First time PHV owner : questions.
Discussion in 'Prime Main Forum (2017-2022)' started by swaldman, Dec 10, 2019.
  1. swaldman
    swaldman Junior Member
    UK
    2018 Prius PHV
    Excel
    Hi all,
    I just acquired a 2018 Prius PHV yesterday. This is my first time with a Toyota and with a plugin vehicle. I have a few silly questions that I hope y'all can help with:
    1. Is there any way to switch the clock in the dashboard to 24h? I'm not American, and I find 12h clocks weird and jarring ;-) #firstworldproblems
    2. What is the difference between "EV Mode" and "EV City"? I haven't had a chance to try any fast roads, but around town they feel exactly the same. The dealer told me that the city version should lighten the steering, but I can't tell any difference.
    3. I've paired my phone with the car, and it works for making phone calls, but when I try to switch the audio source to Bluetooth it sits on "Loading..." forever. Is this a known problem? The phone works fine in other (non-Toyota) cars.
    4. What's the smallest number of Android apps to utilise the largest number of free charging points? (both in terms of finding them and using them).
    5. I note that there's an option to let the car access the internet though my phone. What does it use this for, and how much data does it use?
    6. Trying to make the satnav map less cluttered and more readable, I turned off lots of things in settings, including street names. Yet they still show on the map. Am I missing something?
    Thanks for any help!
    52,001
    congrats and welcome!
    looks like you need another u/k owner, all the best!(y)
  3. Trollbait
    12,543
    There should be a way of changing the clock in the settings. Though some features can only be changed by the dealer. Check the manual.
    North America and Europe have different EV modes. There is an old thread here delving into the differences. Your EV is the same as our EV Auto; the car runs mostly in EV, but it will access the engine if it feels it needs to. We don't have EV City; sounds like it is for cities with EV only access areas. The car stays in EV almost exclusively. I think the engine might turn on if you literally floor the pedal.
    Don't actually have a Prime so can't answer the rest, but #4 sounds like it would be better answered on a more UK or Europe centric site, as we have different charging networks.
  4. Tideland Prius
    16,559
    On our North American cars, you can change the clock between 12h and 24h in the settings through the 4.2" MID on the instrument panel and the controls on the steering wheel (right side).
    EV City is a lower power version of EV Mode, designed for low speed city driving and meant to help extend the range of the battery by limiting the power output.
    Tips, drash and Trollbait like this.
  5. swaldman
    UK
    2018 Prius PHV
    Excel
    Thanks, found the clock setting (for some reason by default that menu starts in the middle - I had scrolled down, but had missed all the options available by scrolling up!)
    EV City feels a tad pointless; it feels like "we have a spare button here, we need to put something on it". Maybe it satisfies some regulatory requirement somewhere.
    The bluetooth problem remains a mystery - I've had to resort to using a 3.5mm cable, which feels a tad old-fashioned in 2019. And, presumably related, I still can't get the car to see the internet via my phone. But hey, I'll replace my phone before I replace my car, so maybe that'll help ;-)
    After a long night drive this weekend, I am in love with the adaptive headlights. My only criticism is that on a clear road (i.e. the full beam is being used), the throw into the far distance isn't actually that great. Possibly that changes with the different beam pattern that's supposed to kick in above 75mph, but one can't legally drive above 75mph in the UK ;-) And seeing further ahead, and less to the sides, would be useful from about 50-55 on British country roads. I think this is a "buy the dongle to change this setting" setting, so I might have to do that...
  6. PianoBench
    PianoBench Member
    154
    95
    San Francisco
    I have experienced this problem a lot as well. For reference I drive a 2017 Toyota Prime Advanced with the larger tablet. And I have my android samsung galaxy S10+ paired to the car. 9 to 9.5 times out of 10 the bluetooth works fine and audio/music plays normal. However sometimes there is no bluetooth audio/music playing and what I tend to do is just find the source menu and reconnect the phone. In that menu it allows you an option to pair either both phone and audio or just one by itself. I suspect that is the bug. Phone calls and text messages always work.
  7. swaldman
    UK
    2018 Prius PHV
    Excel
    Thanks - glad I'm not alone. Sadly it's an every time problem for me (with a Nokia 7.1), so just repairing doesn't help.
    I've resorted to pluggin in a 3.5mm jack (my phone still accepts those!), but it feels very 2005 :-(
    Incidentally, has anybody else found that the bottom half of the rear window is exposed to muck from the road, but hidden from rain, and thus gets really dirty really quickly?
  8. PianoBench
    PianoBench Member
    154
    95
    San Francisco
    The sat-nav is horrendous because of the way that the screen is positioned. Up and down like a smart phone. While the sat-nav itself appears to have been designed for a "TV" viewing more 16:9 screen ratio as opposed to it being flipped like it is. So you will often miss important things like when to turn left or right because the screen is lacking in left or right real estate viewing. I don't have a clear photo to show yah, but I think you understand already. Just zoom out enough so that you can see upcoming on or off ramps coming your way. The tiny pop-up will always pop-up before an oncoming ramp or turn. Cannot shut that off.
    You can actually adjust the headlamps on your vehicle for both lights for both up and down, and left and right. In the hood there are grooves that go into a sort of gear like screw the size of a US quarter. Just take a long flat head screwdriver and stick it in there. There are indicators that show which way to turn to go L/R or U/D. Just find a nice, flat, dark parking lot w/full moon, with nothing on either side, and preferably with a wall to aim at and you can adjust your lights to your hearts content.
  9. swaldman
    UK
    2018 Prius PHV
    Excel
    In Europe we don't get the big vertical "I saw a Tesla and figured if my screen was the same shape it would be as good" screen. From what you and everybody else I see seems to say, this is a good thing! But yeah, the satnav is terrible but there's nowhere sensible to mount a phone to use Google, so we live with it ;-)
    Hmm, my issue is less with aim and more with beam pattern, which won't be adjustable in the same way. I've actually been really impressed with the aim, both in terms of levelling and with the adaptive full beam system, which (apart from the aforementioned lack of throw) is amazing!
    Thanks for the tips.
