First tank after replacing my HV battery and first tank though my Prius in general. How'd I do?
Discussion in 'Gen 2 Prius Fuel Economy' started by Banksy, May 6, 2020.
  1. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    This is the first tank though my 08 Prius with 251k on it. It took 8.4 gallons and cost me only 16.50 to fill. I'm not going to lie my mind is pretty much blown with how efficient this is.
    My hours and hours of work seem to have paid off.
    I filled it right as the last bar started to blink
  2. ydpplqbd
    ydpplqbd Active Member
    551
    253
    Good work!!!!
    My experience: once you get a used Gen2 sorted out, it is one of the greatest, most efficient and delightful cars ever.
    jerrymildred likes this.
  3. Banksy
    415
    132
    Agreeeeeeeeeed
    Best car ever if it is all sorted now
    Totally glad I saved it from the mean streets of jersey
    Considering rewarding it with a tint job
    Raytheeagle likes this.
  4. fotomoto
    fotomoto Senior Member
    5,633
    3,808
    So. Texas
    A newbie's progress through the stages of hybrid ownership is always good to watch. (y)
    In addition to the improvements you taken so far with the car, a big factor is climate. Low a/c and heat use during moderate weather means more energy is applied to moving the car down the road and not the sub-systems. In PA, you should see mileage decrease during summer with a rise again next fall before plummeting in the winter.
    Once you get the car sorted, look into "pulse and glide" and other techniques in this sub-forum that others have discovered pays big dividends in fuel economy.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Well you don't REALLY know what your efficiency IS having only the number of gallons used.
    You also need the actual miles driven to do the math.
    And the number of gallons used on a single fillup might not be accurate either.
  6. Banksy
    415
    132
    Definitely will look into that
    I'm happy with these results this far though!
    Definitely worth the time I put into it!
