First few minutes mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by gazz, Mar 4, 2010.
  1. gazz
    gazz Member
    216
    Coventry, UK
    First few minutes mpg with pictures
    I have be trying to drive my Prius III similar to my old II for the first few minutes. What I have found is that for the first minutes the car runs on battery at 1280rpm and gets about 20mpg (I suppose this stage is to heat the cat) also the ignition angle is negative.
    What I have found though is that if I pull away a bit quicker and force the engine to run (not 1280rmp) I pick up speed quicker and am getting nearer 40mpg over that period.
    Anybody else done any investigation on the first few minutes on a Prius III.
    Thanks
    Gary
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I have not done any investigation but notice that when I drive the three blocks through my neighborhood first thing in the morning to let the engine warm up, I am only getting about 20 mpg and using the battery.
    When I get to the main road where I have to merge with 45 mph traffic and have to accelerate, the ICE will kick in the mpg will jump up to the 40 mpg range as you note.
  3. gazz
    gazz Member
    216
    Coventry, UK
    Yes that's what I see, so what I did was to accelerate straight away and get the 40mpg, the engine still seems to warm the same way.
  4. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    See Ken@Japan's sticky thread in Gen3 Technical Discussion forum on warming up stages of the 2010. He discusses this very point, as well as a reason you may choose not to accelerate hard, and his alternate solutions.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Any time you draw energy from the battery you will see better short term mileage figures. This is because the mileage meter does not include battery charge in its calculations. In effect, what you are doing is borrowing energy from the battery which must be paid back later, with interest.
    The instantaneous mileage looks better, but the real mileage is lower.
    Tom
    2 people like this.
  6. gazz
    gazz Member
    216
    Coventry, UK
    Sorry I don't understand, what I am saying is that the mpg is better when you force the engine to rev higher than the 1280rpm and not just drive on battery and use the engine to heat the cat.
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    in the first few minutes of operation after extended parking time which would be first trip of the day from home or coming home from work, i have very very little options as to my driving style, speed, etc.
    i have a child almost 3 (most common age for child involved in pedestrian/auto accident) , live across the street from the park and despite a posted speed limit of 20 mph, we frequently see people driving much faster.
    but then again, this is another of those "i get better mileage at 65 mph than at 55 mph" thread by another name
    and logic, rules of physical laws, etc. did not work on that thread and probably wont work on this one either
  8. LoveMyPriusIII
    LoveMyPriusIII New Member
    66
    Good point. Well put.
  9. qbee42
    18,058
    3,073
    Northern Michigan
    There are two problems with this approach:
    1) The ICE is not as efficient when cold.
    2) Driving hard with a cold ICE draws more energy from the battery.
    The lower efficiency would be immediately obvious if instantaneous mileage were calculated from gas consumption *and* battery drain. Unfortunately the instantaneous mileage only looks at gas, so you don't see the real cost of forcing the ICE to run harder.
    This is a common mistake, and often it encourages new Prius owners to try and maximize electric only driving. Since the instantaneous mileage gauge only looks at gas consumption, driving in electric mode shows infinite mpg. It looks really impressive on the mileage gauge.
    Unfortunately, the electricity from the battery that is being used has to be replaced. This comes at the cost of burning gas. The efficiency of burning gas to make electricity to charge the battery to make electricity to power an electric motor is much, much lower than burning gas to directly move the car.
    Tom
  10. mmichaell
    mmichaell Member
    241
    chicago
    This is said without full comprehension how it all works, but when the ICE is running - let's say you are driving at a constant 50mph on the highway, isn't the ICE always still charging the battery still, and isn't some of that charge wasted? Or are you saying that the ICE will temporarily run at a higher rpm to charge the battery that you just slightly or moderately discharged minutes before?
  11. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    I try to avoid it because if the ICE is cold, the emission is higher. The catalyst converter is cold too and it will not operate best. The result is more emission goes out the tail pipe and you also waste gas.
    For emergency situations (pull out to incoming traffic), you need to accelerate hard. One way to avoid it is to warm up the car in advance until you are out of stage 1.
  12. qbee42
    18,058
    3,073
    Northern Michigan
    No. The ICE does not charge the battery for free. Any charge that goes into the battery is using more fuel.
    There are situations where energy would otherwise be wasted, such as braking. You can think of this as free charge, even though it originally came from burning gas.
    Tom
  13. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
    Were you driving at the same speed seeing 20 mpg and 40 mpg?
    My assumption is a warming up fuel consumption is based on seconds(time) per gallon instead of miles(distance) per gallon.
    If you drive twice of speed, you'll see double instantaneous mpg on such condition.
    Ken@Japan
  14. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    For those of us who don't understand much, like me:
    Is it better to drive reasonably gently during the warm-up period, so you don't have the engine being VERY inefficient at high revs
    or
    (if you have the choice) is it better to drive reasonably briskly (as some Toyota literature puts it) so as to warm the engine up more quickly
    Or is some other driving pattern best during warm up?
    Thanks.
  15. qbee42
    18,058
    3,073
    Northern Michigan
    Drive gently during the warm up. At this stage the Prius is mostly running on battery power and using the ICE to make heat. If you drive briskly you are forcing the ICE to carry the load before it is ideally ready.
    Tom
    3 people like this.
  16. ken1784
    2,940
    1,359
    67
    Yokohama, JAPAN
    5 people like this.
  17. shankyyy
    shankyyy Member
    172
    Charlotte, NC
    i warm-up around 3 mins atleast every morning, and i see around 10-20 mpg 5-min mileage, then i get about 40-50, and the third sometimes as high as 75 or more. clearly, the warm-up stage (where ICE kicks in in normal mode) uses lot more fuel as one would expect.
    i'm close to emptying my second tank, and i'm only slightly better than the first. so far,i'm about 38 mpg compared to the first tank of ~36mpg
  18. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    warming up the car while idling is not a good idea either. granted, i do it but only because i have to spend time scraping windows, etc. but i dont feel that you benefit from this.
    in my situation, its pretty much 20-25 mph for the first mile or so since i am in a residential neighborhood. in 10 months of ownership, i have just passed 8,000 miles so dont drive the Pri a lot and about 90% of the driving over the past 3 months has been my 7 mile work commute. i think my work commute does well simply because
    1) speeds max 40 mph (sometimes faster in the morning if "need" be but never over 45 mph)
    2) i have a gentle drive for first part of commute on both ends.
    3) warm weather.
    now, if not for the warm weather, i would be around 46-48. i am at 50 mpg, so the weather is contributing to at least 2 mpg.
  19. ksstathead
    1,244
    243
    Kansas
    If you limit your warming up to 1 minute, you should see an improvement, because the warming after S1a (see Ken's link) is pure waste of fuel. Get it moving at that point.
  20. gazz
    gazz Member
    216
    Coventry, UK
    If I drive very carefully for about a minute to the end of my road I accelerate very slowly to about 20mph and see about 20mpg all the way to the end of my road.
    The other way is to accelerate to about 30mph (speed limit) quicker revving to about 1700rmp and then going into "N" and rolling to the end of the road, most of that time I am seeing about 40mpg (UK).
    This is not totally scientific but was just wondering if that first 60 seconds on battery is very inefficient, and maybe is done that way to ensure the cat is warmed in case you drive very slowly for the first 60seconds, but if you drive more normal the cat is warmed and you also get better mpg. In other words are we driving to slowly!
    It was just a though, in every other instance slow is best.
