first oil change on the new 2010
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sidetrack, Apr 17, 2010.
  1. sidetrack
    sidetrack 2010 prius ll Blizzard Pearl
    Wauseon Ohio
    did a oil change on the 2010 III at 3200 mi. looked dark, don't know if I would go the full 10,000 mi.
  2. john1701a
    john1701a Prius Guru
    12,749
    5,244
    57
    7,500 miles has been no big deal with the older models using 5W-30.
    In fact, there's simply no comparison to my mom's Corolla at just 5,000 miles.
    Prius is really easy on oil.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You really can't tell from just looking at it. A used oil analysis (UOA) is the only real way to tell for sure. Sides, the first change should happen early on < 5,000. IMHO.
  4. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    I have checked mine when it was changed at 5k 10k and 15k and it looked clean to me, it wasn't clear but was no where near black. So i will be doing the 10k oil changes from now on. I used to go 5-7k on my chevy with regular dino oil and it was fine.
  5. bisco
    49,359
    kinda surprising, i've gone more than 10,000 miles sometimes on some of my 6 toyotas ( by mistake:rolleyes:) and the oil has never looked anything but light yellowish brown.
  6. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Search in this forum on "oil change" - there's a lot of experience documented here on oil changes early in 2010 Prius ownership. I've contributed some of it (changes at 1400, 5000 and now 10,000 mi).
    The oil is doing its job, trapping contaminants, plus with a new engine breaking in, there could be more blow-by past the piston rings. That will diminish as the rings get seated. I just changed my oil and the oil looked reddish and translucent, cleaner than the first & second changes and this after 5000 miles. I put a TRD oil filter in and I'll go for 10,000 miles this time on Mobil 1 0W-20.
  7. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    Oil filter traps contaminats, oils main job is to lube the engine parts. There is no need for engine breaking in, it was done before you got the car. The only thing you need to do is not to drive it at a constant speed for a prolong length of time, which has been stated in the manual.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    It won't go 10,000 miles because its dino oil and its the motor break in oil. Its not special break in oil I just mean its the oil on board for the engines first 4,000 miles. Lots of wear there that it won't see for the rest of its life.
    But you changed it at the perfect time though.
    Put a new oem filter and 3.8 quarts of Mobil One 5-30 in there and your good to go for the next 10,000 miles no problem.
  9. john1701a
    12,749
    5,244
    57
    That oil weight is for the older generations.
    0W-20 for the 2010.
  10. almypal26
    almypal26 Member
    101
    So Cal
    What did you use to remove the oil filter cartridge? I tried to use a 65mm wrench, but it slips. Any suggestions?
    Thanks, Al.
  11. andino
    andino Senior Member
    746
    550
    San Jose, CA
    ^^ Use a 64mm wrench and its perfect.
  12. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    It can and will go 10,000 miles because 2010 priuses are factory filled with Toyota 0W-20, which is a full synthetic oil.
    Im changing mine though at 1000 miles to get rid of the break in junk and installing a TRD filter too. Then ill cash in on the free maintenance at 10k miles and get an oil change then as well.
  13. Eoin
    Eoin Active Member
    593
    116
    Long Island
    I just took my 2010 prius in to the dealer for the first service at 5,000 miles. They rotated the tires but did not change the oil. They even gave me a form stating "customer declines oil change". I did not. They assured me that Toyota recommends the first oil change at 10,000 miles. Tire rotation is every 5,000 miles.
  14. hornedfrog
    hornedfrog Junior Member
    32
    Did you have to sign this? I have 400 mils on mine after 6 months. Time must also be a factor?
  15. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    I bought the Toyota Special Service Tool (SST) it measures 64mm.
    Toyota P/N: 09228-06500-02, It listed for $99.92 got it for $84.93, it is made of steel and fits snug on the filter housing.
    As mentioned by others check out the other oil change threads, lots of info. there.
  16. Mendel Leisk
    38,636
    Honda's 64mm oil filter wrench also fits (p/n: 07HAA-PJ70100).
