First time replacing headlights
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by galileofigaro, Feb 17, 2022.
  1. galileofigaro
    galileofigaro Junior Member
    37
    2015 Prius Plug-in
    Don't know which to replace of maybe both headlights? What bulb type?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Yes, replace headlight bulbs in pairs. The OEM bulbs are 55w H11 bulbs.
    49,399
    is it base or advanced?
  4. vvillovv
    vvillovv Senior Member
    3,616
    1,273
    NY
    Here's the parts list for the 15 PiP headlights. There's some surprises in that list, including 2 separate replacement Headlight bulbs. Which looks like from your pics you might need one of them on one side and the other one on the other side. Just guessing so far though.
    Headlamp - 2015 Toyota Prius Plug-In
    Might even be worth the $20 for the techstream 2 day subscription for your model so you'll know exactly which parts you need and more importantly how to change the bulbs.
    techinfo.toyota.com
    #4 vvillovv, Feb 18, 2022
  5. ChapmanF
    15,503
    I frequently steer people toward TIS, but where bulb replacements are concerned, it's pretty much always possible to find what you need to know for zero cost from the "bulbs" section of the owners' manual and from searching on parts.toyota.com.
    The repair manual on TIS will be useful if you need more step-by-step on how to change the bulbs.
  6. bisco
    49,399
    mine were really easy, but i think advance are different
  7. galileofigaro
    37
    2015 Prius Plug-in
    based
  8. bisco
    49,399
    it's pretty simple, just a quarter twist to get the holder out, and pop the old bulb out and new one in.
    i forget if i did low or high, low i think.
    the passenger side is difficult. tight space to work in, and i have large hands. most difficult part was lining it up properly to insert and twist back in.
    i managed it, with a few scrapes on my arms and hands. i'm sure you can disassemble things if necessary.
    watch
  9. bisco
    49,399
    I got these on amazon
  10. xliderider
    7,869
    3,116
    Honolulu, HI
    FYI, don't get any grease or even oils from your fingers on the glass part of the bulbs, it will create a hotspot on the glass and can lead to cracking/failure.
  11. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    For the passenger side headlight I found it easier to put the replacement bulb in and then hook up the connector. Spent lots of time trying to get it to seat properly connected to the wiring harness, but had no problems once I unhooked it and just put the bulb in first then connected it.
    vvillovv and bisco like this.
