First Drive: 2010 Ford Fusion Hybrid
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by zenMachine, Jan 5, 2009.
  1. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    CanadianDriver First Drives First Drive: 2010 Ford Fusion Hybrid
    The switch from gasoline to electric is seamless, even though it happens a great deal (the system has been optimized for the maximum number of gasoline engine shut-offs, which improves fuel economy). The redesigned Fusion has a great deal of sound-deadening, and it’s so quiet that, combined with the seamless operation, I’d be willing to bet that if a driver was placed in it with no indication of its hybrid status, it would take him a while to realize it. Steering is responsive, with none of the vagueness that can sometimes plague hybrids, and it feels firmly planted and confident on the highway. If you’re not worrying about how many leaves are growing in your gauge, the car’s very peppy, and there’s enough power to get you around traffic on the highway.
  2. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Sounds great. I sure hope to see more similar reviews from other sources to support this.
    Excellent article. Everyone reading this should click on the link to the actual article and read the entire article. Lots of good info and photos in there.
    "is now entirely Ford’s technology (save for a battery purchased from Sanyo), with over 100 patents pending on the Fusion’s system alone." - an indication that Ford has put a lot of effort and investment into this vehicle.
    "Canadian pricing hasn’t been announced yet, but south of the border, the MSRP is US$27,270."
    At that price, it should sell very well in the US. (especially since gas prices are heading back up)
  3. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    I'll test dive it before I buy the 2010 Prius.
  4. Flying White Dutchman
    4,376
    313
    nice
    good things with ford!
  5. Bohous
    Bohous New Member
    316
    Boston-ish
    It will be interesting to see in the HYbrid package has features closer to the sport model or the base model. From the pics it looks pretty loaded but $30k is a lot to pay for a midsize Ford and the "hybrid premium" could be pretty easy for naysayers to show the payoff period to be prohibitive. That being said it's a nice looking car and I wish Ford best of luck.
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    uh-huh. 40% would be fantastic
  7. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    ...and Ford was the ONE of the Big Three that didn't request a bailout.
    Way to go, Ford. :cheer2:
  8. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    There are some claims being made about this vehicle that make me highly skeptical. The braking efficiency is just one. The staying in all electric is another.
    If they truly are staying in all electric for moderate acceleration, that is not likely to be efficient. The other major problem is that it will result in deeper pack discharge and at a higher amperage rate--not conducive to long battery life as I understand it.
    That's not to say it is a bad vehicle, just that it appears that some of the points are being oversold or perhaps misapplied. Until one of the hypermilers spends some time with it I doubt we will get a straight technical scoop.
  9. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    I assume the 94% refers to how much of the breaking is of the regenerative type - not the percentage of the energy recouped from getting and keeping the car moving. If the former is was what was intended, I'm not sure how that figure was estimated (and am still skeptical). If the latter, then I'm getting one of those cars ASAP and and submitting a patent for a "near perpetual motion" machine.
  10. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    It's straightforward: the amount of the car's kinetic energy that is turned into electrical energy and used to charge the battery, compared to the amount that could potentially be recovered. However, it's nothing new: the Prius (HSD, NHW20) also extracts most of the car's kinetic energy through regenerative braking.
    Remember that the car is subject to losses while driving down the road. In fact most of our fuel's energy goes into overcoming those losses: friction, rolling resistance, wind resistance. The kinetic energy of a 1725kg car (stated Gross Vehicle Mass) travelling at 70mph is around 840 kilojoules, which for comparison is about 233 watt-hours (one joule is one watt per second), i.e. 0.233 kWh. The fuel's energy content is (per Wikipedia) 34.8 megajoules per litre, so absent other losses and assuming 100% conversion it would only take 24 millilitres, or less than two tablespoons, of fuel to accelerate to that speed. In fact the Prius engine is better than 33% efficient at the engine output shaft, so let's say 75ml of fuel.
    Clearly we use much more fuel than that in a day!
    Anyway, once you take your foot off the gas, the car is subjected immediately to those losses. Per Wikipedia again, the Prius has a drag area of 6.24 sq ft, which is approximately 0.58 square metres, so the wind resistance is about 730N at 70mph, with the air at 0 celsius and one atmosphere of pressure. It therefore requires 22,776 watts of power to overcome that wind resistance, and no doubt there's some complex integral I can't be bothered to compute which would demonstrate how much of the kinetic energy is simply lost to wind resistance.
  11. MaxLegroom
    MaxLegroom Junior Member
    Newport News, VA
    If I buy another hybrid, this would likely be it. I've driven a Fusion before, and enjoyed it very much.
    Apparently Ford claims the vehicle to be able to stay on electric power to 75 km/h, which would be about 45 mph, not far from the 47 mph figure I read elsewhere. I'm not surprised, really. It is fairly normal for my Prius to stay on electric power to about 41 mph, but with more charge, I've seen much more than that, up to 50 mph with the eighth bar showing on the MFD.
