First Fillup
Discussion in 'Prime Fuel Economy & EV Range' started by crewdog, Mar 14, 2017.
  1. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
    Gotta make an out of town trip tomorrow, so filled up today even though it was only a little less than half tank.
    2928 miles
    6.176 gals at pump, 1st cutoff, 43 f ambient temp, level ground
    474.09 mpg at pump
    23 mph avg speed while system up
    93% EV driving ratio
    5.2 mi/kwh avg
    YeeHaa!
  2. huskers
    huskers Senior Member
    2,546
    2,488
    Nebraska
    Wow, wow, wow, and wow. Amazing. Enjoy the long trip.
    52,393
    is your engine coming on every 200 miles like the pip did at 124?
  4. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Based on the ECO dashboard of some of the high rollers ICE hasn't come on at all, and it's not mentioned anywhere in the Prime manual
  5. bisco
    52,393
    i'm taking an informal poll, crew dog has a lot of experience with this.
  6. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    Awesome work on the mi/kwh!
    I'm hoping I'll do better once it's warmer out. So far I'm 3.9 mi/hwh
  7. Eric Maple
    Eric Maple Junior Member
    27
    28
    Mattoon IL
    I had to fill up today too. This is truly my 1st fill up. I topped it off when I 1st bought it on 11-27-2016. Never put anymore fuel in it until today. Very happy with the Prime.
    Arctic_White, john1701a and bisco like this.
  8. bisco
    52,393
    i filled up 10-27-16, 2,000 miles and 3/8 of a tank left.
    Eric Maple and thatoneraccoon like this.
  9. crewdog
    493
    388
    Woodstock, GA
    I think it has come on by itself once or twice in almost 4 months, but seems like there's been enough times using climate control briefly starting ice or using that last 4 miles in hv mode that keeps the 200 mile clock reset on it's own.
    Also gotta say that downhill regen seems noticably higher than pip.
  10. bowang
    bowang Member
    45
    37
    At this rate soon there will be a prime need 5k oil change before first gas fill up.
    Look at those 999mpg on Eco dashboard ranking with hundreds of miles. That's only advanced trim with activated safety connect. Must be more prime out there didn't use one drop of fuel yet.
    Arctic_White likes this.
