Flooded PRIUS
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sand0, Dec 27, 2005.
  1. sand0
    sand0 New Member
    I have some questions.
    I can buy a flooded prius with certificate of destruction.
    What cold be the posible damage on 2004-2006 Prius? Where are the weak point in flood on this prius?
    Thanks
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Water and electronics don't usually mix well. It might be worth buying to sell for parts.
  3. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    First of all Sand0, welcome to Priuschat.
    Secondly, like seasalsa said, if a Prius has been submerged, I would anticipate some electronic problems. That is, even though you can take it through the car wash and you can drive it in the blowing rain, flooding and submersion are pretty intense and I would expect water getting into some delicate areas.
    If you are buying a Prius from a dealer or auto mechanic and they are telling you up front that it was flooded and they repaired it, I would still be skeptical unless you know the people and know that they do really good work. Perhaps even press them for a long-term warranty just to make sure.
    Then again, perhaps if you just pump the accelerator a few times . . .
    (get it? flooded? get it? oh well)
  4. sand0
    sand0 New Member
    Well I can buy a damaged in crash PRIUS for about 3000$ for parts.
    But I don't know is it word to try assembly a new car from both cars.
  5. TonyPSchaefer
    14,816
    2,498
    66
    Well now that's an interesting concept.
    Should you decide to attempt this feat, please oh please take and post pictures. That would be cool to watch the progression.
  6. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    considering all the things that are probably completely screwed up from the flood and their tendency to reside in REALLY obnoxious places, it may not be worth it timewise.
    do you have a lot of technical experience with cars, and wiring, and electronics? and diagnostics in case something doesn't work right when you're done? if you've got the experience it would still probably be a challenge and pain to do, but hey. some people consider that a hobby :)
  7. richard schumacher
    7,663
    1,038
    United States
    Weak points for flooding: the engine, the two electric drive motors, the 12 computers, the 205V battery, the inverter, the multiple wiring harnesses... If you want to do this as a hobby, sure, have fun; the fun will never end.
    If you want to save money, buy a five years old Corolla or Civic.
