Flood Waters
Discussion in 'Gen 2 Prius Technical Discussion' started by bambauer, Jan 26, 2008.
  1. bambauer
    bambauer New Member
    santa rosa, Ca.
    My wife and I are thinking about purchasing a Prius soon. Last night, she encountered flooding on the roadway, and with police directing traffic through it. She wondered what would/could happen to the Prius batterys in the same situation. She was able to successfully navigate through the water in her Acura. If water made contact with the batterys, is there a shut off feature? Could she get electrocuted? Are the batterys watertight?
    Thank you in advance for your responses!
  2. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    The battery itself is about the level of the rear passenger seat, so the water would be that deep inside the car if it got to the battery. The wiring under the car floor is sealed, but if water is getting inside the car you are in dangerously deep water -- not from the electrics but from a loss of control, particularly if it's flowing.
    The battery is equipped with cutoffs to disconnect it in case of a short.
  3. patsparks
    10,664
    567
    Adelaide South Australia
    You will be very wet before water gets to the battery in flood waters.
  4. bambauer
    bambauer New Member
    santa rosa, Ca.
    Thank you for your help!
  5. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Just to be more specific: The cables carrying the high voltage from the battery to the engine inverter have a metal shield around them. If any water were to cause any electrons to take a shortcut through these metal shields, then a fault detection device disconnects the battery completely. This makes it close to impossible for the battery current to go anywhere other than the engine inverter.
  6. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    By the time the water reaches the metal cased NiMH traction battery, you will most likely have drowned in the car
