Flashing lights problem
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pauld010, May 13, 2021.
  1. pauld010
    pauld010 New Member
    France
    Hello,
    After a long time I went to use my Prius III, unused because of coronavirus and working from home since the start, all my flashing lights wont work, when i try to use them there is a buzzling sound in my dashboard. I put my car in december 31 at my closest Toyota center but they gave me back the car after few months, and checking some basic things, because "they don't have time to look after it and it will cost me too much to repair it". The car itself works fin exept the flashing lights. Any Idea where to look, I'm starting to feel desperate.
    Thanks for your future answers.
    Paul
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Check the 12v battery
    49,445
    bad flasher unit?
  4. pauld010
    pauld010 New Member
    France
    Thanks for your answers, the battery is new and the same model of the last one, and they changed the flasher unit. They told me an electrician should check wire by wire and that will cost a lot.
  5. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    o_O
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,909
    Columbia, SC
  7. pauld010
    pauld010 New Member
    France
    That's the relay, they changed it and the problem remains :(
  8. bisco
    49,445
    i was thinking the same thing, but figured france, don't ask.
