first time smog check!!
Discussion in 'Gen 2 Prius Main Forum' started by p123456789, Aug 13, 2011.
  1. p123456789
    p123456789 New Member
    25
    mary esther fl
    So 2 weeks ago I moved to hamilton county in tn and it turns out that they smog check vehicles which I have never had to do. I was wondering how often does the gen 2 prius fail smog checks? my car has 120k and no dtc's stored should I be fine?
  2. reverai
    reverai New Member
    119
    Alexandria, VA
    I've never head of a Prius failing a smog test without the engine having major problems!
  3. Patrick Wong
    18,200
    6,474
    If you had the iridium spark plugs and the engine air filter replaced at 120K miles, and there are no warning lights on, then you should not have to worry about an emissions control test.
