Flashing blue light?
Discussion in 'Gen 3 Prius Main Forum' started by mroe1, Apr 14, 2014.
  1. mroe1
    mroe1 Junior Member
    22
    Phoenix, Arizona
    My car sat for three days in a parking lot while I was away. When cam back I noticed a flashing blue light coming from just below the steering wheel and above the brake pedal at the edge of the under part of the dash. When I entered the car, and started it, it went away. Can't find any info in the book. What was this light trying to tell me?
    52,351
    is there an aftermarket alarm or anything?
    spiderman likes this.
  3. mrbigh
    3,686
    699
    Long Island, NY
    Did you buy a used or demo vehicle? if it was new, after 3/4 years you discover a blue flashing light?
    It sounds like an aftermarket product or...a time bomb!!!:censored:
    Something smells fishy
  4. mroe1
    mroe1 Junior Member
    22
    Phoenix, Arizona
    Not that I am aware of.......................... The dealer "turned on" the what I thought to be factory alarm system
  5. bisco
    52,351
    i've never seen a blue light anywhere. perhaps it's an option i don't have.
  6. fuzzy1
    10,602
    What factory alarm system? I don't remember any such alarm in the factory brochure for my 2010, so it must have been installed later.
  7. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    The only "flashing blues" I've ever seen have been those in my rear-view mirror (accompanied by a "wah! wah! wah! wah! wah! wah!) ;)
    DROID4 ?
    dorunron and alekska like this.
  8. nublar
    nublar Junior Member
    Irvine, California
    That's where they put the aftermarket alarm. I have one and there's a blue indicator light in the same position you describe.
  9. bisco
    52,351
    is that your s/o in the back seat, or the cops?:p
    WilDavis likes this.
  10. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Kmart Blue Light Special!!:D
    dorunron likes this.
  11. alekska
    alekska Active Member
    435
    138
    Atl
    I saw the lights you are talking about, just 3 days ago. Will cost me $$$ for +11mph. I should have told the officer Prius can not go fast, everyone knows that. Lesson learned.
    - Alex
    WilDavis and dorunron like this.
  12. WilDavis
    2,493
    2,155
    49
    ...especially if you're hypermiling!!!
    DROID4 ?
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Dealer installed, not Toyota installed. You have an alarm, but Toyota didn't put it there!
  14. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Yeah, it does suck when you are hyper miling through a 30 mph zone and happen to over shoot your target a little bit right about that time the radar catches you at 34. Cops here are fairly lenient, they usually give 10%, but don't speed through a school zone or use a cell phone either in that zone. Got nailed four years ago in my old Nissan truck. 44 in a 35 zone. Took defensive driving to keep it off my record. Never saw the cop, but he sure saw me...
    Lessons learned can sometimes be hard and expensive.
    As far as the OP's post concerning the blue light, I would venture to say it could be a fake led to make thieves think the car has a alarm on it. I see those quite often in cars and trucks around here. You can find those things in a lot of places. Real cheap and could be effective to help repel the average prankster.
    Ron (dorunron)
  15. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    That you had too many drinks on the plane maybe ?? :)
    There IS a light on the dash that flashes indicating that the "security" system is enabled, whatever that might be on the various models but on my C it is not blue and I suspect that it is soldered to a circuit board such that it can't come loose and dangle down behind the dash.
    Have you looked carefully after leaving it parked overnight after that incident ??
  16. mroe1
    mroe1 Junior Member
    22
    Phoenix, Arizona
    I'll have to talk to the dealer then, because when I asked about an alarm system, he said he could "enable" it for me. It was built into the car. So there's an after market one as well? HMMM? Have to look into this one. Thanks
  17. kenmce
    kenmce High Voltage Member
    1,551
    523
    NY
    That is your Global Warming Sensor. The car needs to sit in one place without moving for a while while it takes measurements. Blue means measurable, but you don't have to flee from that spot immediately. :)
  18. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    There is no "factory" alarm system, but there's one that's a common port-installed accessory. That's almost certainly what you've got in your car. (There are, of course, many additional options besides the one Toyota installs, too.)
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Does u horn think when u lock/unlock the doors?
    If it does then u have a dealer installed alarm.
    The Prius doesn't have a factory alarm, just keyless entry. When u asked ur sales rep to "enable" the security system, he was more than happy to do so at ur expense of ~$600. That is what the dealer charges u to keep that system.
    The blue light looks like this?
    VS980 4G ?
  20. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    OP, what you have is a KARR aftermarket dealer installed alarm. It has a few more features than the OEM alarm;
    1) shatter sensors
    2) fuel rail disabler
    3) horn chips (enable-1, disable-2, body motion-multiple short chirps)
    4) valet mode
    Some of the better KARR systems have a feature called TRACK (GPS) where you can follow where your vehicle is on a real-time map on a PC.
    privilege likes this.
