First Oil Change vs. Warranty Issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by journeydog, Apr 27, 2009.
  1. journeydog
    journeydog Junior Member
    Southwest NM
    BACKGROUND: Bought our '08 new from local dealer in April '08. I'm a stroke survivor and after a year and a half, am still unable to drive or service the Prius. My wife is the principle driver and in the year we've had it, only managed to put less than 1400 miles on it (yep - that's one thousand, four hundred miles).
    ISSUE: No services (oil/filter, etc.) have been done since new. Haven't looked at the Toyota Service Manual to determine if scheduled maintenance must be performed every 6 months regardless of mileage. If so, it sounds like the warranty is bye-bye?
    Sales folks said the 1st service cost is on Toyota. Is this a universal Toyota perk or a dealer sales incentive? (I've pretty much always ignored dealer servicing with my other vehicles because experiences have been poor and one of my past joy-filled hobbies has been involved with getting lots of oil and blood imbedded in my hands).:heh:
    Forgive me if this topic has been discussed over and over, but I'm trying to get my DW up on the curve before she talks with the stealer service folks. BTW, she loves the Prius!
    TIA with any useful comments or suggestions you might offer.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The service should be every 5000 miles or 6 months Toyota Parts and Service. In your case I would only have them change the oil and filter. You don't need to rotate the tires based on the low mileage. As for the 1st service being on Toyota, that's a dealer thing, not a Toyota policy. I don't think your warranty is at risk.
  3. Patrick Wong
    18,200
    6,474
    It is true that the engine oil/oil filter is supposed to be changed at 5K miles or six months whichever comes first, for the sake of the powertrain warranty. I'd suggest that you catch up on that now, since a year has elapsed.
    If your engine were to have oil sludge problems (which is unlikely) then Toyota could choose not to honor the warranty due to lack of timely oil changes. Other than that, you should not have any other impact to your warranty coverage. Good luck.
  4. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    So, how about new cars that sit on a lot for 6-12 months? I've noticed Tundra's sitting that long, not moving at all. I wonder if every 6 months, they pull those brand new vehicles into the bays to have an oil change?
    Yeah, right
    How about the build date? Say between building a Toyota in Japan, sitting in a shipping lot there, sent on a slow boat over to a port here, sitting for another 2-3 weeks, finally sent to a dealership, might add up to 3 months right there.
    Say it takes another 3-4 months to sell, and the proud new owner drives off in a new Prius - or FJ or whatever Toyota is still made in Japan - with only 30 miles on the odometer, but 6-9 months on the oil. In theory, that brand new Prius or FJ with only 30 miles on the odometer, should have had an oil change already
    When it's on the dealership or factory, they claim its ok to use that oil that has been sitting in the sump for 6-9 months, subjected to frequent start cycles with zero highway driving. But if you do it to your personal vehicle, suddenly *that* is a problem???
    I don't get it
  5. icarus
    icarus Senior Member
    4,884
    976
    earth
    Not to mention the 12v agm batteries!
    Wouldn't surprise me to see a lot of "new' cars with very short original 12volt batteries. A conventional lead acid battery can lose ~12% per month,, not including any parasitic drain such as smart keys, or clocks or alarms,,, that could be 50% or more. The quickest killer of lead/acid batteries is leaving them in a state of discharge more than a few days,,, much less a few months. HMMMM?
    Icarus
  6. tochatihu
    tochatihu Senior Member
    9,059
    3,529
    Kunming Yunnan China
    2001 Prius
    Hey Journeydog, I have no concerns at all about this warranty. When you get the chance have the engine oil changed. Go to Toyota or some other shop for this, and just keep records of the date and odometer (at each vehicle service).
    Good luck and I often wish I were back in SW New Mexico!
  7. patsparks
    10,664
    567
    Adelaide South Australia
    Warranty only becomes an issue if you need it and that's unlikely, with a Toyota, especially at your mileage. Another part of the first service is checking over the car for loose bolts n stuff, but that isn't likely needed either however as others have said, get the car in for a service as soon as you can.
