Fixing the front end squeak
Discussion in 'Tesla' started by bwilson4web, May 23, 2023.
  1. bwilson4web
    15,513
    Over time, gravity settles the grease below the control arm, ball joint leading to a metal-on-metal squeak. I just fixed my front end, ball joint squeak without injecting grease or replacing the control arm.
    Jack up the car; remove the tire, and; remove the clamp bolt. Then use something like vice grips to grab the ball joint shaft and squeeze the boot to get grease in contact. Move it back and forth to coat the ball and the resistance and squeak goes away. The only problem was the clamp bolt threads were wiped out getting the bolt out:
    So I walked over to Mike's Merchandise, a neighborhood surplus parts store, and bought a substitute bolt, two washers, and locking nut, $0.28:
    Those are WD-40 spray stains on the wheel well. I also squirted down the control arm bolts.
    ps. I was inspired by a UK YouTube that correctly pointed out the grease didn't 'leak out'. Remember, gravity wins.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,154
    2,204
    Taylors, SC
    Hope you used a 10.9 grade bolt and nut.
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
  4. Mendel Leisk
    38,653
    I can’t for the life of me answer that. :unsure:
    What model of Tesla is this? What’s the miles on it, when this started happening?
    #5 Mendel Leisk, May 24, 2023
  5. bisco
    49,397
    2019 moel 3 with 108,000 miles
  6. bwilson4web
    15,513
    No good as the window washing fluid would spill out.
