fix you a head gasket
Discussion in 'Gen 3 Prius Main Forum' started by georgefrank, Jan 9, 2025.
  1. georgefrank
    georgefrank Junior Member
    83
    earth
    3rd gen Prius
    Check engine light saying piston 3 misfire
    Whenever it is cold, it will jerk the engine bay with the misfire, it sporadically comes on and off
    has been driven with this issue for 20k miles
    Will eat about a quart of oil per month
    you open the injector to clean it, and you see oil in that chamber
    Is this 100% a blown head gasket?
    Suspicion: head gasket is blown and oil is leaking into that chamber
    242k mile, has overheated once and completely shut off due to failed water pump at about 170k miles
    the part you are fixing to order:
    Part number: 11115-37062
    This part number only include the head gasket
    There is another kit for about $200 that has many extras,
    Should you get just head gasket for $58 or get the whole kit for $200?
    The job is scheduled for the next 1-3 weeks depending on timing since you are using the car daily
    go now look for the part number for that kit and see which way your fixing to go
    OEM Toyota 2010 - 2015 Prius Cylinder Head Gasket Set 04112-37254 Genuine NEW | eBay
    kit from Japan 210 dollar
    part number: 04112-37254
    get just the gasket or the whole kit?
    The only part of the install you are concerned while watching YouTube clip:
    you have to take off the camshaft/timing chain/tensioner to do this task
    You saw how they mark their timing at 2 o clock, but you'll be documenting it for this thread once you do the task in couple week
    Goal: get all the detail figure out, then do the surgery in one shot so the car is not down for too long
    update: it could not be the head gasket
    Read some of this forum and mendel signature, also watched this video:
    in this video, they talk about symptoms exactly I am having
    They talk about EGR valve and PCV port problems, they get clogged and oil somehow get into the intake
    I still do not understand the point of EGR valve and th PCV valve, read up on them and comprehend them
    the issues that indicate it is not head gasket:
    When you go full throttle, no shaking/misfire, but
    when you drive flow of traffic, there is shaking
    In the video, he discuss this being a symptom of bad egr/pcv valves
    Why does it have the EGR valve? In the video, he puts a spatula blocking the whole system, and the car works fine
    New plan: first clean the EGR valve and the pcv valves, then see if that help
    Can we go without these systems? What is the point of them?
    Try to research these two questions in the meantime while data is coming in
    update: now you understand why our engine is eating its oil, unbelievable
    in this clip, you get your exact answer as to how the prius engine can eat its own oil if EGR valve clogged
    if throttle is at 0, and your egr valve is clogged, now the engine is starving for air
    the vacuum will pull oil from the PCV valve from the bottom of engine into the intake manifold
    wow
    yes, now that new data come in, adjust your plan:
    Clean you out that EGR system and that should solve your engine eating its oil
    #1 georgefrank, Jan 9, 2025
  2. BiomedO1
    BiomedO1 Senior Member
    4,112
    2,156
    SacTown, Ca
    The head gasket replacement may not take care of your intermittent misfire, if it's due to oil fouling your spark plugs. There's three ways oil gets into your combustion chamber: gummed up low tension piston rings, valve guide seal leaks, and scored piston walls. You need to figure that out first! You'll probably also will need to replace your CAT in the near future, due to the high oil consumption.
    IMHO, you should buy the head gasket rebuild kit, that should have new valve guide seals and other gaskets you'll need to do the job properly. The really good ones has new stretch bolts replacement.
    Hope this helps.....
    georgefrank likes this.
  3. georgefrank
    83
    earth
    you've had enough of the misfire/shaking
    fix it already, today is the day
    you point: this is the valve that get clogged and suffocate your japanese engine
    open everything up, let your engine breath so you can glide across your realm
    take you out whatever in your way
    up close of inside egr valve, filled with carbon
    ton of accumulation on your egr pipe
    maybe dissassemble the whole valve, go tinker with it
    i show you what you fixing to do
    this plastic manifold is filled with sut/carbon since,
    your engine has been breathing exhaust gas for a quarter million mile, and
    tons and tons of idling where only exhaust is going into your engine
    keep dissassembling, take you out more harnesses, take you out your intake manifold
    look inside your intake manifold, filled with gunk
    trying to take out the plastic manifold, started taking off lines,
    one of them filled with coolant, splash coolant into your eyes
    suspicion: there is a coolant line going to the intake manifold that maybe cool down the exhaust coming back into your engine
    plan: get you some files and part cleaner, go you into your engine cleaning out the gunk breaking it down with part cleaner, hit everything with compress air
    plastic manifold complex: leave it as it is, clean it using the same protocol outlined
    clean you out your intake with:
    use paint brush to apply generous part cleaner, go in there with your file, hit the entire area with compress air
    tried to put it back together, put back the harnesses to see if she would run,
    no, "check hybrid system", tinker with it more tomorrow
    you ponder: if all the harnesses are connected, and the pipe that puts exhaust back into your intake is not connected, does the car know not to run?
