Flat tire and ugly yellow wheel
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Superdrol, Jul 4, 2011.
  1. Superdrol
    Superdrol Member
    399
    32
    Yesterday I ran over what appears to be an Allen wrentch which caused my tire to go flat. It was leaking air very fast and I could hear the hissing very audibly which is how I found out about it. The car currently sports the ugly yellow spare at the moment.
    My tires have 23k miles on them and I think there may be a good chance the tire will have to replaced due to the damaged. Should I just replace the one tire if it needs to be replaced or replace the two (in the rear which is where the flat is) ?
  2. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    If you can find the exact same type of tires you have on the car now......replacing one tire should be fine.
    If not,,,,,,then buy two matching tires for the same axle.
  3. dogfriend
    7,512
    1,190
    Carmichael, CA
    If you have 23k on them, I would buy a matching set for the rear.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Just to keep the debate occilating from yes to no and back, buy a single tyre.
  5. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    My tire guy says, assuming there is still plenty of tread left on the remaining tire and because this is the rear tire, you need only replace the damaged tire. It's always best to replace both rear tires at the same time, but sometimes, it isn't necessary. If it were the front tire, then you should replace both (unless there was very little wear on the existing tire).
    Another thought is that you might only need to get the tire fixed rather than replaced. I've done that when the tire is still relatively new.
    And by the way, on my Ford Explorer, Costco would only replace all 4 tires at once. I was told they will replace 2 tires at a time on the Prius but I haven't confirmed. I didn't ask whether they will replace just 1 tire.
    Mike
  6. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    23 is over halfway through useful life. I got 39k out of my OEM tires.
  7. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    Getting 2 news tires would be better at this point. Mine made it to 35k, which was pushing it a bit in the snow.
  8. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    has the tire guy tried to patch it from indie the tire? I got 32k from my factory tires, so at 23k I would replace a pair.
