First tank mileage question
Discussion in 'Gen 3 Prius Fuel Economy' started by Wavey, Dec 7, 2009.
  1. Wavey
    Wavey New Member
    Alaska
    There's probably a whole thread about this, but here goes. I filled up today for the first time while the last bar was blinking. Our ODO reads 378 miles and I put in 10 gallons exactly, so about 38 mpg. But one of my trip meters was running since the beginning (it read 377 miles) and quoted a consumption avg of 43 mpg. What am I missing here? I'm not too concerned about the relatively low numbers as it's (A) my first tank and (B) averaging about 20 degrees (F) here in Anchorage. But what about the difference in mileage calculation? Is it due to the consistently inaccurate MFD mileage calculator which is well established here? Which do we think is the correct number?
    Thanks,
    Russell
  2. fuzzy1
    10,254
    I'd say three things:
    (1) the displayed MPG is consistently too high, though that seems too much to be accounted for by this alone;
    (2) the 'dealer' fill never counts, because you don't know if they filled to the same level that you do, and they almost certainly used a different pump;
    (3) you don't know how much fuel was used before your trip meter was reset. 1 mile doesn't allow for much moving fuel, but it could have done some cold idling before that reset.
    Revisit this issue after the next refill.
  3. HelloMyPrius
    HelloMyPrius New Member
    48
    N. Cal
    I am still on my first tank of gas (140 miles total). My displayed MPG is at 44.6 but it has been slowly creeping up. Hopefully it will get close to 50 by the time I get my first refuel.:)
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I find the computer readout to be almost always about 2mpg out. I have also found that filling up at different pumps and different fuel stations can make a difference too - such as one pump clicking off earlier than another and also filling up on a slope one time and on the level the next etc.
    I fill up a lot :(
  5. mbarrows
    mbarrows Illini Bird
    210
    17
    Frankfort, Illinois
    My first fill up was worse than that! We went 152 miles and I put in 5.163 gallons last night. MyHybridcar.com calculated 29.4 MPG - Yuk! I hope future tanks are a lot better than that. We averaged between 44 - 46 MPG in our G2 2005 Prius.