    pretty sure you had all the harnesses connected but the computer would not let the engine turn on
    This setup is fundamentally flawed, you wonder if the old Prius has a simpler setup
    do not touch this engine bay without gloves, it seem like they make so much sharp plastic all over the place just to intentionally not let you fix it
    This job so far is making you not like this generation prius, and want to look into older prius to see their design
    #3 georgefrank, Jan 12, 2025
    52,371
    it's a sad situation. nice write up though
  5. Mendel Leisk
    41,884
    Sounds like runaway oil consumption as well. Consider replacing piston/rings, or safer with those miles and history: new short block.
    my 2 cents: time for another car.
    Brabus82 and georgefrank like this.
  6. georgefrank
    83
    earth
    Make sure all harness proper, see if you can run car without egr pipe
    make sure all harness plug in fully, try to run the engine without egr pipe, if it dont run,
    clean out your egr pipe and maybe take off the whole egr housing and clean that
    then put it all back together and see if engine will run
    how does it know if the egr pipe is install or not?
    show you what you did:
    put your egr pipe into a pool of part cleaner, then run you a metal pipe cleaner and rid you of all the carbon, hit with compress air
    your egr pipe is ready to go another quarter million
    then your egr housing was FILL with carbon, get you pipe cleaner, douse the area with paint brush part cleaner, hit you that area hard with compress air non stop
    put back your new egr pipe, the bolts to get this in are so tight,
    your hand would be pulverize if you dont have on glove
    with it half put back together but all harness plug in,
    your japanese engine roar to life with ZERO shake,
    purring just like it come out the japanese factory
    wow
    then engine shut off because all these random code
    woah: your japanese robotic hybrid is way smarter than you think, it know when its egr pipe is install even if all the harness plug in
    unbelieveable, go now rig everything back up proper, erase the code somehow with your chinese gadget,
    then see if you can get it to drive and not have engine fault
    while you go back and reassemble your japanese robot complex, ask you
    please someone show us how to get around the egr pipe for experimental purpose,
    how can we tell the computer not to care about the egr and just run the engine?
    update: it will turn the engine on, the engine purr properly, then it shut engine off after 20 second
    the possible culprit code:
    U0100, lost connection with ecm pcm A
    look you through that internet, figure out what their talking about
    woah, those flimsy sharp harness, if one of them get loose, you could be stranded who knows where having to deal with this, and
    it makes servicing the car harder, leading to the thought,
    there has to be a way to simply rig your overcomplicated japanese robot,
    to override its ability to shut down your properly functioning engine,
    go now search about that code on the internet,
    hopefully someone spill the sauce on how to overide the system to use the car
    woah, check out what you come across on that internet
    he put a paper clip in the 4th top, and 5th bottom of your OBD port, then
    he go into the fuse box and take out your big white wire, then
    he hit the brake 10 time,
    and all the code are gone
    is this a troll or for real?
    woah, look you through the comment on that video, everyone of them is:
    "I was stranded on the hwy and you saved me, bless you and your family"
    from every angle of the world, this little trick saving tons of people
    articulate what he does:
    There are different thing he is doing, the paperclip and the removal of white wire in the fusebox
    paperclip: that might have something to do with resetting ABS fault
    white wire removal: you are resetting your hybrid system to check all its pathway are proper
    hopefully, the white wire trick should work to get your prius at least able to be used
    notice you last time you try to run your engine:
    after it shut off from the warning, you walk back to your hood, and you hear clicking of relay in your fuse box following a certain pattern, almost like a song
    please y'all comment on what is happening:
    where does that white wire go and why does it work for all those people?
    What exactly is happening when you put a paperclip in those 2 obd port?
    you do need to use the car so hopefully you get it work out
    also for the help of million of people to keep their Prius running,
    discuss we the way of how these system work, and experiment I and show picture until fix
    #6 georgefrank, Jan 13, 2025
  7. Mendel Leisk
    41,884
    You need a work bench lol. Just a 2’x4’ sheet of 3/4” plywood with utilitarian, metal folding legs will do.