  8. zonie911
    zonie911 Member
    585
    Nashville, Tennessee
    I would think that just putting a few miles on the Pri (such as was mentioned) would be more detrimental than it being a car in shipment or just setting on the lot and not moving.
    It seems to me that the oil (since it is being carried thru the engine and being heated up) would over time deterioate
    I may be wrong, of course "I have been wrong before"
    But, get that car into your dealer as soon as possible and get the oil changed.
    Also, I'm surprised that the engine battery didn't go down.
    :deadhorse:
  9. jayman
    13,439
    640
    Winnipeg Manitoba
    Well, if there is a problem during the warranty, and it's approved, than warranty covers it. If they can prove "neglect" or its off warranty, than TFB you're SOL
    Yeah, now thinking about it, those vehicles at a dealership should have some sort of float charge being applied to the battery. If the build date is 6 months or more in the past, an oil change would be a good idea too
  10. jayman
    13,439
    640
    Winnipeg Manitoba
    Well, part of the problem is that the engine may be started 20-40 times during all that shipping/transit. The engine may run for a couple of minutes, tops
    All those frequent cold starts really load up the oil with trash, especially oil in a brand new motor. My FJ had a build date around 5 months before I bought it.
    When I had the oil sampled at 3,000 km, it was completely shot. Nitration was through the roof, implying the oil had been subjected to a lot of short-cycle operation before I got it.
    Even my mostly highway driving to the hobby farm, around 80 miles one way, wasn't enough to burn off the trash. Some of the blowby and other trash just hangs around
  11. KD6HDX
    KD6HDX New Member
    256
    Chino Hills,CA
    Hello JourneyDog,
    Next time we are in NM I could change it for you if you buy the oil and filter. We usually go to Santa Fe in September for Fiesta. Of course I would like to have a sopaipilla or two for my labor charge. :) Maybe some red chili and a margarita for lunch...hoo hoooo.:rolleyes:
    Good luck with the dealer.
    Dave
  12. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    I have been wondering about this too and thinking if I should change oil after the initial 1K~2K miles as opposed to the Toyota recommended 5K miles. Suggestions?
  13. firepa63
    1,761
    208
    Personally, I follow the 6 mo / 5K mileage schedule. There is really no reason to change oil at 1-2K.
  14. jayman
    13,439
    640
    Winnipeg Manitoba
    As far as an early initial oil change, I guess that really depends on the vehicle and the use. A vehicle that may only see 2,000-3,000 miles a year, with factory oil it had *better* be changed
    Only a used oil analysis can uncover if the oil is shot, eg low TBN, high nitration and oxidation, etc
  15. 2009Prius
    2,705
    510
    63
    Thanks! I drive about 1K miles per month.
    Where do you get oil analysis done? How much does it cost?
  16. jayman
    13,439
    640
    Winnipeg Manitoba
    I get my oil sampled at Toromont Caterpillar, which is a HD equipment distributor of Caterpillar equipment in Canada. Their testing lab is in Concord, Ontario. Retail cost is $20, due to an arrangement I have with a client, it doesn't cost me anywhere near that
    A popular choice in the US is Blackstone
    Blackstone Laboratories
    and it will also cost you around $20. Some of us more anal Prius owners have routine oil analysis done on our cars. The used oil analysis is a good "snapshot" of the condition of your oil and your motor, and can uncover issues long before they become troublesome
    Eg: a crack in the tube between the airbox and the throttle body, a torn air filter element, a very slow internal coolant leak, an oil unsuitable for the motor, etc
  17. KD6HDX
    KD6HDX New Member
    256
    Chino Hills,CA
    JourneyDog:
    Will be in NM in a few weeks. Driving on the 40 east to ALBQ, then North along 25 into SF.
