Flat top "lock-on" jacking adapter for $27.88 Walmart jack
Discussion in 'Gen 3 Prius Main Forum' started by Georgina Rudkus, Nov 9, 2020.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,495
    Taylors, SC
    We developed this inexpensive adapter to allow jacking up either the front control arm or rear spring mount for changing a tire or working on the brakes.
    It locks onto the top of the $27.88 Walmart HyperTough two ton trolley jack which is also sold under the Torin or Amazon Basics name and many others.
    It is shown jacking up the Gen 3 Prius v but will work with most other cars.
    Very little lifting distance is needed to lift the car to get the tire to clear the ground. front tire off ground.JPG Gen 3 Prius rear tire up.JPG pad w Delrin center.JPG