  12. patsparks
    10,664
    567
    Adelaide South Australia
    Can anyone tell me what is with that bloody ugly chrome grill?
    I wish them every success but do something about the ugly stick they hit the front with.
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    My best guess of what the "up to 94%" statement refers to is how much energy that leaves the generator ends up in the battery. I am pretty confident it does not mean that up to 94% of kinetic energy makes it to the battery. The statement of EV up to 47 mph is also fairly simple for Prius devotees to grasp: it just means that M/G is allowed to spin about 10% faster than the Prius before ICE counterspins, similar I think to newer HSD spec, and less than what we will see in the first gen Prius PHEV.
    Mainstream auto press still does not really understand the Prius after 10+ years, so I am not surprised to find them blindly quoting numbers for the Fusion with nary a clue.
  14. JSH
    JSH Senior Member
    2,605
    140
    PDX
    That "bloody ugly chrome grill" is the new face of ford. The 3 bar grill was first introduced on Interceptor concept car and is now on every US spec ford car except the Mustang. It is also on newly introduced crossovers like the Flex and Edge.
    Ford Interceptor Concept----------------------------Ford Focus Coupe----------------------------------------------Ford Edge
    [​IMG][​IMG][​IMG]
    Automakers have a problem. Large grills / grill openings became very popular in the late 90's and remain very popular. However, large grills are not required for cooling and can greatly increase aerodynamic drag. According to Race Car Aerodynamics by Joseph Katz, the Cd of internal airflow through the cooling system ranges from 0.005 to 0.07. When you consider that the average production sedan has a Cd of 0.30 to 0.35 that means internal airflow can make up 20% of the total drag from the car. At the same time, car makers are being pushed by both the EU and US regulator bodies to increase fuel economy. So you have a conflict between the engineers and the stylists.
    The compromise has been to keep the large opening but fill it with something to block the airflow. Ford does this with the new 3 bar grill.
    VW has blocked off 1/3 to 1/2 of of the grill opening for their Bluetech vehicles to get better fuel economy.
    [​IMG][​IMG]
    Honda is doing the same thing, the 2010 Insight and 2009 Pilot still have a large grills but they are blocked:
    [​IMG][​IMG]
    For a visual of how crazy the stylists have gone with large grills here are front pictures of my last 2 cars, the first a ~ 200 hp V8 and the second a ~ 90 hp hybrid that shuts off the engine at stoplights:
    [​IMG][​IMG]
  15. Collector
    Collector Junior Member
    24
    Illinois
    Does anyone know if the Fusion uses the same hybrid system as the Escape hybrid?
    I used to think each company uses the same system in all their hybirds but then I read something that said Toyota uses a different system in the Prius than they do in the Hylander.
  16. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Does anyone know if the Ford Fusion Hybrid uses a power split device (and thus a fully variable transmission) similar to the one used in the Prius?
  17. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    I find it sad that like the Camry Hybrid, Altima Hybrid and this new Hybrid Fusion get relatively lousy mileage. A Prius, basically the same size, gets 33% better mileage. There is NO reason they can't do as well as the Prius, yet, they are not designed with high mileage in mind, just compact car mileage in a mid sized car.
  18. Tideland Prius
    16,445
    Basically, yes in terms of category but the Altima and Camry are a lot bigger than the Fusion and the Prius. Also you're asking a 2.4/2.5 litre hybrid to get the same fuel economy as the 1.5 litre Prius. S'not gonna happen.
  19. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    been in a TCH and it might only be slightly bigger in overall capacity, the passenger area is more roomier... its wider and makes a lot of difference, but then again, i have never ridden in the back seat of a Prius before
  20. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yep, to chime on this... the TCH feels significantly bigger and wider after having driven one for a day. It also has (and feels) a lot more powerful than the Prius. The NAH is way more powerful (88 hp more) and feels WAY faster than the Prius. (I drive my mom's NAH every now and then.)
    The NAH is also ~600-700 lbs. heavier than a Prius...
    So, I'd also agree that it's unreasonable to expect the same mileage vs. a Prius w/all these factors against it.
    Just take a look at Most fuel-efficient cars. The all the non-hybrids there are wimpy in terms of power.
    On a side note, I saw the Fusion Hybrid at CES at the Microsoft tent. I did see the gauges and tried out Sync w/my iPod. After some struggling (lack of familiarity w/command set and UI goofiness), I was able to do things like (push button) then say USB, Play Song [name of song]/Play Artist [name of artist] off of songs on my iPod. Very cool!
    Too bad I couldn't take it for a drive. There also wasn't much to see under the hood since most stuff was under plastic covers.
