fixing the prius battery?
Discussion in 'Generation 1 Prius Discussion' started by nightmare66, Mar 28, 2019.
  1. nightmare66
    nightmare66 Junior Member
    24
    Kentucky
    2001 Prius
    I
    think this will work? had to trim the metal a little, but coudn't find a replacement anywhere,
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    nightmare,
    if you would like, I can send you a piece of actual harness with a sensor tab on it that you could splice in. Post a photo of the wire and I can probably even match the color scheme.
  3. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    You could remove the plastic ferrule and just use the crimp. The plastic ferrule is there to grip the insulation part of the cable which, in this case, doesn't exist.
  4. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Toyota soldered those connections for a reason. Crimp is pretty substandard, prone to coming apart or oxidizing. Do it right or don't do it at all.
  5. ChapmanF
    18,501
    Here's where to find the replacement.
    Are you sure they did? Hard for me to tell from the photos I'm finding, but they look crimped to me.
    There's a difference with crimp connections between properly-executed and ham-handed (and a similar difference for solder, as it happens). Properly-executed crimps are gas-tight cold welds and will not oxidize or come apart in the contact area; they're the overwhelming choice in auto, marine, and aerospace where there are wires and vibration. (Solder is still king on electronic circuit boards and such, where stuff doesn't move; open any of the Prius ECU's and you'll find plenty of solder there.)
    In the case of this particular harness, which is high voltage and weirdly skinny, I would not have crimped it or soldered it; I would have bought a replacement. That's not a judgment of relative merit of crimping or solder, but only of my chance of executing a field repair as reliably as they can build those in the factory.
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    You can buy entire used wireframe for $40 or less.
    Just search for the words wire frame prius.
    This way you'll have extras when some more go bad.
    You don't really need insulation on the crimp terminal.
  7. vanionbb
    vanionbb Junior Member
    Kennewick, WA
    2002 Prius
    I too am working on a Gen 1 traction battery with the same issues. I am looking for a solution to the leaking electrolyte. I think if we use an O ring on the lug that sits just proud of the copper, then when we tighten the nut, the copper bar compresses the O-Ring and seals the leak at the gap between the plastic and the metal.
    O ring material must resist alkaline, so EPDM, here is a link to one site but the size is probably wrong. I need to measure what is needed.
    AS001-70EP | AS568-001 EPDM O-ring 70 Durometer (EP/ EPR / EPT)
    Need 76 of them, 2 * 38. Also need to measure the size. Any thoughts on this problem. If we re-hydrate the cells it will just leak again, so re-hydrate and seal externally is what I am thinking. If someone has already done this or something similar please let me know.
