First Planned Maintenance
Discussion in 'Gen 2 Prius Main Forum' started by Spcalan1, Jun 23, 2011.
  1. Spcalan1
    Spcalan1 New Member
    104
    Flowery Branch, GA
    Well it is time for me to to the first 'scheduled' maintenance on my 'new' 2006 Prius.
    - Oil Change
    - PCV Valve
    - check belt
    - inflate tires
    Anything else ?
  2. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    How many miles?
  3. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Refer to your owners manual and if you aren't sure that the last major service was actually done, do it.
    One extra service to consider is a transmission fluid change. That has been covered in several thread with oil analysis to justify doing the first change at around 30k miles than later changes at about 60k intervals. Yours has likely never been changed.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    PCV is a PITA. Change spark plugs, clean throttle body and MAF sensor while you are in there.
    +1 on the transaxle fluid change. Do it regardless of mileage.
