Flip phone battery ? <no laughs, plz) LOL!
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Aug 24, 2020.
  1. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,151
    1,701
    Mars Hotel
    If I have a 3.7 volt flip phone battery that has 800 mAh, can I replace it with a 3.7 volt with 1000 mAh?
    I have posted before that I don't have a smart phone. No real cell service where I live. Friends with Verizon, T-Mobile, Sprint, ATT, etc. all are amazed if they decide to brave the backcounty and finally arrive at my place....no service.
    Well, O.K., they are amazed they found the place, first of all and then are amazed that anyone would drive the single line road daily (if you meet someone, one of you has some backing up to do) and finally that cougars and bears did not attack during their journey.
    Anyway, I still have the Samsung Black Stripe Flip Phone that my father gave me in what -- middle school?
    It works fine....if I get to somewhere where it gets service. Of course, only for calls and SOME texts (it does not like texts from lots of folks -- have not figured out why it accepts some texts and rejects other).
    No matter, I don't really text. But, a friend said her grandfather died and had a couple of flip phone batteries, so she gave them to me. They fit and they are 3.7 volts, but they are 1000 mAh vs. my 800 mAh.
    I may be wrong, but I THINK my battery is the original....not planning to replace it, but if I need to would the 1000 mAh work?
    BTW, yes, I get a lot of teasing about my phone. Especially when I show them my "case" (a plastic baggie)> But, I pay less than $30 per year and I get what I need.
    kris
    #1 cyberpriusII, Aug 24, 2020
    bwilson4web likes this.
  2. Trollbait
    12,351
    Shouldn't be a problem. The h in the mAh metric is for hours; it's a measure of energy capacity. The 1000mAh will last longer than the 800.
    cyberpriusII and fuzzy1 like this.
  3. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    It will just be slightly "thicker", but should still fit in the baggie.
    cyberpriusII likes this.
  4. bwilson4web
    16,012
    I suggest taking a photo of the batteries side-by-side, width, length, and thickness, along with the connector. The further away from the batteries, the less camera distortion. But for grins and giggles, use this as an opportunity to verify both work.
    CAUTION: make sure the wire color codes are identical to the connector. It would be a bad thing to reverse connect the battery.
    cyberpriusII and Prodigyplace like this.
  5. Prodigyplace
    12,407
    11,682
    Central Virginia
    If it is the same chemistry, physically fits the phone and has the same polarity connector it should work. A second unknown question is whether your charger can handle charging a larger capacity battery.
  6. ETC(SS)
    6,958
    Already asked and answered.
    I concur with the above opinions that there should be no problem provided that the new battery fits and is compatible.
    There will be no charging problems if the battery does work with the phone. A larger capacity battery will just take a little longer to charge....but it should last longer once fully charged.
    No laughs here......flips are making a comeback!
    cyberpriusII and Prius Maximus like this.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    As long as it will physically fit......and has the right connector.
    I recently replaced a battery in a cordless phone. The new one LOOKED the same but was a couple of MM longer and would NOT fit.
    Thankfully I was able to exchange it for the right one.
    No need to wait too long.
    You likely will be amazed at the increased run time you get with a fresh battery of a higher capacity.
  8. Prodigyplace
    12,407
    11,682
    Central Virginia
    I was afraid it might try to draw more current than the charger design.
  9. Trollbait
    12,351
    A charger pushes electricity into the battery.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    The battery question has been handled well. I seem to remember from another post that you do have internet in your neck of the woods. If you want to make calls from home, and you have a wifi router, and your phone provider offers the service (most do, afaik), a smart phone would be the solution. You'll need a data plan, though, but they are a lot cheaper than they used to be.
    https://www.usmobile.com/blog/what-is-wifi-calling/
  11. John321
    John321 Senior Member
    1,367
    1,353
    Kentucky
    Big fan of flip phones -avid fly fisherman and often get dunked in the creeks along with everything I am carrying when wadding. Phones find a way to get wet even in plastic bags
    Here is my current flip phone with my backups . Ebay had them priced $10 for all 6 phones together Flip phones.jpg
    cyberpriusII, DavidA and Raytheeagle like this.
  12. ETC(SS)
    6,958
    No worries these days, unless a really REALLY large fish mistakes your phone for a lure.....
    Nearly all phones sold in the last few years more or less proudly advertise a confusing IP rating or IPCode, (IEC standard 60529) which really doesn't mean much when you consider that an IP 2x rating only protects the phone from intrusion by small fingers.....BUT(!!) nearly all phones these days carry at least an IP6x rating, which means that they're fairly water-resistant.
    Even newer flip-phones.....;)
    As a proud submariner, I'm hesitant to use the words "water" and "proof" together since very few things....really are.
    Even my beloved <$ 200 Android claimed military grade durability with MIL-STD 810G and IP68 rating for dust and water resistance.
    Of course, any device beginning with a lower case "i" is expected to be water resistant, dust resistant, and nearly toddler-resistant as well considering how much they cost---and for the most part they usually are.
    Heavy emphasis on toddler RESISTANT.
    Humans can, and some very few HAVE made things that are waterproof, but nothing is 'toddler proof.'
    #12 ETC(SS), Aug 25, 2020
    cyberpriusII and jerrymildred like this.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    If it doesn't fit just install it best you can then smack it really hard on the wheel of your stagecoach.
  14. cyberpriusII
    1,151
    1,701
    Mars Hotel
    Stagecoach? :confused::confused:
    Not paying for one of those. Around here we make do with a buckboard. !:whistle:
    edthefox5 and jerrymildred like this.
  15. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    I assume they are at least 3G phones? I wanted to use my old Nokia bar, but there are no longer 2G service providers in the US. Didn't want to spend $50-70 on new 3G 3310.
  16. John321
    1,367
    1,353
    Kentucky
    I am not sure what they are.I only use it for phone service and texting. Our provider is Consumer Cellular and they use AT&T and T-Mobile infrastructure.
    To be honest their most important feature to me is I can get 6 for $10 from ebay which makes them almost disposable. When they get dunked in the creek I have to remove and dry out the battery and SIM card in a bag of rice and then switch them to one of the spares.
    They cost $30 apiece from Consumer Cellular new and here are the specs. (Consumer Cellular doesn't care what type of phone you bring to their service as long as it is compatible with the network so buying one on ebay is fine with them)
    Key Features
    Large, easy-to-use classic 12-key keypad
    • Bright, colorful main display screen
    • Additional external display screen
    • 2.0MP digital camera
    • Bluetooth® 4.2
    • Supports up to 32.0 GB microSD card (microSD card not included)
    • FM Radio
    Dimensions & Details
    • W: 2.17" H: 4.37" D: 0.76"
    • Weight: 4.5 oz
    • Battery life: 14.0 hours talk time / 16 days standby time
    • Hearing - Aid compatibility: M4/T4
    Prices are applied at time of purchase, and include FREE activation.
    Devices are limited to stock on hand.
  17. Salamander_King
    11,009
    8,935
    New England
    Yeah, if AT&T or T-Mobile sim works in them, then they are at least 3G GSM phones. I have old flip and bar phones, but they are all 2G phones and now no carrier in the US. When my 7 years old Nokia Lumia Windows Phone8 OS stop working, I want to switch back to a dumb phone again.
    Data Daedalus likes this.
