FLOOD PREPAREDNESS
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Andyprius # 1, Oct 30, 2012.
  1. Did anybody manage to connect a inverter to thier Prius for power to thier refrigerator or freezer? ( assuming your house, garage was dry)
  2. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    I keep an inverter in my Prius. Last winter we used the Prius for power for two plus days. We used wood in the fireplace for heat. After a summer storm we ran fans off the Prius.
    Andyprius # 1 likes this.
  3. syscon
    syscon Member
    329
    43
    Edm. Alberta
    I am 99% sure next Prius model will have 120V outlet build-in.
  4. lensovet
    2,615
    496
    Burlington, NJ
  5. Good job.
  6. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    During a power outage, I ran our freezer in the basement, as well as our phone system off an inverter connected to the Prius. Unfortunately, our refrigerator in the kitchen drew too many startup amps and couldn't run off the setup.
    See the video for how the inverter was set up.
  7. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    Congratulations for making such a first-class installation and easy to follow video. There is one detail that I did not catch, do you recommend that the car be running when operating this setup?
  8. bisco
    51,140
    looks like we got the one percent.:cool:
    Pluggo likes this.
  9. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Yes, the car should be turned on, otherwise you'll drain the 12v battery. The gas engine will auto cycle on and off to keep the 12v battery happy.
    Pluggo likes this.
  10. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    A 1500W 100V AC inverter has been an optional extra with the PIP since the start in Japan - it's fully integrated, providing several outlets inside, as well as an adaptor to get an AC output from the charging port. I have not seen this available in any other markets, though.
