Fixing Cat and Misfire (420, 030*) price
Discussion in 'Gen 2 Prius Technical Discussion' started by Victorio Mo, Jul 11, 2019.
  1. Victorio Mo
    Victorio Mo Member
    124
    31
    Folsom, California
    Just hit a 3,6K estimate to fix these errors on my nice Prius '08 with 230K.
    It's highly reputable shop so they don't deal with aftermarket, their cat price from dealer 2,2K (?).
    And for Misfire they think need at least new plugs.
    Anybody can share their experience using 200$ cats from ebay? I definitely don't need this last 10 years. Couple of years max.
    Will appreciate any hints. The best part that I'm California.
    Tx all
    Mario
    #1 Victorio Mo, Jul 11, 2019
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    The walk into the Dealer price for an OEM cat should be around $1300+ without install.
    Ebay and others will not ship third party cats into CA. Smog tech also might not pass the visual test.
  3. Victorio Mo
    Victorio Mo Member
    124
    31
    Folsom, California
    my Local Toyota dealship cat price = 2200.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    I guess you must have the oem cat under which is why we see so many reports of stolen cats off g2's on this site.
    You will fail test with aftermarket cat.
    California strictest smog in the country.
  5. Victorio Mo
    Victorio Mo Member
    124
    31
    Folsom, California
  6. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    I’d chat with @Joele3 as he may have some ideas ;).
    Good luck and keep us posted (y).
  7. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    What dealership? Folsom Toyota?
    Go to this website and look up part 17410-21500.
    1741021500 - Toyota Catalytic Converter (Front). Pipe, Exhaust. Engine, System, Intake | Roseville Toyota, Roseville CA
    It’s 1650.03 internet price at Roseville Toyota and you can choose pickup at counter and not pay shipping. List isn’t even 2200 for crying out load. It’s 2148.55 plus tax.
    And keep the old one. You can sell it for 300-350.
  8. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    I'd fix the misfire and see if the cat rejuvenates itself, if you have time to inspection.. As an advanced topic there is a wet chemistry way to take off some of the cat contminants (Zinc/phosporous from the lube oil leakage) but that assume you got lots of DIY energy and resources and not enough money.
  9. Skibob
    2,912
    1,505
    Northern California
    I would like to know this.
  10. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    #10 SFO, Jul 12, 2019
  11. Skibob
    2,912
    1,505
    Northern California
  12. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  13. Skibob
    2,912
    1,505
    Northern California
    SFO likes this.
  14. Skibob
    2,912
    1,505
    Northern California
    I wonder if I could just dunk the cats in a bucket of citric acid overnight then a quick dunk (60 minutes) in Oxalic acid to finish off? They were pumping a solution thru.
  15. Victorio Mo
    Victorio Mo Member
    124
    31
    Folsom, California
    Thanks guys (and girls?) for all info. I will check all plans. Dealer was in LA area, I don't want to give any names just for the case. But I have a part # now so I will check around. Misfire estimate was only for replace plugs, so I it can be separated, originally was single 420 code, without misfire, so I assume fixing misfire won't help.
    I don't think I able to do any chemo procedures as well, so will check all leads on Monday.
    I have time till September for smog.
    Best
    #15 Victorio Mo, Jul 12, 2019
  16. Victorio Mo
    Victorio Mo Member
    124
    31
    Folsom, California
    I add 1 Qrt oil each 3000 miles, so I think this could make any Cat bad faster. Just another factor to estimate how feasible this repair is.
  17. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    In addition to what @SFO has said, I believe there is a thread here on Prius Chat the guy actually did it, I am thinking it worked.
    I am thinking he had to take the cat off the Pirus, which may involve some difficult cutting. Then he put it in a bucket of solution, and dired and put back on.
    I see if I can find the thread but no promises no hints, except you can look for my name as I was following his work.
    Skibob likes this.
  18. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    @m.wynn has experience with this;).
    He’ll be along and probably can share his method(y).
    Skibob, m.wynn and SFO like this.
  19. audiodave
    audiodave Active Member
    800
    272
    US
    If a new cat is the only solution have it shipped to a friend or family in another state and then to you. Find one you can install yourself.
  20. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    here's one thread, but not the thread I was thinking about
    maybe this one is the one..."Acid Bath and PA0420"
    https://priuschat.com/posts/2363229/
    I am searching on "CITRIC" and these past threads pop up
    Raytheeagle and SFO like this.
