First Snow, low temps...
Discussion in 'Prius c Fuel Economy' started by james cook, Nov 4, 2012.
  1. james cook
    james cook Member
    145
    36
    Louisiana
    I did 42.9 MPG on my recent fill up, 8.5 gallons.
    It's even colder now here in minot, north dakota and only going to get colder....
    drove around today and got 25 MPG...... started off with 7 MPG then 16 MPG and finished with 25 MPG...
    would getting a block heater increase the mpg? I purchased one but too lazy to get it installed...
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    It will help reduce the ICE warm up cycle but if ur running the heater it will keep the ICE running.
    U might also want to look at the grill blocker
    RocMills likes this.
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Keep checking tire pressure too! Sudden cold temps means you're losing air pressure.
  4. Mendel Leisk
    38,726
    I had ours plugged in yesterday for about three hours before start up. Tw0 hours is the practical limit for raising temp's., but...
    Anyway, immediately after startup cooolant temp was showing around 100 degrees Fahrenheit, and within a couple of minutes (just backing out, getting out of our cul-de-sac) was up to 120 degrees. That rapid rise is likely due at least in part to the coolant temperature getting more homogenized, with circulation.
    Ambient temperature was around 50 degrees Fahrenheit. As that drops so will the block heater results I think, but you can typically count on it to raise coolant temperature by 40~50 degrees F.
    The temp. observations were with a ScanGage.
    BTW, we got ours installed by the dealer, when we purchased the car. Installed they charged us $400, pretty steep. I might have taken it on myself, if I was doing now. From what I've heard/read it's doable, but a bit of a struggle.
    You should really look into grill blocking too. There's a Prius 3rd gen grill blocking thread here, not sure how applicable it is to the C, or if there is a similar thread for yours:
    2010 Prius Grill Blocking strategy | PriusChat
    It likely can't hurt (inspires confidence, eh) to block just 50% of lower grill. If you've got continuous slats on the C, 1/2" plumbing pipe foam insulation is very effective. The 1/2" refers to the pipe diameter: the OD of the insulation is maybe 1.5".
    You can also use that stuff to reduce heat from escaping through the hood. This is 3rd gen Prius, but something similar might work for you:
  5. frugaldriver
    frugaldriver Ceterum censeo Carthaginem delendam esse - Cato
    81
    26
    Somewhere over the rainbow
    Now today is getting colder still for North Dakota (15 F is the high, 8 at night in Bismarck), how are the MPG's holding up in Minot? I had trouble just getting out of the apartment complex driveway today (nearly got stuck a couple times). I think you guys got the worst of the snow up there. Bismarck got 3-4" from that storm, though that wind doesn't help any :confused: . Are you going to try that grill blocking thing mentioned on the other forums? I would like to see if that would help at all if you would be willing to try that.
  6. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    What kind of tire slips are you seeing in snow? Is it more agressive than the regular Prii? The wife's hatchback simply goes limp at the first sign of tire slip.
  7. james cook
    james cook Member
    145
    36
    Louisiana
    I'm down to 36 on my usual trip to work I'd get 55-48.
    going home is usualyy 55-65 now i get about 38-42.
    I'm at 40 miles per gallon for 200 miles with 130 miles until empty:cry:
    Car drives well in the snow, snow tires are a scam...lol..we got like a foot or so over the weekend..my friends car got stuck but my C didn't stall at all.....
    I notice at lower temperatures the car refuses to use battery even if it's fully charged:mad:
    I'm too lazy to grill block..I'm moving to hawaii at the end of december!!! NO MORE SNOW EVER AGAIN!!! I'M EXPECTING TO AVERAGE 50 MPG ON THE ISLAND!!! lol
    Mik1 likes this.
  8. frugaldriver
    81
    26
    If the temps on the ocean were what we get here, maybe you could drive there :p. Wouldn't be a whole lot different than driving to work these last couple of days. Well, according to the people so far that have grill blocked, its only a couple of minute mod that costs pennies on the dollar, might be worth the investment if it works. And as long as you don't live on Mauna Kea, you'll probably be fine as far as snow is concerned :LOL: (wish I could live in a temperate climate again :cry:) . Thanks for posting your results.
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Not really. :)
    All-season and summer tires lose pliability in cold temps and increase stopping distance fairly dramatically at temperatures below 45F. Just saying. :)
  10. james cook
    james cook Member
    145
    36
    Louisiana
    That video is hilarious. Meh, I drive slow.
    F8L likes this.
  11. frugaldriver
    81
    26
    I agree, drive like its winter, and you probably wont see the difference in tires. To people who only experience snow when they drive up to it or live in an area where it snows but warms up enough to melt it, then the sudden shock of driving on wintery roads may save some headaches. I am curious though if there is a difference when driving on ice, or icy pack snow (when it heats up enough to melt all of the snow around the packed snow, but the packed snow remains and re-freezes). That stuff is annoying, and generally means that it takes more time getting going from a stoplight. Don't know if its $150+ a tire annoying, but would be nice to have more traction in that case. I would love to drive on the snowy roads they showed compared to winter roads here.
  12. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    Snow tires are not a scam. Traction is everything, and "all season" tires don't have anything close to the traction of snow tires in below freezing temperatures. All you have to do is bump into another car or slide off the road and you have paid for snow tires. My favorite winter tires are the General Altimax Arctic and Bridgestone Blizzacks.
    Last year as I drove a snow covered interstate to work, I saw a pickup truck come on the to the road too fast for conditions. He was what I call a "shooter". There are two types of drives that I don't like. Some are shooters (drive like they are in a Nascar race), and "slugs" (could not catch a cold and merge on an interstate at 45 MPH). Well, this shooter guns the engine to get to the left had lane just in front of me. The tail of the truck came around quickly and his head lights were pointed right at me. With snow tires on my car I made a quick maneuver into the right lane and as I went by, the shooter was grinding up the passenger side of his truck against a center guard rail. Those snow tires paid for themselves that morning.
    F8L likes this.
  13. Mendel Leisk
    38,726
    Also, after the initial outlay, for the snow tires and extra rims, you will be extending the life of your regular tires. Burning the same amount of tread yearly.
  14. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    You may also save a life. Tires are the most important object on your car. Why mess around when your life or someone else's is at stake? I find it inconsiderate to drive on unsafe tires which includes tires worn past 4/32s when it's wet out.
    sfv41901 likes this.