  8. georgefrank
    83
    earth
    experiment with your prius, ask nature to give you a break
    soon we go experiment with reset prius hybrid system, experiment with the prius hoping to get it to run again
    although you have decide already that you will not let it go, and get to the bottom of the issue, still you say to nature:
    nature I am tired of solving problem, somehow please give me a break and in exchange, I share with the people the sauce on how to get around the prius safety feature so they don't need a tow/get their gold/cash taken from them for no reason
    and to show the people that yes, their prius is amazing, the Japanese engine, but
    it was the lawyers/insurance/corporation that put pressure on Toyota to make a faulty product
    your theory: the engineer that make your prius is secretly on your team, to get around all the faulty setup,
    that they gave you a way to get around all the problem stopping your prius from gliding you across your realm
    go you now: make that narrative true, prove to everyone that yes, the Japanese engineer is on your team, to keep your prius on your road
    solved, your japanese engine purr back to life like nothing happen
    what an idiot: you did not fasten the grounds on top part of your engine,
    What gave it away:
    "Lost connection" code lead to you figuring it out
    yes, still you experiment with running your japanese engine without egr pipe etc
    go you now glide across your realm with your japanese hybrid robot
    turns out your just an idiot and the japanese engineer is on your team
    #8 georgefrank, Jan 14, 2025
  9. Mendel Leisk
    41,884
    That makes sense I guess. :oops:
  10. ASRDogman
    ASRDogman Senior Member
    7,800
    3,979
    ???????:confused::confused::confused::eek::eek::eek:(n)(n)(n)WHATTTT??????????
    Brian1954 and georgefrank like this.
  11. Mendel Leisk
    41,884
    I'm not sure what to think. Hides his profile, and from "earth".
    #11 Mendel Leisk, Jan 14, 2025
  12. Mendel Leisk
    41,884
    Google Translated? Or AI generated?
  13. georgefrank
    83
    earth
    sorry i am a real person diagnosing their prius, the writing stye is to hopefully invite solution
    apology if it is confusing, but I intend to not break any forum rule and spread solution to other
    update:
    glide across your realm in a bit of limp mode
    does not have full power, check engine light throwing code only about air flow sensor, was disconnected, but
    the code for the misfire gone unbelieveable
    continue experiment:
    take off egr pipe, but leave all harnesses connected, including the air flow harness
    what happen if you take out egr pipe, and plug all harness properly, can we get all check engine light gone?
    now you go test
    @Mendel Leisk
    mile 245k
    Tried running prius without egr pipe, will run for 20 second, then shut down
    the code it throw:
    P3190
    go look you up that internet and see what they say
    put egr pipe back in, plug in all harness, zero check light, wow
    your japanese hybrid robot know when you take out the egr pipe and will not run your engine
    in this picture, you try another experiment, shove you some paper into egr pipe to see if you can trick computer,
    no, computer does not get trick and know not to run engine
    now it is running fine with a tiny bit of shake
    plan: go you through the rest of the egr valve, you already clean the closer half, take you out the entire egr assembly, hit that with all the cleaner, let it sit in part cleaner, etc
    take you out the rest of the egr assembly, try not to take out too many other harness/etc
    get you in there and clean it, and rid your japanese engine from the small rattle
    car been running 1 hour cycling, no check engine, no misfire
    go you now and finish the job
    go you back in your egr situation
    found more carbon inside the plastic intake manifold, get you a massive pipe cleaner, go as deep as possible, dose it all in paint brush part cleaner, hit entire area with air, do this multiple time
    tried to reach bolts to remove rest of egr body, couldnt, might have to take out your windshield wiper
    go watch you a video see how they take out the egr body
    in this clip, you see what it take to take out your egr assembly:
    remove your windshield wiper, get you the right torx tool to remove the big stud holding egr body to engine block, use 12 mm on swivel to take out rest of bolt,
    ton of work to clean your egr assembly
    somewhat defeated since you cannot finish job due to time/tool, put your engine bay back together
    you need a 2 day span of time to take out all the everything to take out egr assembly
    but at least your check engine light gone, japanese engine purring, gliding you across your realm
    #13 georgefrank, Jan 14, 2025
  14. ASRDogman
    7,800
    3,979
    CR94, Brabus82, Kromis and 1 other person like this.
  15. Mendel Leisk
    41,884
    What's the miles on the car, on the odometer? I'm thinking it's head gasket.
  16. bisco
    52,371
  17. Mendel Leisk
    41,884
    Ah, see now, in initial post. Thanks.
