exists. Even finely machine products with close tolerances will develop wear patterns over time as parts mesh together. My MPG didn't stabilize until about 7,000 miles. I had driven an '02 for 2 years prior, so I don't chock it up to lack of experience.
