flapper valve
Discussion in 'Gen 2 Prius Technical Discussion' started by superstar, Jul 29, 2009.
  1. superstar
    superstar New Member
    Los Angeles
    Is the flapper valve important in the gas filler neck on a 2004 Toyota Prius?
    __________________
    You win some, you lose some, you wreck some.
  2. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    Important in what way? As in... will my tank get messed up if it breaks off and falls down into the tank? Maybe. As in, if I rip it out through the opening and toss it aside, will my car blow up? Not likely.
    I'd figure the little flapper thing is just there to help mitigate evaporation. As long as you screw the cap back on after filling up, you shouldn't have to worry about anything.