  18. georgefrank
    83
    earth
    search you for hour and hour for the solution, and it was on your forum
    wow, in the quote, you get your receipt that yes, the Japanese engineer is on your side, that
    all you have to do is just unplug the egr harness and your car will run better
    articulated perfectly and exactly how you imagine it, @Paladain55 spill the sauce for everyone
    soon, go you try to unplug your harness on your egr, and see if the trick work
    remember: if you reset the system, the car will do that thing where it run for 20 second and shut down
    you have to plug egr in, let it run, then unplug if you reset 12v system
    if this work, you could possibly take out the egr pipe, and disconnect the harness, and it should run better
    also when looking around for solution, it seem like EVERYONE has the same exact problem, all you hear is the death rattle and egr talk
    How many prius have this problem before we say,
    "putting exhaust back into your engine is the dumbest idea you ever come across"
    5 million prius? 10 million?
    I bet you right now there are 20 million prius in America with death rattle
    In that thread reference, there is someone in Brazil that declare that prius in other country does NOT have egr and will go 500k miles with same head gasket etc
    unplug the harness that go into your egr, make that check engine light come on
    go run you around doing errand, see if it improve
    it has full power when you want to go, but during idle still some shaking, with one episode of big shaking
    next experiment: try now to take out your egr pipe with the egr harness not connected
    report back with what happen
    take you out your egr pipe and unplug egr harness
    no, tried to take out egr pipe and the harness, computer will not allow it
    computer so picky, even if you try to run it without airbox, it knows and wont run the engine
    sad sad, pour you some oil thinking it wasnt that low, no
    you poured half a gallon to get it to full,
    rip your gen 3 prius, and many others will all start to break down at this time
    You were hoping @Mendel Leisk was not correct, but yes he is completely about the head gasket
    you are FUMING as you work on your plastic engine bay with sharp stuff everywhere,
    thinking about how much you paid in gold for this machine that you thought was made proper,
    nope, just like the forum said, by the time you figure out how it work, your head gasket will be rip
    they successfully did it, the lawyer broke the toyota reliability
    calm down try to come up with plan:
    1. you have to figure out how to run the engine successfully without exhaust going back into it
    someone know the sauce on how to put a resistor on some wire to make it think everything is fine with egr
    2. spend you probably 3 day dissassembing and assembling top of your japanese engine cover in sharp plastic everywhere
    take off windshield wipe situation/literally everything/all harness/the timing situation with tensionor/chain/complete nightmare
    it is not worth fixing unless you get make sure you can figure out #1, the exact question,
    "How do we trick computer into letting it run without egr pipe so it can pull in regular air?"
    you are a bit nervous that you will be stranded somewhere if it keep eating this much oil
    calm you down a bit, adjust your narrative:
    "the japan robot took you around the world almost ten time, saved you thousand and thousand of gold in fuel cost, you have slept in, camped in it, etc,
    cant you appreciate that it took you that far? who care if your japan robot down for 3-4 day for heart surgery? if you do it yourself, and everything work out, it can cost you $200-300 total,
    humble yourself, save your estate, do the title of thread"
    wow
    here is another 3rd gen that was total, part prius, 93k miles, also has death rattle last it was running, not eating much oil but who know
    inside of your part prius
    what could happen:
    take you out the engine from this prius and put it into the other if this one does not have blown head gasket
    then you can rebuild your other engine properly and still have a car to run errand
    the engine that currently need fix, need:
    head gasket, spark plug, piston ring for all 4, connecting rod bearing
    that should be it but that alone will cost 400-500 dollar, and who know what else your missing
    or, watch you a video of what it take to take out your death rattle engine, and place in the 94k mile engine that might have death rattle
    summary:
    either fix the current engine, or just bring in your spare engine into your prius
    dont decide anything yet, soak it all in, about what this mean, be you frugal in your plan
    your so angry about it not letting you run your engine without exhaust going into it, that
    you will get to bottom of how to trick the computer using science/nerd method
    #18 georgefrank, Jan 15, 2025
  19. Brian1954
    Brian1954 Senior Member
    2,396
    960
    South Central PA, USA
    You really do not know what you are doing or talking about. It will be interesting how this ends.
  20. rjparker
    rjparker Tu Humilde Sirviente
    10,489
    6,576
    Texas Hill Country
    You have a failed engine which needs replacing. Bad rings and a bad head gasket are the root cause.
    The engine won't start with a small vacuum leak much less a big one from the egr.
    A rebuilt engine that is swapped in will eliminate oil consumption, fix the hg problem and will give your experienced mechanic easy access to cleaning things.
    Swapping engines can be easier than a hg job since no camshaft removal or timing chain installation is required.
    #20 rjparker, Jan 15, 2025
