For Sale FiveAD S5F wheels 19x8.5 +45 $400
Discussion in 'Private Sales' started by riceroni87, Mar 14, 2018.
  1. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    Selling my wheels since wife will be using the car now and wanted something with a little more sidewalk. They are gunmetal in color. If you want flush fitment and your on a budget, these could be the wheels for you. I’ll start with the bad,
    The Bad,
    All wheels have some curb rash, they can be repaired though. This was a daily and rashes was caused by either a valet drivers or my wife even though she won’t admit it.
    It has two good tires and two bad ones. Good ones are wrapped in Federal 595 SS and have around 7k miles on them. The bad ones are Delentes that have camber wear since I was running camber on the rear. I’d suggest you get new ones if you scoop these up.
    The Good,
    They will come with tpms, lugnuts, key for the lugs, hub centric rings, and I’m letting them go for $400.
    Local pickup only (I live in Palmdale, CA) or I can meet you in the San Gabriel or San Fernando valley.
    iPhone ? Pro
    HelloHybrid likes this.
  2. JC91006
    16,474
    8,393
    Will this look funny on a non lowered car?
  3. riceroni87
    360
    598
    Oxnard, CA
    Not sure to be honest with you.
    iPhone ? Pro
  4. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    What tires size are you running and are you rubbing on these lowered?
  5. riceroni87
    360
    598
    Oxnard, CA
    215 35r19. I’ll rub if I lower it to the lowest my coilovers will go. If your on lowering springs you will be fine
    iPhone ? Pro
  6. torparts
    torparts Senior Member
    417
    643
    Compton
    Happen to know weight? Trying to ball out but I’m on da negro budget.
    Salamat pare
    Nopho4u likes this.
  7. riceroni87
    360
    598
    Oxnard, CA
    I think the wheels are 25 lbs a piece? I’m sure someone might chime in
    iPhone ? Pro
  8. SD-Realtor
    SD-Realtor Junior Member
    39
    What sort of mpg loss did you have running these? I may be interested in upgrading from my 17s. Also, are your fenders rolled? I see some bacon strips going on there. I'm lowered on Tien H springs, and I wouldn't want to rub, or damage the body at all.
  9. riceroni87
    360
    598
    Oxnard, CA
    My mpg has a wide range on these wheels. It can be as bad as 35mpg when I’m on it and it’s all city miles or long drives it can get back up to 45mpg and not going over 75mph. You won’t have issues with just lowering springs. Coilovers may be an issue if your threaded almost all the way down. These are probably not for you if your worried about mpg loss.
    iPhone ? Pro
    Yea Right likes this.
