First dump from OIL CATCH CAN - how's this look? :(
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Atari, Jan 31, 2019.
  1. Atari
    Atari Member
    84
    47
    Sacramento
    The sludge is coming off of the line connected to the intake manifold.
    The line connected to PCV is clear.
    Of course this car has all the other symptoms this pos Gen3 Prius has that gets people installing an OCC in the first place: "misfire" but only at start, drives fine otherwise, white smoke in the cold. I've already cleaned the EGR pipe, cooler, IM, etc.
    Loss of coolant can be seen from the reservoir (big surprise...?)
    Oil itself from the dip stick does not seem contaminated.
    I am starting to think design flaw with how they secured the IM around cylinder 1 and they don't want to admit it. Think about it, if you replace the IM, you're going in and reseating / torquing the bolts and putting on a new IM gaskets.
    Grit and bisco like this.
    49,397
    looks like what's left of my dinner :eek:
    Mendel Leisk and Raytheeagle like this.
    49,397
    btw, what are you driving, and how many miles?(n)
  4. Atari
    Atari Member
    84
    47
    Sacramento
    2010 Prius V. about 190k miles.
  5. Grit
    Grit Senior Member
    6,141
    4,055
    Wilkes Land
    Cant wait to put my OCC in, that's like scared straight drug/drunk driving videos back in grade schools.
    orenji and Raytheeagle like this.
  6. Atari
    Atari Member
    84
    47
    Sacramento
    I don't know... I'm assuming this is indicating a head gasket failure at best.
    Update: After reading around a bit more, maybe this is somewhat normal/expected? Someone said it's a combination oil and water condensed? Doesn't look normal to me.
    #6 Atari, Jan 31, 2019
    Kuang likes this.
  7. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    Did you took the occ out after the car has been sitting for a while or after a drive?
    I took mine out after doing an oil change and it was more liquidity than yours.
  8. Atari
    Atari Member
    84
    47
    Sacramento
    Hey Nutz! Thanks for chiming in. I loosely followed your youtube videos for the EGR/PIPE/IM cleaning.
    The car is a daily driver. Been on the road every day since the EGR cleaning / OCC install project (same day). Car also got new plugs (the current DENSO's that Toyota prescribes) and oil change.
    One thing I thought of just now with the sludge looking OCC contents is that immediately after the major EGR cleaning I dumped a bottle of techron "fuel system cleaner" in to clean up the injectors since I didn't have time to touch them or play test-the-coils this time around. So the OCC would have caught any by products from that as well. Maybe there are some detergenty solvents or something in the techron that would do that. We'll see on OCC dump #2 (if my car survives that long... still has the shaking fits)
    Btw, coils and injectors are next. After that, I'm not sure what the shaking can be.
    This isn't my car below in Youtube video, but my problem is basically like theirs....
    (making a sound like the Prius has changed itself into a giant rock polisher.... but only for a few seconds until it corrects itself)
    #8 Atari, Feb 1, 2019
  9. NutzAboutBolts
    1,476
    1,552
    Bay Area
    Is your car year model a 2010-2011 by any chance?
  10. Leadfoot J. McCoalroller
    7,138
    6,685
    Pennsylvania
    2018 Prius c
    Whip water and oil (any oil) together hard enough and you'll get salad dressing like that.
    Cold weather and short trips will cause nearly any engine to form an emulsion like this. The general idea is that at some point you will take a longer trip, the engine will get up to full temperature, causing the water component to boil off and the remainder (motor oil) will be indistinguishable from the rest of your motor oil.
    When you add a catch-can, you're just skimming it off instead. Nothing wrong with doing it that way, other than that you have to figure out safe disposal and then replenish the lost motor oil.
  11. Atari
    Atari Member
    84
    47
    Sacramento
    Yes... 2010 Prius V. In California - but over 150k so SOL on the extended warranty stuff for EGR/IM. It acted up before earlier in it's mileage history but I don't think it was recorded with the service people.
  12. Atari
    Atari Member
    84
    47
    Sacramento
    Whew. Good to know. When I first saw that (with coolant loss in reservoir) I immediately thought the headgaskget has failed somewhere. Going to try to get coils today.
  13. Mendel Leisk
    38,656
    I check my OCC spring and fall. The fall "catch" is mostly oil, but in spring it's more of that "mayo" appearance. As @Leadfoot J. McCoalroller says, an oil/water mix, and not necessarily due to coolant leaking into oil, maybe just due to rainy/humid winter conditions. If you had head gasket problems you'd be seeing the coolant level dropping in the reservoir?
    NutzAboutBolts likes this.
  14. Atari
    Atari Member
    84
    47
    Sacramento
    Coolant level does drop in reservoir.
    But it does maintain about 1" of coolant at the bottom of the reservoir.
  15. Mendel Leisk
    38,656
    Ah sorry, missed that. Interesting video:
    Atari and m.wynn like this.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    You sure it is maintaining or the front compartment portion that can’t drain;).
    I’d look again(y).
  17. Atari
    Atari Member
    84
    47
    Sacramento
    Wait... can you explain in more detail? The reservoir on the top left.
    Oh... I see what you're saying. The bit that is a little below the hole for the drain hose. Yeah you might be right.
    .... so.... where is the coolant going? Or do I not want to know.
    It doesn't appear to be in the oil (on the dip stick)
    Raytheeagle likes this.
  18. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    If the level is dropping and there is no puddle of coolant on the ground, it’s going into the engine:(.
    Some questions:
    • How fast does the level drop?
    • Does the oil have an abnormal smell?
    • Didn’t you have the temperature icon appear awhile back?
    • Did you ever resolve that?
    Good luck and keep us posted (y).
    Atari likes this.
  19. bisco
    49,397
    you can add your vehicle model and package under your avatar where it says other non-hybrid, by clicking on your screen name at the top right of the page, then clicking 'personal details' (y)
    Atari and Prodigyplace like this.
  20. Atari
    Atari Member
    84
    47
    Sacramento
    Replaced coils today.... problem is 90% better.
    It still does the stutter for about 1-2 seconds on a cold start or short-trip start, but definitely clears up faster.
    It was so bad before replacing the coils that it would do the stuttering at every stoplight/intersection for 4-5 seconds of pumping the gas (because I feel like that is helping... but probably isn't)
    Very odd. I still thing Toyota hiding something here with what is happening with the Gen 3's.
    • New plugs - the P/N toyota now sells
    • "New" denso coils (from wrecker)
    • EGR valve, pipe, cooler cleaned very well.
    • Existing intake manifold and ports cleaned very well.
    • New oil / filter
    • New air filter
    • New PCV valve
    • OCC installed
